Go Back   Dodge Diesel - Diesel Truck Resource Forums > 3rd Generation Ram - Years 2003 and up > 3rd Generation Ram - Non Drivetrain
Register FAQ DTR Store Members List Mark Forums Read
Thread Tools Display Modes
Old 05-26-2009, 09:45 PM   #31
Clane
Clane's Avatar
Send a message via Yahoo to Clane
Quote:
Originally Posted by rip 112 View Post
Bump..........
No need to bump, it's a sticky... Just gotta be patient....
__________________
-Chris
DTR Megacab Club Member #217
06 2500 MegaCab 4x4 SLT Black
6" Lift - King 2.5s / Thuren Towers
37" Toyo MTs / 20x10 Pro Comp Wheels
Defiant Steering Brace
AFE Stage 2 / Muffler Delete, 5" RBP Tip
Some AV Stuff
AMP Powersteps
On Board Air / Train Horn
NightRunner Head Lights
DT ProFab Light Bar 3 - 7" H.I.D's
Clane is offline   Reply With Quote
Old 05-28-2009, 08:57 AM   #32
rip 112
DTR's Groundskeeper
rip 112's Avatar
Send a message via Yahoo to rip 112
Quote:
Should I still be patient? I wanna know whats going on and what my codes mean.
__________________
Rick-04 2500 2wd 305/555 nv5600 , Smarty/ MP-8, HTT 62/71-13ss, Airdog 100, SBC Con OFE, BD Short shifter, Isspros, Quad RP, AFE stg. 2, CFM horn, MBRP stacks , LED tails and cabs, 20" Helo Core, 285/55 Terra Grapplers. Memphis Audio, Kicker L5 15.
08 Rhino 700fi 4x4 on 27"s
07 Yamaha Grizzly 700 on 27"s
"Don't have much, but what I got is MINE."
Aug 08 TOM
rip 112 is offline   Reply With Quote
Old 05-28-2009, 09:45 AM   #33
madhat
The Admin that's here for you!
madhat's Avatar
I would suggest making a new thread on this with the codes that you are showing as the thread starter...
Just my .02, since I don't have the answer for you.
__________________
Mark
04.5 3500 SRW 4X4 Smarty REVO PoD, MP8, HTT 64/71/16ss, Flux 2.5, ARP studs, ATS stage 4 with aftermarket output, Snow stage 3 water/meth, AD 150, Arson II CP3 mod. 37" BFG KM2 MT's on stock rims and ride height.
636/1266 fuel
868/1778 on a little spray
David Dunbar's dyno, 7 Nov
12.46 @109 Coastal Plains, Oct 08
Many thanks to Lary Ellis and the DTR store, ATS, Don M, and Bob W...
madhat@dieseltruckresource.com
madhat is online now   Reply With Quote
Old 05-28-2009, 03:49 PM   #34
Clane
Clane's Avatar
Talking
That or take it to the dealer ....
Old 05-28-2009, 05:23 PM   #35
rip 112
DTR's Groundskeeper
rip 112's Avatar
Nah, I'll pass. Truck runs fine, must not be that important, was just curious.
Old 06-04-2009, 02:59 PM   #36
Rednax
Rednax's Avatar
Quote:
Originally Posted by madhat View Post
How to Check codes:
Turn the key on and off 3 times, do not engage starter. On the third cycle, leave the key on. In my vid, it reads 'DONE' because I have no codes, but if you have them, they will display.
How to do a gauge check/display 'C' codes:
Press the odometer trip reset, hold it, then turn the key to the 'ON' position. Do not engage starter. Once the gauge check starts, you can release the button. Once it is done with the gauge check, it will display 'C' codes.
Hour meter check:
Turn key to 'ON'. Press and hold Odometer trip reset button. After a few seconds of it being pressed, it will show the hours.
hth...
mad
First, I want to say thank you for the trouble in posting this information. I used the following link to help decipher P-codes:
P-Codes:
http://www.cumminsforum.com/forum/3r...en-trucks.html
I had no "P" codes, but did have a "C" code combination"
A4 01
I haven't found A4, so if someone would post, it would be appreciated.
(I see that the OP is deployed at Iwakuni; I've a son at Kadena (VMGR 152). I was thinking of ALL of you-all while at the recent annual air show at NAS Corpus Christi; how is that May 5 show?)
__________________
2004.0 2500 2WD QC SRW 305/555 NV5600 longbed. Currently at 7,360-lbs & 154,000 miles. [3,850-hrs/39 mph]. Stock, but for Leer topper; Aeroturbine 4040 [ as resonator] ahead of Rokktech Silent Might [as muffler]. 18-20 city/24-27 hwy/13-15 towing 34' TT [logged].
All miles at 1700-1900 rpm.
Rednax is offline   Reply With Quote
Old 06-06-2009, 07:32 PM   #37
2fastfountain
Just did my 03 pretty cool. It brought up code p0483 which is fan speed whatever that has to do with anything doesnt overheat.
2fastfountain is offline   Reply With Quote
Old 06-06-2009, 09:59 PM   #38
madhat
madhat's Avatar
A big thing with these codes... if anything out of the norm is detected by the ECM/PCM, it set's a code. Sometimes, there is just a hiccup, and something goes out of tolerance for a second, then straightens back up.
If the truck is not running bad, or you don't see any symptoms that the code described, get it cleared and see if it comes back. Make sure it's a failure, an not just a glitch.
Rednax, I'm in Okie right now, just a stones throw away from Kadena. Small world...
Old 12-18-2009, 11:11 AM   #39
MyFirstRide
codes
so i checked my truck and i have some codes, where do i go to figure out what they are and how to clear them?
MyFirstRide is offline   Reply With Quote
Old 12-18-2009, 05:29 PM   #40
madhat
madhat's Avatar
http://wiki.dieseltruckresource.com/wiki/Computer_codes
Here are the codes... What are they?
If you do not have a programmer like a smarty that will clear codes, you can take it to an auto parts store, and they can clear them out for you.
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.6.7
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
vB.Sponsors
Copyright 2003, DieselTruckResource.Com
