Clearance Light Gaskets
Old 07-26-2014, 10:28 AM
Clampett's Avatar
I've searched the forum but can't find any info on where to buy the clearance light gaskets. Mine leak like crazy. I know LMC sells a clearance light kit but the lights have different screw locations than the factory ones. I'm thinking the gasket may be a different size/shape. I'm sure some of ya'll have replaced them. Where can I find those gaskets? It literally rains inside my truck when I get caught in bad weather.
Old 07-26-2014, 11:39 AM
Received 1,331 Likes on 862 Posts
To my knowledge they are not available from Ma' Mopar anymore, nor are they reproduced.
Old 07-26-2014, 12:16 PM
Clifford93's Avatar
I'm also pretty sure they are no longer available. Best bet is to purchase gasket material and, using one of your old gaskets as a template, make new ones.
Old 07-26-2014, 12:20 PM
1st Generation Admin
BC847's Avatar
Stop by your local roofing company, and see if they'll give you some scrap EPDM rubber roofing material. Cut to shape with common scissors. Should work like a champ.
Old 07-26-2014, 12:28 PM
Clampett's Avatar
Thanks fellas. Mopar PN 3738019. No longer available.
Old 07-26-2014, 06:42 PM
I just sent an E-mail to the LMC people asking if they would consider reproducing these gaskets.
Old 07-27-2014, 11:51 AM
NE frmhnd's Avatar
I have a friend who would probably cut them out of a cereal box, and coat them with permatex.
Old 07-28-2014, 09:16 AM
james1's Avatar
Hella used to manufacture chrome clearance lights for our trucks that look far better than the OEM units. They were Hella part #79726 but are now discontinued. However, if you can source a set somewhere, they do come with gaskets.
Old 07-28-2014, 12:55 PM
Received a response to my e-mail.....
Dear Sir,
Thank you for your interest in LMC Truck. We appreciate your suggest and have sent it to the appropriate department.
If you have any questions please do not hesitate to contact us.
Best regards,
Who knows?
Old 07-28-2014, 02:56 PM
mknittle's Avatar
Who knows?
maybe if they get enough requests.
Old 08-04-2014, 09:31 AM
Clampett's Avatar
The gaskets that come with their light kits may work. I know the lenses mount different though which makes me think the gaskets would be different also.
Old 08-04-2014, 10:02 AM
I bought a sheet of Neoprene foam gasket material that I can use to make new gaskets if desired.
Just like this stuff....It's 1/8 (.125") thick. Used it for a few things...works very well.
http://www.ebay.com/itm/Gasket-Sheet...item2c77982a96
I would prefer to have nice clean cut replacements already available.
gatorfan
05-17-2008 12:01 PM
mjsandt
06-13-2006 05:55 PM
rjm022
04-23-2006 09:44 PM
Mcmopar
26
10-29-2005 10:29 AM
Journier
02-27-2005 10:34 PM
Quick Reply: Clearance Light Gaskets
