Thread Tools | Search this Thread | Display Modes |
#1 | ||
Counterfit Fleetguard oil filters?
#2 |
counterfit fleetguard oil filters UPDATE
I did not have the mfg and date code when I called Cummins yesterday. Today I was assured that they are genuine and under 6 months old. They said that when a line shuts down here, the Indian plant will make some for the USA. I am still wondering if any of you have gotten ones from India. I also learned they consider ones over 3 yr. old to be condemned or at least don't advise using them.
#3 |
Good info on the use by date. Never heard that before. Wonder why it is?
__________________
01' 2500 CTD w/ 6 speed, Edge EZ, Boost Elbow, Gauges & Jacobs Exhaust Brake |
#4 |
Interesting info on the date. I'll have to check my filters. I bought quite a few at one point direct from Cummins with a discount so that me and some friends had a stash of filters to use. But considering I only change oil twice a year, I don't go through my supply very quickly.
__________________
Maroon 2001 2500 QC 4x4 SB 3.55 6-speed 285/70R17 Nitto Terra Grapplers on 3rd gen rims, Smarty, KSB1-1, Mach 4s, Raptor 100, Amsoil EaAU4091 |
#5 |
When I asked about the life of filters I was told the rubber seal even under perfect temp and humidity can fail after 3 yr. And we keep that stuff in the hot/cold garage or shop. Honest distributors return them for destruction before that date and strive to keep from overstocking to keep them fresh I was told. The date code is Julian, mine was 11355 meaning 2011 355th day of year.
Still wondering if you guys have gotten any from India |
#6 |
I switched to Baldwin a while back. They are as good, cheaper and red!!
__________________
Kurt 2001.5 2500 QC LB 4WD H.O. 6-SPD SLT Plus 3.54's, Camper/Tow/Plow, A.R.E. Canopy w/ SS Vanguard rack, Southbend clutch and hyd.,TIMBO APPS, BHAF/Heatshield, MBRP 4" TBE, FP Gauge, Femco E-Z Drainplug, DSS, Thuren Trac Bar, 2" leveling kit, P/H Tow Mirrors, PBR, 128K miles. FASS LP "When I was younger I could remember anything, whether it happened or not." Mark Twain Support Our Troops! NRA, MSBL, BYO, GSP, BOLTS, Southpaw, CDC* *Cracked Dash Club |
#7 | |
Quote:
I'll have to check my spares when I get home from work to see where they were made. The stuff about the rubber seal failing after 3 years even under perfect conditions sounds like BS to me, but I could be wrong.
__________________
2000 2500 QC, Mach 1s, FASS 150, South Bend Con FE, PDR HX-35/40 Hybrid, Edge Comp, Smarty, Timbrens up front, GCF-O1 bypass filter, Motorguard coolant filter |
| Display Modes | |
