changing fuel tank module
I have to change the fuel tank module in my 2001.5. I would like to know which way would be the best way to change it. Lift the bed off the truck or just drop the tank. I have accsess to a overhead crane at work. If i drop the tank has to be done with no truck lift. Would like to hear everybody two cents worth. Thanks in advance for your input.
2001.5 Quad cab 4x4 120 hp injectors AFE stage 1 intake and 4" exhaust Edge juice w/a 10x8 eagle alloys 392 walbro lift pump 2" leveling kit Banks high ram intake 335.000 kms NADP full race auto trans 285x16 bfg trac bar and steering stab |
With a crane available and no lift, I would lift the bed. Only a few bolts. Those straps can be hell to get loose even with a lift and a tranny jack under the tank.
'01.5 2500 CTD QC SB SLT 2WD, Auto (Goerend), 3.54LS, TruxPort, J-hook, AEM Workhorse, Boost/Pyro/FP/Trans Temp, 4" Pinnacle Power Exhaust, Vulcan Big Line Kit w/Raptor, Edge Comp, DD1s, DEI Remote Starter, KoolVue Tow Mirrors, 20% Tint, LED tail ,brake, and turn signals and 4300k HIDs. Keith |
I have had to drop mine several times and and have dropped it as opposed to lifting the bed. My bed has a fairly heavy toolbox and a headache rack in it that is lighted and there is not enough slack in the wires to raise it enough with out unhooking the wires so I drop the tank. It is two bolts, and a couple of quick connect fittings and couple clamps. I can do mine in about 15minutes.
Obviously the least amount of fuel possible makes it easier. I can do it myself with 6 or 7 gallons in it after that I need a jack.
2001.5 SLT, QC, LB, 4X4, DTT Auto, 3:54's, Maghytec Trans and Diff Covers, Edge Juice, RV275's, Smarty, SPA gauges, Linex, AFE intake, DOR Bumper, Kore Chase, Cam, 12valve lift pump, LSFARM Traction Bars, 3rd Gen TracBar, DSS, PDR HX35, On Board Air and one big grin |
I have done both mutiple times both ways are a PIA but I think i prefer dropping the tank I just try to get it as empty as possible and have a floor jack and 2 short jack stands to sit it on. it does not need to be on the ground to pull the sender out at a slight angle.
2001 2500 quad long bed western plow bhaf quad max mileage |
I would raise the bed or take it off. Much easier IMHO. and it gives you a chance to inspect parts of your truck that are normally hard to see. Brake and fuel lines, rear diff, frame rails etc.
Daniel My Trucks- 01.5 2500 CTD 2wd 6spd QC/SB Green SLT Loud Audio, Low Fuel Press. Light, 6k Flashtech HIDS 91.5' CTD Sold Dads Trucks- 93' W350 Reg Cab DRW 4x4 CTD 5spd flatbed 4" stack 04' 3500 Reg Cab DRW 4x4 CTD 6spd 87' D150 318 Auto KYDTR#41 Chapter President Contact me on how to join KYDTR #41 Forum So. Ill and In. Welcome Click Here |
With access to a shop crane (and warm place to work - lucky you) I would lift the bed right off. Without access to the crane - I would drop the tank. But thats kind of obvious.
Thanks for the info. I did a little checking on the price of that module in the fuel tank. My local dealer wants 520 bucks for the part. I phoned my brother in edmonton he priced one out there and the price was 368 buck. That price was also from a dodge dealer why the big price difference. Talk about getting bent over. I phoned the local dealer and told him the price and he said that was the wrong price. I gave him the dodge part number and he was speechless. Makes a guy wonder how bad we are getting bent over when we have to get parts from a dealer. Again thanks for the info Garry
dealer's around here seem to be setting there own price on part's also.there's not much choice,when it come's to local dealer's in my area now.i ended up getting part's from a dealer in washington and it was still cheaper with the shipping cost.they also shipped it from a dealer closer to my area and i had it in 2 day's.
02 2500 slt laramie qc 4x4 long bed cummin's auto,k&n filter kit,4" turbo back exhaust,mia silencer ring,edge ez,vulcan big line kit w/ draw straw II,summit pump(14@140gph),autometer fuel pressure gauge,2" leveling kit,dss. |
Try going to Vulcan Performance. They have the jeep liberty cannisters for one heck of a lot less. I think even with the drawstraw installed it was 200ish and without was 100ish. Direct drop in and complete if I recall correctly. Certainly worth a call.
I would follow BarryG's advice about Vulcan Performance. That or bring in a module in from the states if you can wait.
I believe hes talking about this: http://www.vulcanperformance.com/Dra...w-p/jlfmds.htm or this: http://www.vulcanperformance.com/Dra...low-p/jlfm.htm I dont have one so cant give specifics. They will ship USPS so shipping is cheap as well.
Why are you changing the module?
If the fuel gauge doesn't work, the sender is available for 45 bucks, and if your lines are rotten at the top, you can either get a remanned unit from Dodge for 150 bucks or a Vulcan draw straw for 49. They are also available on Ebay cheap.....
"Brownie" 1997 2500 Ext.cab SLT, 4X4 auto, 3.54 gears, posilock, 98/99 steering conversion. New TC, lovin her again! "Greenie" 1997 2500 Ext. cab SLT, 4X4, NV4500, 3.54 gears, Ready to install SB DD3250, built just 216 trucks after Brownie! |
demon.what is wrong with your module anyway's?
my truck had the in-tank pump retro-fit.i just left it in place and popped a draw straw into the tank for my fuel supply line.
When I have a little more than a 1/4 tank of fuel my truck run out of fuel. put there is still fuel in the tank there is about 5 gallons of fuel left.
I just paid $148 for the level sending unit at the dealer last week, I dropped the tank rather than pull the box and there is a I beam and chain block in my garage
two straps as opposed to a bunch of bolts and the wiring at the rear seemed to me to be a whole lot easier. I only had about a 1/4 tank of fuel and access to a cheap motorcycle jack. I also have used just a floor jack before by myself to drop the tank to replace a leaking return line.
1996 Ram 2500 4X4 club cab long box kdp Killed, Aurora 2000 Turbo. Isspro boost pyro trans temp gauges. BD intake, Smokem's 5 x .012 injectors, rack plug, 100 plate timing set at 15.5*. DSS , 3rd gen track bar and bracket 4" BD exhaust 3000 gsk. TPS built Trans, Billet input, single disc converter. |
Quote:
1999 Ram 2500 Quad Cab 4X4 Shortbed Cummins 24 Valve, NV4500HD, NV241HD, model 60 and 80 Dana Diffs - All Stock. |
| Thread Tools | |
