Thread Tools | Search this Thread | Display Modes |
#1 | ||
Chevy Rear in a 1st Gen?
__________________
-2005 2500, 5600, 4wd shortbed 205k oilfield truck |
#2 |
Yes they will fit I believe you have to move the pad's but my last truck worked Great had a corp 14rear and a dana 60 front with 410's and 39 in tall tires on a 85 crewcab
__________________
2008 2500 Sold / 2011 3500 Sold 1985 crewcab w350 4x4cummin's swap wifes hotrod 2012 Jetta sport wagen TDI it's a little Rocket lost but not forgotten 1967 vw speedy the bug died a hot death on 5-17-10 12 noon Ashes to ashes, dust to dust, if it wasn't for fords..... my tools would rust! FORD Ford Owner's Recommend Dodge :) |
#3 |
yeap and the 14 bolt is a strong axle!! It will hold up behind the cummins no prob..
__________________
2012 3500 CCLB SRW G56 4x4 1973 Ford Courier Crawler |
#4 |
I have a 90 Chevy SRW crew cab w/ a 14FF, the spring pads are closer together vs a firstgen Dodge, the Chevy framerails are closer together. I think 87 and older 3/4 ton Chevys have different spring pad/framerail spacing, I think they're further apart, not to mention they put the 14FF in many different apps, probably a few different spring perch and overall widths. I know my Chevy has smaller u joints vs the Dodge too, different yokes for the 14FF are probably available. If I end up repowering my Chevy, I'm probably going to put a D70 in there, because I can't find 3.54 gears for a 14FF and the Dana Power Lok posi units are supposedly a lot better than Gov locks.
__________________
91.5 W250 5 sp 92 W250 CC 5 sp 96 2500 CC 5 sp 4x4 215 hp, BHAF, 4" straight pipe exhaust, 285/75-16 BFG All Terrains. |
| Display Modes | |
