What the crap is wrong?
I thought it was just me,ive had my truck for a little over a year now(my first diesel)ive always felt it was underpowered from what everyone says about these trucks.if i pull away from a stop light,and get on it,it doesnt do much.....i was just out messin around with it and thought id do a big smokey burnout.well man was i not impressed.on level 5 it would NOT even turn the tires,i tried pumpin the brake to get em goin and nothin.SOMETHING aint right.can you guys help me,give me some ideas of things to look at or try?????
Stock lift pump? how many miles are on your truck? You mite not be getting enough fuel to fulfill the needs that level 5 is requesting. just my opinion. Could be a lift pump going bad. Does it start okay? Hows your transmission shifting?
Yes it is the stock pump,the truck has 76k miles on it,i even tried it on level 1 and wouldnt do anything!truck starts fine,i build transmissions for a living and i have been into this one and all is good there.....
Ok, well atleast your tranny is good haha. Well my 03 has the 555 cummins not the 600 cummins like your 05 so there is prob a difference in the Edge programs but you shuld still be able to burn the tires on any level. Your lift pump may not be making enough fuel pressure. Idk if there are any common problems on the 05's like the 03's or not. Is your truck down on power across the powerband or just whenever you try to burnout etc.?
It takes some work to get these tires broke loose. Try hitting your stall, then letting off a little to a roll, then getting on the brakes again. In my truck, I have to back off the brakes to get them to break loose.
Start it on some sand or something.
Do you have gauges? FP and RP, I mean. You may be starved for fuel.
Madhat will be more help than i am haha. Im pretty sure he knows alot more than i do. But i just know what ive learned from the trucks my buddies and i run around here and what all experiences we have had.
I dont think you have a boost leak then. The 600 series Cummins naturally dont get as good as milage as the 555 does in most cases. madhat has a point tho. Its not hard to drain your rail. You may want to check your Fuel pressure and Railpressure.
Where do you check that,and what do you need to do it.
I am in the process of checking my fuel pressure this weekend. From what ive learned this week You can buy a replacement fuelcanister cap with a pressure port form Genos Garage and they also sell a fuel pressure test kit. Im not sure about the rail. You would have to ask around. I havent run into that yet. madhat may know. sorry i cant be of more help with checking your pressures. My friend has everything to check my FP and RP so ill have to ask him.
