Thread Tools | Search this Thread | Display Modes |
#1 | ||
Cruice control & Edge easy
__________________
o3 3500slt qd.Lb Lt.almond-2wd,SO47re-auto3:73 towpackage-sliderwindow-woodgrain-RhinoF/L steps P/e retrac tonoe cover Chrome bed rails. truckwith factury everything but leather (Az to HOT for leather).Side curtin air bag. |
#2 |
Re:Cruice control & Edge easy
I'm not sure if anyone else is aware, but there is a RECALL (Not a TSB) for '03 trucks for a cruise control issue. After using the cruise control for extended periods of time, there is a high idle experienced. I got the notice in the mail, but my truck doesn't have the problem. The solution is to update the ECM with updated software. Here is a link to the recall:
http://www.recalldata.org/2003/43475.shtml |
#3 |
Its Safety Recall CO2. I thought most trucks built within the last 7-8 months or so already had it fixed. If not, DC would still be flooding the mailboxes with snail mail. I had mine reflashed a few months ago. I never had the symptoms, hence my reluctance to fix something that wasn't broke.
__________________
Chris '03 2500 SLT QC 4x4 short bed, 305/555 HO, NV5600, 4.10LS, 4" SS exh; H2/35's, Smarty Jr. '06 VW Jetta TDI, 5-speed '01 VW Golf TDI; 2 Door, 289K, 5-speed Maryland DTR Chapter #33 Feelings of inferiority and superiority are the same - they both come from fear |
#4 |
I have the EZ and no problems at all with the cruise, empty or pulling it works perfect. Maybe with the new box the problem will go away.
__________________
2008 Resistol Edition Mega cab dually 2005 SRT-10 Regular Cab Flame Red. 12.771 @ 109.67 |
#5 |
My rig is fine, but I bought it back in the middle of June, so who knows. I still got the letter though.
#6 |
My cruise control holds a steady speed with very little variation at all. Also when resuming or going up or down hills, the change in speed is very gradual, it doesn't put on power very strongly at all. I'm assuming this is in the interest of fuel economy.
__________________
2004 2500 4x4 HO/48RE Laramie/Sport - Line-X, Jordan, Wet Okoles, Dynamatted, Scotty's intake, WinchReady Front/Rear Bumpers w/PIAA's, DPP 4" Exhaust, RDS 51 Gal Tool/Tank Combo, Amsoil Oil Bypass System, Boost/EGT/FP Gauges, Edge Hot Juice, Super-B, Kore Chase Suspension, Weld Wheels w/ 35" Toyo Mud Terrains, full DTT trans w/billet shafts, MITUSA fuel system. |
#7 |
The CO2 recall only applied to the trucks equipped with the six speed. Ram lon ON has the 47RE. I never experienced any of the symptoms but had the reflash done anyway also.
__________________
Took delivery 01/11/03: 2003 Ram 3500 Quadcab 4x4, LWB, SRW, HO, Six Speed, 3:73, LSD, Heated seats, Tow pkg, Laramie, Sport, Graphite Metallic, Slate interior, Mopar molded mudguards, Rear wheel well liners, Rhino Liner, 20x8.5 American Racing Chrome Kahunas, 285/55R20 BFG KO-ATs. Just say no to cabmarker lights! |
#8 |
I received CO2 recall the mail several months ago. It applied to the 5 speed and the 6 speed. I didn't have the described problem with cruise. After the re-flash I have experienced the check engine light coming on periodically. If I shut off the engine and then re-start it the light is off. There are no codes recorded so it is a blip in the software.
| Display Modes | |
