Crew Pictures
Old 12-05-2008, 11:23 PM
  #61
Trooperthorn's Avatar
Here is mine before and during disassembly. The frame is painted. The cummins and nv4500 is sitting on the shop floor waiting...
Old 12-06-2008, 02:19 AM
  #62
johny5's Avatar
Originally Posted by Featherman
Johny5.................you have some nice looking 1st gen crews with Diesels running around in your province. Should look the guys up and maybe you could hook up with them.
Once gentleman had a crew cab body (redone) listed on Craigslist, that I was thinking of purchasing but I was too far into mine.
I decided to graft the 85 crew body onto a 93 4x4 extended cab frame/chasis. Had to modify the floors at the rear to accomodate the difference in the frames and cut out a notch for the fuel sending unit; its all assembly now.
yeah we have a few nice trucks .
i'll post up the prower wagon i saw .
I bought my crew cab from Colorado and drove it home.
because i didnt want to do a ground up resto, but thats not been working out
this is a local truck i saw on the side of the road
Old 12-06-2008, 02:26 AM
  #63
johny5's Avatar
heres some of my favirite saved pics i have found online.
Old 12-06-2008, 06:42 AM
  #64
PapeCAT's Avatar
What a nice lookin truck... I think I've posted mine before.. but here it is again.
it needs some love.. bed is trashed, needs some cancer floor repair and desperately needs the whole drivetrain from my 1990 W250...
Old 12-06-2008, 02:24 PM
  #65
DodgeFreak's Avatar
I have a Question for the crew cab conversion guys .
Im putting the running gear from a 93 into my 85 CC .
did you have to move the transmission mount back about 2 inches?
i'll get a build up thread soon
On our 85 cc 2wd, using parts from a 92 2wd 5spd, we had to redrill holes and move it back about 2 inchs, The motor mount we had to pull from the 92 on the drivers side?? i think and reweld as it was different or somethign was different about it. enless we done work we didn't have to do...
Old 12-06-2008, 07:33 PM
  #66
The diesel trucks have slotted holes in the the under engine cross member. The older frames, at least those from the seventies, have a hole and a dimple under the mount. On my 1977 ramcharger, the factory motor mounts for the cummins went right into the existing holes. I thought I might have to slot the holes, but I did not have to. For what it is worth, here is a pic of the driver's side.
Old 12-06-2008, 08:08 PM
  #67
RumbleFish's Avatar
with all this talk, and somebody posting a pic of it already, here is more pics of my old crew
what it looked like when i got it. yellow and stacks, ewwwww!
bad pic, sorry!
off to the races!
Old 12-07-2008, 05:12 AM
  #68
johny5's Avatar
sweet, i have considered coping that color scheme
Old 12-07-2008, 05:55 AM
  #69
PapeCAT's Avatar
what intercooler did you put in that red crew?
Old 12-07-2008, 07:35 PM
  #70
RumbleFish's Avatar
its a banks unit. the PO built the truck, i bought it from him. he trimmed the backside of the grille to get it to fit and not use the gross tubular grille that came with the kits.
Old 12-08-2008, 12:36 AM
  #71
alwaysonDTR
Alwaysworking's Avatar
well here it is again
getting closer
https://www.dieseltruckresource.com/...d.php?t=196446
Old 12-11-2008, 02:37 PM
  #72
NoFrills's Avatar
I am in the process of converting a 85 crew cab I am trying to get the interior all done do you guys know of a sorce for a rubber mat or a carpet
Old 12-11-2008, 02:45 PM
  #73
johny5's Avatar
OK keeping this tread on the first page.
My next question is: What did you do for the drive shaft steady bearing mount?
Im trying to use all the stuff from the 93 club cab 4x4 in my 85 short box CC 4x4
I tried moving the cross member to where it worked perfect but then the gas tank would not fit.
the best I have come up with is to flip the mount over and move it back till its close to the tank then make a piece of flat plate to bolt to the mount that extends past the mount to bolt on the steady bearing
, **** more holes to dril in the frame
  #74
simplysmn's Avatar
I just went to lowes and bought my own carpet and padding and built my own carpet
Old 12-11-2008, 02:47 PM
  #75
johny5's Avatar
try these guys and let us know how they are .
http://www.motorsouthcarpet.com/Carp...oductName+DESC
Quick Reply: Crew Pictures
