Go Back   Dodge Diesel - Diesel Truck Resource Forums > 1st and 2nd Generation Ram - Years 1989-2002 > 12 Valve Engine and Drivetrain
Register Forgot Password?
Search
submit to reddit
Thread Tools Search this Thread Display Modes
Old 10-09-2002, 10:10 PM   #1
yz
clutches
Hey guys I was wondering you what you guys thought of the south bend con o clutch vs. dial a clutch. Dial a clutch seems to be a lot cheaper then south bend but which is better in your minds. thanks -Anthony
yz is offline   Reply With Quote
Old 10-09-2002, 10:16 PM   #2
dodgeman01
dodgeman01's Avatar
Re:clutches
all I know is that is you are over 350hp a centerforce gives up. It will hole 330hp for a long time and never slip.<br>my 0.02
__________________
Aaron
[color=blue
94 Dodge Cummins Diesel forest green 4x4 reg. cab (2002) 5spd 215 pumped set at 30* 5x16 edm injectors ported,polished, and O-ringed head with custom valves and springs snow water meth kit
put to the ground by SBC DD clutch[/color] twins soon
04 auto commonrail (stock)01 p-pumped 24v 6spd 98 dodge CTD 93 dodge ctd 95 dodge gasser
Its a Horse power thing Ford owners wouldn't understaind
Thanks Peter of South Bend Clutch for the new tranny clutch and help
dodgeman01 is offline   Reply With Quote
Old 10-10-2002, 09:58 AM   #3
Bob Beauchaine
Re:clutches
I am running a SB Clutch and I'M very happy with it. The 1st Gen's had a noticeable launch shudder problem. Since I put my SBC in I have not had a single launch shudder. You may beat SB's prices but you can't top their customer service. Some of the things I've seen Peter do redefine customer service. In the long run if you have a problem you will see what I mean. <br>Bob
__________________
1993 CTD 4X2 Horton fan, Green HP Air Filter with custom AF mount, 14cm2, PDR HX35 turbo, ATS exh. manifold, 15%+ pump with DennyT Stage II Pin 3200 GSK, DD3+ injectors, BD exhaust brake, 4 in Rip Rook exhaust, NV4500HD trans SB clutch and gauges. 394/888 #2 - 441/889 W/M.
Bob Beauchaine is offline   Reply With Quote
Old 10-10-2002, 11:10 AM   #4
PourinDiesel
PourinDiesel's Avatar
Re:clutches
You get what you pay for.<br><br>SBC all the way.<br><br>--Justin
__________________
123456
SMARTY POWERED!!
PourinDiesel is offline   Reply With Quote
Old 10-10-2002, 05:13 PM   #5
Doubleclutch
Re:clutches
From a Newbie on this board, you can't go wrong with SB. Peter is a square shooter and stands behind his product!
__________________
1996 &quot215&quot hp standard cab, 3:54, 5spd.
Doubleclutch is offline   Reply With Quote
Old 10-10-2002, 08:21 PM   #6
gitchesum
Re:clutches
Someone else said it. You get when you pay for.
Just ask Dial-a Clutch if their clutch with get a 1 ton dually to chirp the tires in 4th gear at 35 mph.
THe Con OFE is an awesome clutch. It's help just about everything I've thrown at it. And it shifts and feels smoother than the stock clutch.
SBC all the way.
__________________
2004 Ram 2500 Quad Cab, Short Bed, 48RE auto tranny.
Mods: none.................................yet!
gitchesum is offline   Reply With Quote
Old 10-10-2002, 09:07 PM   #7
yz
Re:clutches
Wow ok. Then it's SBC. Thanks -Anthony
Old 10-11-2002, 10:23 AM   #8
dodgeman01
dodgeman01's Avatar
Re:clutches
what about pulling a sled. Will a SB clutch hold up. I have heard that they will do the same thing as my centerfoce. They get a glaze on the clutch material and will never hold that same again. Just something I have heard. What is a good pulling clutch to use. I'm looking at a dual disc clutch from Enterprise engin performance. I have heard that they are the best.
Old 10-11-2002, 11:37 PM   #9
gitchesum
Re:clutches
Peter had developed a pulling clutch from what I understand.<br>In interest of safety, I don't think he'll sell one unless you have a scatter shield or tranny blanket. <br><br>Can't really blame the guy for that.
Old 10-12-2002, 07:49 AM   #10
PourinDiesel
Re:clutches
SBC is a great clutch for trailer pulling and racing!<br><br>But for Sled Pulling, Yes the Dave Mitchell (Enterprise Engine)<br>Pulling clutches are awesome!<br><br>Both of these clutches are totally different animals for their purposes.<br><br>--Justin
Old 10-13-2002, 07:19 PM   #11
Don M
DTR Advertiser
Don M's Avatar
Re:clutches
So far the Mitchel pulling clutch is the top dog in the pulling arena. I dont have much data on the clutch, but the peformamce of it so far is top notch.
The Southbend clutchs are the best dern street clutchs I have ever driven, but have a HP limit of about 550.
Joes modified Sachs is by far the only clutch that can hold 600 plus HP with ease and still have a sprung hub to keep vibration and harmonics down. It drives kind rough and is not for everyone, but will hold the power, street or dyno. I dont mind the way it drives but some of the guys like smooth as silk engagement with a light pedal.
Joes clutch is not for sled pulling either. The facing just wont allow it to be slipped long enough to get the weight moving.
I have been working with Joe on a modifed version of the Sachs that can be slipped, but it still is not a primary pulling clutch like the Mitchell dual disk is.
Don~
__________________
The real destroyer of the liberties of the people is he who spreads among them bounties, donations and benefits.
Don M is offline   Reply With Quote
Old 10-13-2002, 07:46 PM   #12
Promoter
Re:clutches
Mitchell's clutch is good,but it's definately not the top dog. Haisley Machine's comp clutch is as good or better.
Promoter is offline   Reply With Quote
Old 10-13-2002, 07:53 PM   #13
Don M
DTR Advertiser
Don M's Avatar
Re:clutches
Ya know Chad, I would not deny that Van and Patty do build some great products. I just have never heard of the Haisley pulling clutch. As far as I know there may be ten other good pulling clutchs out there.
I have few ideas on clutchs too, but have not implemented any yet.
Don~
edit- I wanted to add, I like the JVD box that Haisley is using for the 24 valve engines. I really like the ability to have them (JVD) custom program the parameters to what you want.
Old 10-13-2002, 08:12 PM   #14
Promoter
Re:clutches
Who you callin Chad??<br><br><br>Haisley's clutches are very popular. Alot of hot pullers run Van's comp clutch including Kent Crowder,Don Quaethem,Ed West,Wade Wright and myself. That's just a few.<br><br><br>
Old 10-13-2002, 09:03 PM   #15
Don M
DTR Advertiser
Don M's Avatar
Re:clutches
I thought you were Chad, sorry for the confusion ???<br><br>As far as the Haisley clutch and tractor pulling all around-I know enough about both to get me into trouble. Im sure Van can build or design a good one though. I actually want to get one those 1 3/8 input shafts made up from him for my 5- speed.<br><br>Don~<br><br>
submit to reddit
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.6
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
vB.Sponsors
Copyright 2011, DieselTruckResource.Com
Contacts Backup
