Go Back   Dodge Diesel - Diesel Truck Resource Forums > 1st and 2nd Generation Ram - Years 1989-2002 > 24 Valve Engine and Drivetrain
Register Forgot Password?
Search
submit to reddit
Thread Tools Search this Thread Display Modes
Old 10-30-2008, 10:26 AM   #1
MDLP412
MDLP412's Avatar
Charging system troubles
my uncle has a 01 automatic that i put a new lift pump on for him, on the way back to deliver his truck to him the "check gauges" light came on. i checked and the voltage was down to below 8V so i took the alternator off and it tested bad, after i put the new one on i started the truck and it hung around 10-11ish for about 3-4 min and then it dropped right down to below 8 again. had the new alternator tested and it tested good, i was also told the the voltage regulator was in the PCM (JTEC) and it might be a bad computer. does this sound right to anyone or has anyone had the same problem? any info would be helpful. THANKS!
__________________
05, Quad cab, 3500 DRW, 6-speed nv5600, 4x4, 3.73's, BHAF
MDLP412 is offline   Reply With Quote
Old 10-30-2008, 08:31 PM   #2
Grider Pirate
Grider Pirate's Avatar
As a starting point, I would disconnect both batteries, check voltage while disconnected, and charge them before spending any more money. After charging, check the voltage before reconnecting them. If either is under 12.6 volts, it's likely bad, and troubleshooting charging problems with a bad battery is tough.
__________________
Grider Pirate, USAF RET
'99 2WD, Auto trans, 215,000 miles, DSS, New VP44, new LP, cheap DIY low fuel press. warning light.
'01 4WD, 175,000 miles. Dyna mat throughout interior, Alpine Stereo with remote amp, '03 track bar, Bilsteins, '08 (17") Wheels, 1 Ton chevy wheel cylinders, FASS, ATS trans, 3.74 gears, BHAF, 3 piece exhaust manifold, Banks power elbow, 4" exhaust, Banks High Ram intake, Stage 1.5 F-1 injectors.
Janus C glider
Grob 104 glider
Grider Pirate is offline   Reply With Quote
Old 10-31-2008, 06:44 AM   #3
dozer12216
Yes, check both batteries separatelly.
A quick test of elecrtonics for charging is with engine running, the alt pulley should be a magnet. The reason. IF PCM is working regulator circuit the rotor will be a magnet and the alt pulley is also a magnet. Carefully hold a screwdriver near front of pulley and should pull to pulley.
A FSM would help clear the issues of testing.
__________________
2008 1/2 3500 dually that is stock except for 2 micro inline filter for fuel. Infero red extended cab, long box made for highway towing.
dozer12216 is offline   Reply With Quote
Old 11-02-2008, 10:30 AM   #4
mini14
mini14's Avatar
yes, pcm controls voltage regulation, many have had your prob. u can bypass the pcm control and add an external voltage regulator.use the search function on this board and subject u will find what u need.
__________________
99 auto 4x4 4.10 rear,no s ring,bhaf, edge ez, 4" s.s. magnaflow
05 Q.C. auto, stock....for now...
mini14 is offline   Reply With Quote
submit to reddit
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.6
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
vB.Sponsors
Copyright 2011, DieselTruckResource.Com
Contacts Backup
