Go Back   Dodge Diesel - Diesel Truck Resource Forums > Specialty Forums > Cummins Conversions
Register Forgot Password?
Search
submit to reddit
Thread Tools Search this Thread Display Modes
Old 10-25-2009, 06:07 AM   #1
oliver foster
CTD in '85/need brake booster?
I just bought a crew cab that has been already been converted to CTD power. The brakes work but it reminds me of my manual brake powered '69 Cuda. I have to stand on the brakes to get them to work and no matter how hard I stand I can't get the wheels to lock up. I am thinking that the brake booster is a gasser job. Would putting a "diesel" brake master and booster be the set up I need? Those gas boosters work on engine vacaum right? The brake lines and brake calipers, pads and shoes where changed by the last owner as I am sure he was trying to make it stop better.
Any ideas guys?
__________________
'01 3/4, 4x4, LB, quad, Nv-4500, 4' Banks turbo back, Edge w/ Juice, BHAF, Banks High Ram, Custom bumpers, Leveled, Bilstein, 33s, Air dog 150, SB OFE, 200,xxx
'85 1 ton, 4x4, crew, '90 CTD/Getrag, 6' lift, 37x13.5
'85 1 ton, 4x4, crew, '90 CTD/727 , Over spring
airbags all the way round, 33s
'72 1/2, SWB, 318, stick, 4x4, lifted, 38's, 79,xxx original
'70 Challenger 440/stick
'69 B-Cuda 360/stick
oliver foster is offline   Reply With Quote
Old 10-25-2009, 06:42 AM   #2
JD730
I would seriously consider switching to a hydro boost system instead of vacuum. I've had issues with the vacuum systems on 2 of my 93's. One I switched to hydro boost and other I'm starting to gather parts for.
Here's a little reading on the subject.
http://www.dieseltruckresource.com/d....html?t=169715
__________________
Mike
That's not a leak, its the external lubrication system.
The "Rattle Box"
93 W250 Silver Club Cab, 47RH rebuilt by me with Goerend goodies, HTB2 62/12, hydroboost brakes, plus a few other things, 424/1039, 1/4 mile 14.00@94.3mph
2000 2500, 4x4, 6 speed, 12 valve, Homemade WH1C/HX55W twins
96 2500, Club Cab, AT
93 W250 Green Club Cab, AT
92 Club Cab, AT
07 2500, Quad Cab, 5.9L, Auto (Dad's new ride)
John Deere Two Cylinders, too many to list.
JD730 is offline   Reply With Quote
Old 10-25-2009, 09:13 AM   #3
rich
rich's Avatar
hydroboost is the way to go, gm has been doing it in their 3/4 and up trucks since the mid 70's its way better then vacuum
rich is online now   Reply With Quote
Old 10-26-2009, 06:26 AM   #4
oliver foster
I don't want to do something just cause GM did! LOL. I just can't belive that this is the best this brake system can work as it is un-safe in a panic stop. I can't get the wheels to lock up even on dirt and as an auto I am also fighting the engine! I will check the vacuum line to to see if it is cracked or broken. I will look at the hydro boost system as I have a few '94 and up parts Diesel Dodges I could steal the parts off of.
Old 10-27-2009, 09:01 PM   #5
Trooperthorn
Trooperthorn's Avatar
If you don't want to go with the hydro, just get the parts in there that were with the diesels in the first place. Put premium pads and shoes on it and turn the rotors and drums to remove the glaze. You should be good.
__________________
'77 w200 crewcab, 4x4, 91.5 ctd/nv4500/205, M&H chromoly tie rod. In the works.
'77 Ramcharger/clubcab shorty '91.5 ctd/auto/205, GSK, M&H #2 fuel pin, Guages, 37s on 8 lug 60/70, 16cm, screws turned, cross-over, Jungle frame kit
'91.5 w350 standard cab, auto, 3200 spring, m&h #2 pin, fuel pin maxed (91.5 short pin, 1.5 turns), 315k
'86 Jetta turbo diesel 145K.
Trooperthorn is offline   Reply With Quote
Old 11-05-2009, 09:13 AM   #6
oliver foster
So I am looking at swapping the brake booster and master for a diesel job out of a 1st gen Trooperhorn? That sound easier than swapping in parts from a different gen truck.
submit to reddit
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.6
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
vB.Sponsors
Copyright 2011, DieselTruckResource.Com
Contacts Backup
