Go Back   Dodge Diesel - Diesel Truck Resource Forums > 3rd Generation Ram - Years 2003 and up > 3rd Gen Engine and Drivetrain -> 2007 and up
Register Forgot Password?
Search
submit to reddit
Thread Tools Search this Thread Display Modes
Old 05-27-2012, 02:23 PM   #1
k9prtnr
k9prtnr's Avatar
Code P0335 &P0336 CrankShaft Position Sensor
Engine light and Electronic Throttle Control light both are on. Went to the Parts store and the following codes showed up:
P0335 - Crankshaft Position Sensor A Circuit Malfunction
P0336 Crankshaft Position Sensor A Ckt Range Perf.
So the Autozone guy told me that I need to replace the Sensor, $32.00 for the sensor. He also said that might be a warranty issue on the motor. Looks like it would be an easy part to put in... One problem, where is this sensor located?
Can anyone tell me if this sounds right and is it a easy swap out? What help manual would show me the location of the sensor.
Any help would be great... Thank you in advance
__________________
Jeff
2007.5 Silver 2500 4x4 Laramie Mega 6.7... No MODs
k9prtnr is offline   Reply With Quote
Old 05-27-2012, 02:37 PM   #2
06RAM2500
06RAM2500's Avatar
It's mounted right above the harmonic balancer. Crawl underneath the front of the truck, it'll be on your left, can't miss it.
__________________
06 QCSB SLT: It's Sort Of Stock
The weather was dominated by a large Canadian low. Which is not to be confused by a Mexican high.
November T.O.M Winner
06RAM2500 is offline   Reply With Quote
Old 06-03-2012, 09:16 AM   #3
alboy
I went thru that whole scenerio,turned out to be a cracked connection on the wire loom that runs under the oil filter,there are some old threads on here re the cam sensor mis diagnosis, hope you got it fixed.
__________________
06 5.9 3500 QC 4X4 Larmie 48re 305 55 20 toyo, AR wheels airaid,magnaflow,edge/attitude.
alboy is offline   Reply With Quote
submit to reddit
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.6
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
vB.Sponsors
Copyright 2011, DieselTruckResource.Com
Contacts Backup
