Thread Tools | Search this Thread | Display Modes |
#1 | ||
Code Definition
__________________
02, 2500, QCLB, 4x4, Auto, 3.55 Power-Lok LSD - DTT/Billet - Smarty- Mach 4's - BD Twins - O-Ring/Studs -Snow's H2O/Meth - FASS - F-1 Cam/Valve Springs - HTT Manifold - Road Armored - 5" pipe - TC Lockup Switch - 3rd Gen Brakes, Wheels & Trackbar - Fluidampr - DSS - 33" Pro Comp Xtreme A/T's |
#2 |
try this....
__________________
Ricktrad@dieseltruckresource.com________________________________________ 04.5 3500 Dually, Regular cab, 6 Spd/3.73's, Just black with a little chrome, TAG, Centramatics, B&W Turnover Ball, Brakesmart, Line-X, Weatherguard Box, UWA 100 Gal. transfer tank, Dodge heavy duty mud flaps Sheeple (a portmanteau of "sheep" and "people") is a term of disparagement in which people are likened to sheep, a herd animal. The term is used to describe those who voluntarily acquiesce to a suggestion without critical analysis or research. They undermine their own individuality and may willingly give up their rights. |
#3 |
Thanks... but that list is incomplete.
P1765 ? P1693 .... Companion code if I remember correctly? RJ |
#4 |
You got me. The Wiki list is better than the one I have saved.
#5 |
P1765 Transmission 12 volt supply relay control circuit
__________________
2005 Patriot Blue 2500 CTD--QC--4x4--Auto--Off-road pkg Silencer ring MIA S&B CAI TS shift enhancer Rokktech crank sensor Custom intake manifold 5 inch TBE w/ FTE resonator / 5 inch turn down tip Smarty Jr. Isspro boost, EGT, Trans temp gauges Prodigy P3 :D 1990 Honda accord 2dr 240k miles When going through customs and are asked "Do You have firearms with you?" do not answer "What do you need" SAC member #333 |
#6 |
Thanks guys
| Display Modes | |
