Go Back   Dodge Diesel - Diesel Truck Resource Forums > 1st and 2nd Generation Ram - Years 1989-2002 > 24 Valve Engine and Drivetrain
Register FAQ DTR Store Members List Mark Forums Read
Thread Tools Display Modes
Old 02-10-2009, 06:35 PM   #1
loudredram
Send a message via AIM to loudredram
cranks for a long time then starts
In the last few days after the truck has been sitting for more than a few hours it cranks for 15-30 seconds befor she fires. Fuel pressure is good turn key it primes then goes to 17psi while cranking. you can shut it off and it will start rite up
__________________
01 Quadcab shortbed 2500,2"leveling kit,MBRP 4" exhaust straight piped,S&B intake,TST comp, smarty,Isspro gauges.. ,jammer 3s,Bd super B turbo and a raptor pump...........I also have a "built trans" but cant tell you whats inside cause I dont know!...thanks Level 10
loudredram is offline   Reply With Quote
Old 02-10-2009, 06:38 PM   #2
McCanick08
It's a shot in the dark but are the cylinders taking a while to warm up? I don't know much about the subject but I'm actually rather curious about this myself <_< any answers?
McCanick08 is offline   Reply With Quote
Old 02-10-2009, 06:38 PM   #3
mishkaya
Quote:
If it's not a lift pump issue, it's usually a VP44 issue I hate to say. Do you have any codes?
mishkaya
__________________
'01 6spd, Mach 7's, Helix 2 cam & springs, twins, Adrenaline, DD clutch, DOR bumper, etc...
mishkaya is offline   Reply With Quote
Old 02-10-2009, 06:46 PM   #4
loudredram
havent checked any codes yet. But I was leaning twards a IP too cant complain with over 100k on a tapped pump
Old 02-10-2009, 07:31 PM   #5
loudredram
no codes but when the last IP went out I had no codes or CE light
Old 02-10-2009, 07:33 PM   #6
mishkaya
Doesn't surprise me much. Just about certain it's the VP though...
mishkaya
Old 02-11-2009, 07:43 AM   #7
Wild4kst8
Wild4kst8's Avatar
i had similar problem & turned out that i had changed my fuel filter & didn't get the cap tightened all the way... i was loosing prime overnight & had to crank a while to get it fired up
something to check
__________________
Rattlin 'n Gobblin
2006 DMax LLY 4x4 CCSB
SOLD! - 2001.5 2500 SLT QCSB 4x4 Silverline exhaust, cat MIA, silencing ring MIA, new relocated LP at 72k, fuel pressure gauge installed, home-made BHAF, Diablosport Power Puck, SMARTY, Alcoa Classic Series w/ Hankook RF10 285/70/17s
Wild4kst8 is offline   Reply With Quote
Old 02-11-2009, 09:18 PM   #8
rebal
rebal's Avatar
Send a message via Yahoo to rebal
with the cold weather it might be an air leak from ...filter or a line the cold could make a seal shrink
__________________
1990 W250 bought new in Nov. 89 performance built 727 and torque converter , high miler 700 k heavly bombed kelderman air ride
2001 2500 HO 6spd 4x4, Engine brake , mad.ecm mach1.6s fass,SBC 4" turbo back exhaust BHAF fluid damper,ARP head studs, DSS, Fast cools.snow w/m, wife says trucks fast enough:( 335 hp/800 tq)
How many of your rights are you willing to give up before you feel totally safe ?Wake Up People vote EVERYONE OF THE BUMS OUT OF OFFICE!
rebal is offline   Reply With Quote
Old 02-12-2009, 12:46 AM   #9
JoeCanuck
JoeCanuck's Avatar
The exact thing was happening to my unit. Turned out to be a very small leak from a loose injector line. It took me forever to find it. I couldn't see it leaking but I found it by touch.
The odd thing was that it was running fine, then one day, it started acting up...lots of cranking if it sat for anything more than 10 or 15 minutes. I hadn't been playing with the tubes at the time.
There was a faint odor of raw diesel, which had been hanging around under the hood for a while but I had attributed that to a leaky filter drain.
__________________
'00 Quad Cab Cummins 4x4, Adrenaline (impressive) w/ Pulse, Stg 1 Jammers, Raptor, Leer Tonneau, Dodge Steering Stabilizer, Luke's Link, Mikuni MX-40 coolant heater, BFG T/A's, Isspro FPG.
JoeCanuck is offline   Reply With Quote
Old 02-12-2009, 02:39 AM   #10
AlpineRAM
AlpineRAM's Avatar
I'd check at the long crank whether it emits white smoke or not. If there is white smoke, sniff to check whether it's diesel or normal exhaust.
I second the losing prime theory.
It can be the return line from the back of the head, and the fuel hoses that go up to the hardline to the filter too.
HTH
AlpineRAM
__________________
On Vacation at the beauty farm: 98.5 lb 2500 auto. 4wd, Smarty, DTT 89% TC, VB, Masterkit... 4"DPP aluminized ..Scotty 2 , Rods Pod .DonMs EDMs, ARP 12mm studs PIAA 530. DSS, some Luke's links, 3/8" fuel hose from inside the in-tank module to the Holley, 3/8" to the filter, Wildcat bigline kit
Clear lense aftermarket headlights, Bilstein BE5-2549& BE5-2550
The inofficial smarty update guide for download
Daily driver: 97 Toyota Carina E Turbodiesel 2.0 L 83 hp Station
AlpineRAM is offline   Reply With Quote
Old 02-12-2009, 11:11 PM   #11
cmckinney
I think JoeCanuck and Wild4 are on the trail of your issue.
Had the same issue but it was after 4hrs that it would hard start. My issue was an injector had backed out of it's seat and let air in the system.
Good luck.
__________________
2002 CTD ETC Ext 4x4 5-sp, IssPro boost, Fuel pressure &amp; Pyro Pre-Turbo
PIAA 80XT's, Warn HS 9500I,
Cooper Dominator's 285/75R16 4/24/06 96589mi
Nitto Terra Grapplers 285/75R16 2/27/09 131887mi
Edge EZ, BHAF
Dynoed 256 HP 556 TQ EDGE EZ
Dynoed @300HP 600TQ EDGE EZ + RV275's
Edge Pulse Level 3 TST Grabber HP=?? TQ=??
Replaced ball joints w/ Moog @72300.
Warrantied VP44 Injection pump 86000 7/05
125K+ mile club July 08
cmckinney is offline   Reply With Quote
Old 02-12-2009, 11:19 PM   #12
nickg
nickg's Avatar
another thing to check for is heavy tank vacuum, loosen the cap once you shut the truck off, if it starts right up 3-4hrs later, the vacuum is sucking the fuel from the IP back to the tank. usually made worse by a leaky fuel line
__________________
Nick
2001, 2500 Edge J/A Hot unlocked,Magna flow exhaust. HX35 Jammer II's. BHAF, Airdog 150,DSS,3rd gen Track Bar. Carli Suspension, 3rd gen Brake upgrade, transgo Shift Kit. Firestone AirBags May 07 297,000kms Dec/09 473,000kms RETIRED Military Mechanic (20yrs)
nickg is offline   Reply With Quote
Old 02-13-2009, 09:04 PM   #13
loudredram
its getting worse now its doing it all the time....one thing i did get to check today is there is no white smoke while cranking........also I dont know if this makesa differencebutmy tst stopped fueling it works just wont fuel anymore
Old 02-17-2009, 03:38 PM   #14
5Oclock
My truck is doing a similar thing. Sometimes it fires up immediately. Other times it cranks several times and fires while other times I have to crank the heck out of it. There is no pattern for hot, cold or time between starts. Once running it runs as it always has which is good. No codes, no smoke. Both the VP and IP only have 30K miles on them.
__________________
2001 RAM 2500 4X4 Auto, 3.54 gears, 305-70r16 tires, Edge EZ, 4" exhaust, boost & pyro gauges, BD VB/TC, Exhaust Brake.
5Oclock is offline   Reply With Quote
Old 02-19-2009, 01:06 PM   #15
loudredram
OK..... still tring to figure this out smell fuel cant find leaks also park truck nose down fires right up, park truck nose up cranks for ever then starts..... no smoke while cranking
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.6.7
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
vB.Sponsors
Copyright 2003, DieselTruckResource.Com
