#1 |
CLUNK,CLUNK,CLUNK can anybody else hear that CLUNK?
I guess dodge could hear it to.
![]() Front and/or rear shock absorber noise. The customer may experience a clunking-like sound when traveling over small inputs (bumps and dips) in the road. This clunk-like sound is sometimes described as being similar to the sound that “loose lumber” may make when loose boards strike each other. This condition is more noticeable during cold ambient conditions below 40°F and at lower vehicle speeds when background noise is less. The sound may come from the front and/or rear shock absorbers. This condition is due to internal components within the vehicle shock absorber and the bulletin describes the replacement procedure. 4500/5500 only TSB# 02-003-08 This drives me nuts, finally dodge released a TSB, I can't wait to go to the dealer.
__________________
2006 CTD LARAMIE - 467HP - 12.97 @ 101.68MPH SMARTY REVO TNT - Autometer Phanton II Gauges - AFE Stage 2 - FASS 150/150 - Quadzilla RP/FP - CFM+ - MBRP 4" - Full Billet DTT Transmission - 2008 Ram 5500 4X4 - 12 Foot Deck - Edge Insight 2008 Ram 4500 2WD DTR SAC #25 Are You A Diesel Head? Click here to Find Out! |
#2 |
Thanks for the info mine just started doing it at 4k miles with the onset of the colder temps..
__________________
08-Sterling Bullet 5500 4x4 6.7 Cummins,188.5,Quad Cab,White,Custom Built Flat-Bed,6sp Aisan,4.88's ,P-3,PTO/Snow Plow Prep. 05-3500 4X4.5.9, Jake Brake, Imp. Blue.Big Horn, Long Box Quad Cab, G56 SRW.3.73 LS.Custom Built Bed Rack/Weatherguard Tool Chest.Line-X OTRBL B&W T.O.B.,P-3 W/Valley "V30137" In Bed Harness. 01-Cat/EP 4x4 Forklift, 4.2L Perkins 32' 16.5K GN 42' 24K GN-el/hyd disc brakes |
#3 |
I hear that clunk as well, not in a truck but in the American auto industry.
#4 |
Well, at least I can stop looking for that loose lumber in the bed of the '05 now...
__________________
"Miss Sled" Silver 2005 5500 Quad SLT G56 4WD LB... too many mods to list - designed, built, installed at shop. "Cheap Hooker" Chestnut Pearl 1998 2500 Quad SLT 49RE 4WD LB twin turbo... same as above "XLR8R" RED 1965 GTO Ram Air 400, M-21, 3:90 Posi, Tripower, Nitrous... ditto Gun-Happy |
#5 |
a TSB means the dealer will look at it?
__________________
92 W250 16cm. housing fp/boost/pyro, 3200gsk, DennyT stg II, pump tweaks, K&N, custom bumper 01 c&c 3500 4x4 stock w/deck 08 c&c 5500 4x4 dpf & egr fell off, $2.99 fooler box, Alum.tool boxes, Heila 5500 picker, custom deck |
#6 |
TSB means that it is a common problem and is telling the techs what to look for and how to fix the problem. However it is not a recall by any means. You can take a copy of the TSB in and have them check it. I have done that before.
__________________
08 5500 4x4 quad cab G56 4.44s SB 3250 dual disc, XRT, and aux trans. 95 2500 G56 w CON OFE 4X4 3.55's, 913 pump, 100 plate ff, 3 GSK, 16.5* timing, DDP stage 2 injectors, HE351. |
#7 |
^^^Basically what he said, if your vehicle has this problem you print it out and give it to them and they do the work to resolve it. It fixes a oops in the vehicle design without the mass(expensive) scale of a recall.
#8 |
My 2004 3500 has this same sound....but you say it is only for 4500/5500
__________________
2004.5 3500 Laramie ************************ Edge Juice with Attitude Raptor 100 AFE Stage 2 Pro Dry Muffler delete Silencer ring removed |
#9 |
Bumped for Joe
| Thread Tools | |
| Display Modes | |
