Crew Pictures
Old 09-28-2008, 01:35 AM
kellypckp's Avatar
Crew Pictures
I would like to see some pictures of crew cabs or trucks in process.
85 2wd converted 4wd 91 w 2nd gen intercooler 47RH being painted Dark Garnet pear. Aftermarket Black and Gray seats to go in to it. It is a slow process and a money pit.
I thought I should give some pictures to go along with all the questions I have asked through out the years.
Old 09-28-2008, 08:03 AM
JD730's Avatar
Thats what I'm going to do with my 85 crew cab. Convert it to 4wd with 3.07's and use a single wheel bed. I had all the conversion parts before I had the crew cab. Now all I need is the time.
Old 09-28-2008, 10:03 AM
BRUISER's Avatar
Here is my conversion write up:
https://www.dieseltruckresource.com/...d.php?t=199864
I have soem stuff still to do , like piant etc.. but it is getting there
pics:
Old 09-28-2008, 03:17 PM
EatMySmoke's Avatar
This my dad's crew cab conversion. We dropped in the Cummins and converted from 2 wheel drive to 4 wheel drive. It still needs paint and some other finishing touches, but it's getting there.
Old 10-01-2008, 09:56 PM
simplysmn's Avatar
here is my old truck before I sold it and right after I rebuilt it from rolling it
8 in lift 3 in body lift dual front shock's and dual stablizer's was a dually bed but we cut the fender's to make it look better tires are 325-85-R16 michellin's
Old 10-01-2008, 11:49 PM
PapeCAT's Avatar
Suhweet!! makes me want to get a 4wd...
Old 10-02-2008, 01:38 AM
simplysmn's Avatar
Yeah I had the First crewcab longbed 4x4 in Calif I orignaly built it back in late 80's from 2x4 into 4x4 then when crazy from there I will have to pull up a couple pic's of it right after we rolled it it was amazing that we both walked away from it with minor scratches n no broken bones .
Old 10-02-2008, 02:40 AM
PapeCAT's Avatar
How'd you roll that one? Off roading?
Old 10-02-2008, 11:56 AM
simplysmn's Avatar
we rolled coming back from Nev last yr Jan 4th on hwy 88 from carson city to Calif 20 mph going around a corner in 4 lock hit 2 inches of ice and it was all over with from there I will dig a couple pic's out later today and post em you guy's will be Amazed we got out ok .to say the good Lord was watchin over us is a understatement . good thing was damage was small to running gear It broke the steering box and took 2 wheels out and the whole body buy the time Caltrans got done with it .
Val
Old 10-02-2008, 07:03 PM
minipete's Avatar
hay simplysmn, ive seen some of your front shock stepup pics. i was wondering how u had them connect on the bottom connected the the axle? got any pic of that or could yah explain? thanxz
Old 10-02-2008, 08:32 PM
simplysmn's Avatar
I have a pic of the top but the bottom was basicly a templet of the bottom bracket on axle just made longer to attach the shock's and not hit eachother .A buddy of mine did the fab work when we built em he was Awesome .
Old 10-03-2008, 12:04 AM
simplysmn's Avatar
Here is a pic of the top mount the bottom like I said was just cut to fit the end of the bottom mount then welded on to it the ground smooth Hope this help's some
Val
Old 10-06-2008, 12:12 AM
kellypckp's Avatar
simplysmn This is part of the blue truck that I bought from you years ago. You delived to me in Pahrump. It is coming together slow but together.
Kris
Old 10-06-2008, 12:49 AM
simplysmn's Avatar
Hey Kris kool glad it gettin finished man I am startin a new project also soon going to build another crewcab shortbed this time but not as high as my last 1 knee's can't handle it any more .
Old 11-15-2008, 07:27 PM
kellypckp's Avatar
Getting closer
It is painted and get closer. Still need interior and wire completed.
Quick Reply: Crew Pictures
