Go Back   Dodge Diesel - Diesel Truck Resource Forums > 3rd Generation Ram - Years 2003 and up > 3rd Gen Engine and Drivetrain -> 2003-2007
Register Forgot Password?
Search
submit to reddit
Thread Tools Search this Thread Display Modes
Old 06-09-2012, 02:10 PM   #1
fatpete
fatpete's Avatar
Crazy vibration at 40-45mph- help! My coffee keeps spilling
Strange vibration that began about two months ago. Gradually increases from 35 mph and gets worse until 45mph. When the trans (auto 48re) shifts around 40-45mph, it goes away.
I notice the vibration mostly in my cup holder as it starts to shake with the vibration, however it does vibrate the steering wheel and seat a little bit. I thought it may be that my tires are down to their last 20% on tread or that they're out of balance/alignment, but I would think that the vibration would increase with more speed and not go away when the trans shifts.
Anyone with any ideas or similar experiences? Thanks guys...
__________________
2006 Quad Cab 2500 4x4 Auto Big Horn 100k mi
Nitto 285/75/17s, 2009 Four Wheel Camper
Parts replaced: Upgraded to 2008 steering (two tie rod ends warrantied),steering brace,Ball Joints,factory stereo died,leaky oil pan gasket,Seat Foam fail/replace,Batteries,Batt temp sensor failed,Recirc Door broke/upgrade,Idler pulley- failed,turn signal switch/arm failed, trans gov sensor/solenoid replace, Ujoints worn out,shocks to Bilstein, WWfluid sensor died, leaky heater hose-upgraded.
fatpete is offline   Reply With Quote
Old 06-09-2012, 02:21 PM   #2
hot_runner58
hot_runner58's Avatar
May sound weird, but I would check your u-joints. They may seem tight, but look them over really good. My truck does this when they are getting worn. I have replaced 3 sets of these, same symptoms every time. If they pass, I just changed my front end components, bearings and ball joints. I still have a little play. Also look at the top pinned thread on the main paig of this particular forum for death wobble.
__________________
HOT_RUNNER58
_______________________________
-04.5 ram 2500 -Banks intake -Straight 4" exhaust -Turbo upgrade -19.5 tires and rims - built tranny -Air bags - custom bumper -welder and crane
-03 ram 3500 dually,custom straight pipe dual exhaust 4" under passenger door back, smarty jr., turbo from an 04.5, Banks intake w/ super scoop, air dogII rf100, phanton gauges,pacbrake,ramifier, Beefed up trans, 60hp inj.
-'96 gmc 3500< wishes it was a Dodge
hot_runner58 is offline   Reply With Quote
Old 06-09-2012, 03:22 PM   #3
fatpete
fatpete's Avatar
Thanks hot_runner58, will check the u-joints. I have 90k and have not replaced them. I did the front end swap, ball joints, etc too recently so I think that stuff is good.
Old 06-11-2012, 09:18 PM   #4
wellmax
when you feel the vibration, is it in the steering wheel or floor board(front tires)
or can you look in the rearview mirror and see the corner of the bed shaking? (rear tires)
could be something as simple as lose of a wheel weight off a tire.
if drive shaft is good then tires would be my next look see.
real pain in the butt when you have a shimmy at a certian speed.
If you have been on some rough roads you could have lost a big chunk of rubber off a tire. some of those tires with big lugs, the lugs can break off causing vibration.
let us know what you find causing the vibration.
wellmax is offline   Reply With Quote
Old 06-12-2012, 12:43 AM   #5
junebug95628
check if the vibration is consistant with rpm in different gears or constant speed in different gears. ujoints will be more speed specific, drive trane more rpm based. I just fought a similar vibration around same speed but found it to be rpm based as it would happen in 2 and 3rd. as soon as torque converter locked it would get real bad. also check to see if it happens worse under load or lightens when you let off throttle.
__________________
2006 2500 Megacab 4x4 SLT
De-badged
Silencer ring MIA
Custom air tube
BHAF
Smarty Sr. #9
Quadzilla Commander for gauges
Recently Upgraded to Goerand TC and VB
Failed Parts: 2 AC compressors, 2 Steering boxes, Transfer case, Torque Converter, u-joints and center bearing, drivers seat, e-brake handle, both pinion seals, rear axle seal...70k miles...
junebug95628 is offline   Reply With Quote
Old 06-12-2012, 08:04 AM   #6
fatpete
fatpete's Avatar
Thanks for all the suggestions guys. At this point, I can rule out wheel bearings and alignment issues. I will road test today and see if it is more speed or rpm specific. I also am going to crawl around underneath and look closely at Ujoint and center bearing. I'm hoping it's that an not something inside the trans...
Standby for update
btw Junebug- I'm going add my failed parts laundry list to my tag at the bottom too. Funny how so many of us have replaced the same crappy parts.
Old 06-19-2012, 08:31 PM   #7
novahauler
novahauler's Avatar
Did you figure this out yet? I have a 2nd gen with same symptoms, but mine is more noticeable at 35-40, and then is noticeable again at around 62-70.
__________________
2001 2500 4x4, Edge Juice With Attitude, 197K Miles, 4" SS Exhaust, 18.6 MPG Set on 3,5, Home made AN Big line kit from Fuel Filter to VP44, BHAF, 2.5" leveling kit, Falken Wild Peak A/T 285/75/16, Sport Light Conversion Hella 9004/9007 Off Road lights, 4 on low, 4 on high (8 filaments).
novahauler is online now   Reply With Quote
Old 06-19-2012, 11:34 PM   #8
JP-4.5
JP-4.5's Avatar
MAke sure to check front drivesahft.. I have seen user when this shaft goes bad and destroy transfer case.. Expensive problem for a $$ ujoint or CV joint to fail and destroy transfercase.....
__________________
2004.5 SRW 2500 Graphite 4x4 SLT CTD QCLB 48RE 3.73LS, Autometer guages, Nasta Stainless Steps, Nitto DuraGrappler, Flares, Renegade 892 17x9, Bilstein, Diamondback powdercoated black, TST R49, Smarty SSR/UDC, AirDog165, GDP 2 micron kit, 5" exhaust , Kilby tray/grill guard , Billet DTT , stock/S475, SolidAxle free-spin hubs
JP-4.5 is offline   Reply With Quote
Old 06-26-2012, 10:52 PM   #9
fatpete
fatpete's Avatar
Thanks for all the tips guys. Here is a follow up: felt the u-joints with the driveshaft on the rig- they felt fine. Looked closely at the Ujoint that goes into the pinion on the rear diff: rust dust and very dry looking. Pulled it off and felt it- TOAST. Took it in and had new ujoints pressed in- no more vibration or coffee spill. It is smooth as silk from 30-45 now. There is a very slight vibration at 65ish, but hardly noticable. Since it's easy, relatively cheap insurance, I'm going to pull the front driveshaft and have the Ujoints on it done too. Thanks again guys and if anyone else is experiencing this- go straight to the Ujoints. Later
Old 06-26-2012, 10:54 PM   #10
fatpete
fatpete's Avatar
submit to reddit
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.6
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
vB.Sponsors
Copyright 2011, DieselTruckResource.Com
Contacts Backup
