Go Back   Dodge Diesel - Diesel Truck Resource Forums > 3rd Generation Ram - Years 2003 and up > 3rd Gen High Performance and Accessories (5.9L Only)
Register Forgot Password?
Search
submit to reddit
Thread Tools Search this Thread Display Modes
Old 02-06-2008, 12:47 AM   #1
Kman9090
Kman9090's Avatar
Cp3 upgrade?
All right when I rebuilt my motor Don M said I had a bad tank of fuel so I took the orginal Cp3 off my truck and put on a different one. In meantime that Cp3 has been sitting around. I want to get a modified pump but can't have my truck down for that long. So I was wondering just because the Cp3 had a bad tank of fuel run through it if John or Darkside rebuilt it would it be ok to run after he did a stage 2 on it?
__________________
""Chain Reaction" 2005 Patriot Blue Dodge Cummins
Edge Juice
Edge EZ
Smarty Revo/R
F1 Flux 2's
F1 Sporstman Springs
Scheid Street Cam
Fly Cut Pistons
Arp Studs
AirDog fuel system
Afe Intake
SPS 66
Ipricol gauges with Quad RP gauge
Haisley Steet Puller clutch
Floor it Stage 3 Cp3 on the way!
(Ad removed signature violation)
Kman9090 is offline   Reply With Quote
Old 02-06-2008, 01:30 AM   #2
WUnderwood
WUnderwood's Avatar
I think Floor it or Darkside will fix/replace anything that needs it inside the pump, so i wouldnt worry about that bad fuel that was run through it before, just my opinion
__________________
2004.5 2500 QC Laramie 4x4 auto
1998 2500 QC 12V NV4500
1994 2500 12v Laramie auto
WUnderwood is offline   Reply With Quote
Old 02-06-2008, 01:50 AM   #3
Kman9090
Kman9090's Avatar
all right thats good, anybody else have any oponions. John maybe you can chime in?
Old 02-06-2008, 07:00 AM   #4
revolution_dsl
revolution_dsl's Avatar
depends on whats wrong with the pump
or i guess i should say where in the pump its wrong.
__________________
'00 2500 QC SB - Some Custom Fuel Stuff
'03 3500 CC SB - Custom Paint, All Billet HTS, SB66, DDW Stage 4, RevD Custom Injectors, Other Stuff...
revolution_dsl is offline   Reply With Quote
Old 02-06-2008, 07:01 AM   #5
revolution_dsl
have you had your injectors checked since the bad tank?
Old 02-06-2008, 07:37 AM   #6
haloman
haloman's Avatar
How bout using that one in dual setup after you get it rebuilt?
__________________
Daniel
01.5 2500 CTD 2wd 6spd QC/SB Green SLT
haloman is offline   Reply With Quote
Old 02-06-2008, 02:51 PM   #7
Kman9090
Kman9090's Avatar
Yeah The injectors weren't in when the cp3 was bad. The bad tank a fuel took my injectors out and my motor.
Old 02-06-2008, 04:41 PM   #8
mopardamo
mopardamo's Avatar
Hello,
WOW. You are too close to me. Where did you get such a bad tank of fuel?
Damon
__________________
2006 Flame Red 4x4 2500 Big Horn, 3.73 Gear, 48RE, Goerand VB, Mag-Hytec all around, Quad RP & FP, Line-X, Smarty Jr, PSC Stabilizer, 5 SKS holes done with armor piercing bullets 14.72 at 92 mph in Quarter
mopardamo is offline   Reply With Quote
Old 02-06-2008, 04:45 PM   #9
Kman9090
Kman9090's Avatar
I can only narrow it down to two locations. One is either Mobil Off Hwy N and Z in Wentzville or Shell at the Wright City exit.
Old 02-06-2008, 10:32 PM   #10
mopardamo
mopardamo's Avatar
Thanks Kman9090
Were you on the pedal a bit to cause that much damage with bad fuel? What is the circumstances you believe that contributed to the failures.
Thanks again
Damon
Old 02-07-2008, 03:47 AM   #11
Kman9090
Kman9090's Avatar
Yeah I was deep into the pedal when it let loose. Had no idea I had gotten a bad tank of fuel til it was to late.
submit to reddit
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.6
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
vB.Sponsors
Copyright 2011, DieselTruckResource.Com
Contacts Backup
