Go Back   Dodge Diesel - Diesel Truck Resource Forums > 1st and 2nd Generation Ram - Years 1989-2002 > 1st Gen. Ram - All Topics
Register Forgot Password?
Search
submit to reddit
Thread Tools Search this Thread Display Modes
Old 08-14-2006, 11:32 AM   #1
JimmieD
Cracked flywheel!?
Hi guys,
Doing an engine swap: 4BT into '60's Dodge. It's a mix/match of parts to make it work. Got a 98W-350 Diesel flywheel from a Atlas Auto Wreckers, in Hubbard, Oregon and it's got 2 cracks in it. Don't know if that's normal or what, but it doesn't look too good. Seen it in gassr flywheels and no big deal.
One's about 1 1/2" long and starts at inner edge of friction surface, the other about 3/4" long at outer edge of friction surface. The short one has another small crack beside it. Located [as if you divided up flywheel into 4 segments] at 9 o'clock and the other at 12 o'clock. What do you think? Useable? Haven't called the wreckers back yet and return shipping would be expen$ive. Not real happy here......
JimmieD is offline   Reply With Quote
Old 08-14-2006, 11:41 AM   #2
signature600
signature600's Avatar
Are they heat cracks, or actual cracks that go clear through??
Chris
__________________
2010 Ram 3500
CCLB SRW Loaded
Deep Water Blue
Stock....for a while...
signature600 is offline   Reply With Quote
Old 08-14-2006, 11:49 AM   #3
JimmieD
I'd say heat cracks on surface. Can't Magnaflux to be sure. Found a 3rd one at 3 o'clock.
Old 08-14-2006, 11:55 AM   #4
jrussell
jrussell's Avatar
Quote:
I know nothing of flywheels, so can't help you there. If you find it's not useable though, you shouldn't have to pay for return shipping. I would think a digital cam and some pics should be enough for the place to send you a new one or give you a refund. It should have been checked before being shipped and most reputable companies would either offer a refund or send out a new one for no charge.
jrussell is offline   Reply With Quote
Old 08-14-2006, 12:00 PM   #5
JimmieD
Quote:
Yea, I'm more than a little upset about this! Every place I checked on clutches that mentions resurfacing flywheels says: NO CRACKS! Great. Like I say I haven't called them on it yet, just noticed this morning.
Old 08-14-2006, 02:13 PM   #6
flashgordon
flashgordon's Avatar
The best person to answer question would be a shop that turns flywheel!
thay now how far thay can cut a flywheel, before it is junk and and have seen enuff of them to give you a good visual gess!
put up some pic and will all give you are apinion but you now what thay say about apinions...........
with out seeing it and form what you have said........i'd say turn it!!
I have seen some vary deep appering crack that didn't take much to turn out!
__________________
91.0 non intercooled 3/4 ton 5sd ex.straight piped HX35, timing bumped 1/16...Pump mods have started Full power screw1/2 max with out removing the collar. Gear Vendor over drive!
Finally finished 2nt gen intercooler turbo and Coolertubz, By Tim (TWorline)" write-up here:http://www.dieseltruckresource.com/d...d.php?t=186908
flashgordon is offline   Reply With Quote
Old 08-14-2006, 10:56 PM   #7
JimmieD
Well, I think I really blew it here, guys! I blabbed away here before engaging my brain. From the sounds of my post I got a bad deal from Atlas Auto Wreckers.
NOT SO!!! I called Phil the owner this morning after I had posted, WHICH IS WHAT I SHOULD HAVE DONE BEFORE I POSTED. He had no problem with exchanging it and was entirely friendly and reasonable about it. Mistakes happen and this just happened to be one of them. He has another Cummins truck coming in tomorrow but doesn't know if it's manual or auto and is going to call me.
So things are looking up. I'll let y'all know what finally comes down......thanks for advice!
Jimmied
submit to reddit
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.6
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
vB.Sponsors
Copyright 2011, DieselTruckResource.Com
Contacts Backup
