Check out chickenfarmer's Dodge!
Old 10-24-2014, 05:51 AM
MARF75's Avatar
Looks like a good start. have fun and save some cash, your gonna need it.
Where ya at in MICHIGAN? I'm 20 miles out of Ann Arbor
Old 10-24-2014, 08:11 PM
chickenfarmer's Avatar
I'm around the holland area out here by the lake.
But anyways, I attempted to replace my fuel filter tonight and ended up with fuel pouring out. The fuel heater wasn't plugged in anyway so I'm thinking tomorrow I'll see about finding one of those close nipples to delete the fuel heater. Does anybody know if napa has a part number for that? Thanks for your help!
Old 10-24-2014, 09:40 PM
mknittle's Avatar
I have my doubts about NAPA.But that could be a local thing.
Genos has them.
http://www.genosgarage.com/FUEL-PRE-.../#.VEsM8GfQM5s
Old 10-24-2014, 11:37 PM
MrFusion's Avatar
Decent looking truck man. Welcome to DTR! Ditching fusible links is pretty high on my list too.
Old 10-26-2014, 03:23 PM
j_martin's Avatar
I'm going with relay mods on the lights and heater to take some load off the links. Also helps the longevity of other weak parts, mostly switches and connectors.
As I was studying the wiring diagram for the clearance light mod, I was appalled that most of the circuit is wired with 18g, and fused at 20 amps.
Old 10-26-2014, 07:07 PM
I got almost all the fusible links taken care of, I got an f150 fuse box from a junkyard and cut and soldered like crazy. The only thing I need to get to next is to find a fuse of some sort for the alternator. I'm thinking a stock alternator is probably 75 amps, correct me if I'm wrong. I also should fuse up my trailer brake and a future cb wire. Some pics just for you guys.
What I started with
In process
And now
Old 10-26-2014, 08:20 PM
mknittle's Avatar
Looks like you are on the right track. Looking good.
Old 10-26-2014, 10:27 PM
blueghost08's Avatar
looks good man im in the process of restoring my 1st gen id love to do that just not that great with electrical lol
Old 11-01-2014, 05:05 PM
Well I went and bought the $26 Genos nipple and it worked like a charm. Luckily for that price. They also sent a couple sweet stickers so I'm not upset with the price anymore!
Old 11-01-2014, 05:24 PM
mknittle's Avatar
Cool
Old 11-01-2014, 07:58 PM
j_martin's Avatar
Alternator will put out 120 amps. you need a 150 amp fuse. They bolt down on a stud block type fuse holder.
Trailer brakes should be a 20 amp auto reset breaker. 12 g wire.
CB can run off the auxiliary circuit. or a separate 5 amp circuit, unless you have a monster heater on it.
Old 11-02-2014, 02:06 PM
Tyanks! That's exactly what I needed. I found that 50 amp maxis are not enough for the two heater relays. So ill have to order something bigger for those
Old 11-02-2014, 04:43 PM
j_martin's Avatar
The heaters draw over 100 amps each, over 200 total. That's why the lights dim repeatedly after a cold start. The alternator can't keep up. The dimming is normal.
Old 11-05-2014, 07:08 PM
peckens's Avatar
Would you mind sharing what circuit got what size maxi?
Old 11-09-2014, 02:13 PM
Yea the only two with maxi's were the tranny cooler (20A). The headlights and fuses 4 5 and 6 in the cab (20A) and the rest of the links were put on the regular type fuses. The smaller (22 guage) link got 10 amps and then the 20 guage got 15 amps. Most of the fuses didn't get used
Quick Reply: Check out chickenfarmer's Dodge!
