Go Back   Dodge Diesel - Diesel Truck Resource Forums > 3rd Generation Ram - Years 2003 and up > 3rd Gen Engine and Drivetrain -> 2007 and up
Register FAQ DTR Store Members List Mark Forums Read
Thread Tools Display Modes
Old 11-06-2009, 10:57 AM   #16
coolbreeze
Quote:
Originally Posted by ah64id View Post
Try getting warranty for an oil related issue with your "mark" as the full point.
Use the dipstick.
Yep, use the dipstick, the manual, 12 quarts with a new filter of the proper oil, and you won't have any oil related warranty problems.
__________________
2008 3500 CTD Quad Cab LB SRW 6 speed Auto 4X4 3:73 P3 Brake Control White Born 09/07.
coolbreeze is offline   Reply With Quote
Old 11-06-2009, 02:27 PM   #17
mega-engr
mega-engr's Avatar
Quote:
Originally Posted by sabersix View Post
I agree that 4K is way overkill for uncompromised oil. However, oil that is diluted by fuel loses viscosity and quickly degrades lubrication performance. I too went to shorter oil change intervals with the 6.7L because of the fuel dilution issue.
Let's see, to get fewer emissions the guvment has mandated emissions controls. Now I use more fuel and change my oil more often...
That's probably why my system fell off and it currently under inspection for proper operation.
Actually, there are mostly several reason for this and they all need to be fixed really.
The factory manual shows capacity. For this to be 100% accurate, you would have to 100% remove every trace of oil from the motor and systems. Capacity is a reference. The dip stick is a gauge to make sure the level is proper and should be followed. The emission system will cause the oil level increase which does also affect the oils ability to do it job to an extent because of dilution.
Choose your margin of safety and act accordingly. Following the manual and gauges is the way to ensure this minimally.
__________________
2007.5 Ram 3500 SLT 6.7L Megacab, 4x4, 6sp. Auto, Electric Blue, Nav & 6 disc changer, Smarty S67 ME14 (SW3), Revertable EGR Plugging and Exhaust Deletes, Edge Insight, S&B intake, Amp Research Steps, Prodigy Brake Controller, Wolf Liner O.T.R.
DTR Megacab Club Member #152
mega-engr is offline   Reply With Quote
Old 11-06-2009, 03:02 PM   #18
AH64ID
AH64ID's Avatar
What I find so interesting is that it seems that most people on this forum just add 3 gallons and call it good. But every other vehicle forum i have ever been on it the opposite, go off the dipstick not the published quantity.
I mean think about the design of the oil pan, the threads probably keep a 1/2 qt or so of oil in there that is "part" of the 3 gallon capacity.
__________________
2005 3500 SRW 4X4 QC LB NV-5600, Jake Brake, Smarty Jr Revo, Airiad MIT, GDP Intake Horn, GDP MK2+ w/ Cat 2um, Baldwin BF1212, Amsoiled, Pricols
AH64ID is offline   Reply With Quote
Old 11-06-2009, 03:15 PM   #19
Mlucas
Mlucas's Avatar
Quote:
Originally Posted by mr. ed View Post
I just changed my oil today. After 4,000 miles I removed about 3 1/2 gallons. I never wait for the oil change indicator but change oil instead at about 3-4k intervals. I don't feel comfortable with the oil level rising so much in such a short mileage period. This is the first vehicle I've owned that actually "makes" oil.
I'm seriously considering removing about a quart of oil every 1.5k miles or so in order to keep the level from rising too much (the Fumoto drain valve makes this easy). As one guy on this thread said, too much oil is VERY bad for the engine.
Still love the truck, though....
Crazy to think that your oil is diluted by 1/2gal with diesel after only 4k miles....man, doesn't your rig warm up before you drive away? I'm not bashing you-just wondering...
__________________
2006 3500 QC SLT SB AUTO, High Idle, 35 x 12.5 Dick Cepek FC2 on Incubus Nemesis 8 20 x 9, Nerf Bars, Espar
Catch Me Red
Mlucas is online now   Reply With Quote
Old 11-06-2009, 10:41 PM   #20
mega-engr
mega-engr's Avatar
Quote:
The making of the oil does not have much about warming it up or not. It is due to the extra fuel being used to clean the envirnoment. Inevitably, it gets in the oil that way warm or not. 0.5 gal is less than 5% of the rated capacity...
Old 11-07-2009, 04:43 AM   #21
sabersix
Quote:
Mega-engr is right, the fuel dilution is due to the regeneration cycles. I drive my truck 20+ miles to work each way, so it was getting warm.
With my 2007.5 6.7L truck, I pulled an oil sample each time the "change oil" message appeared in the overhead console. The message usually appeared around 4,500 miles. My % fuel dilution was almost always above 2% and once was 5.5%.
Now with my new 2009, I was able to go 7,500 miles before I got the "change oil" message (7,500 is the max interval allowed and will trigger the message). My fuel dilution on that oil was 1.5%. Same driving conditions.
__________________
2009 Ram 3500 Mega DRW 4x4 Auto - August 2009 TOM
2007.5 Ram 2500 Mega 4x4 Auto - SOLD
2004.5 Ram 2500 Quad 4x4 Auto - SOLD
sabersix is offline   Reply With Quote
Old 11-07-2009, 07:42 AM   #22
CoastalDav
CoastalDav's Avatar
Send a message via AIM to CoastalDav
You guys ever seen a crankcase explosion caused by Diesel Fuel in the oil pan? It's not pretty.
If you guys are right and want you're expierencing is an overfull crankcase casued by Diesel Fuel, I would get it to a dealer or a Cummins Service facility and have them change the oil with both you and the service facility getting a sample to sent off to verify the percentage of dilution. A vis guage can tell you if you have diesel in the oil, if you can get a sample.
This got so bad offshore on unmanned platforms, and some manned drilling platforms, that relief valves were installed to vent the explosion and shut the engine down, there by avoiding the fire that usually begins when this happens.
I would not play around with this as it could be a really bad thing.
Dave
__________________
2006 Dodge 3500 SLT, Cummins, 48RFE, 3:73's, 70 Gallon Transfer Flow Bed Tank with Trax II Monitor System, Racor Marine Centrifigal Water Seperator/10 Micron Filter in the system. Edge Insight w/pyro, Headache Rack, Turbo Wing, Rhino Bed Linner, Nasta Rails, Recon Lights and Strip Lights, Sirius Sat Radio, Net Weight 7,520 lbs with 34 gallons fuel Tagged at 13,500lbs GVW. Towing 35ft Carriage ,Triple Slide 5fer, GVW 14030.
04 Hemi Durango AWD "Grannys Hemi Kid Getter"
CoastalDav is offline   Reply With Quote
Old 11-07-2009, 01:50 PM   #23
txarrowhunter
txarrowhunter's Avatar
When i change the oil on my truck its the other way around, i let i t drain for 30 minutes and pour the capacity on the manual and drive it around let it sit for 30 min and my dipstick is on the lowside by half an inch.
Should i add more oil than the capacity of the engine calls for even thought the dipstick is more than 1/2" below the full mark?
I talked to the dealer about it and they said their techs pump the capacity of the engine every time they change the oil in customer trucks they dont bother with the dipstick either.
__________________
07 5.9 CTD MegaCab 6spd 4x4, afe blade runner, 4" silver line exhaust, AFE mega cannon CAI, 5.5" revtek/pro-comp susp lift, 5100 bilsteins, BW pocket flares, eclipse diamond audio, 35.00-12.50x20 nitto m/t, 20" diamo wheels, srt hood, dual Stabilizers, Thuren Trac Bar, -o fab trac bars
DTR MegaCab Club Member #260
txarrowhunter is offline   Reply With Quote
Old 11-07-2009, 02:50 PM   #24
AH64ID
AH64ID's Avatar
I would go off the dipstick.
Old 11-07-2009, 04:07 PM   #25
coolbreeze
Go with capacity and check the level after it sits overnight.
Old 11-07-2009, 04:32 PM   #26
mr. ed
Quote:
Originally Posted by bansh-eman View Post
ever 4k is way over kill. I got to 9k before I change mine. Also you got to be careful, not having enough and having too much oil is just as bad. Both will not allow proper lubrication.
I would love to go longer on the oil changes but I figure it this way: if 4000 miles creates an extra 2 quarts then 9000 miles would put me over one gallon too full! I ain't gonna wait for that to happen, even if it is a waste of oil and $$ to change it every 4k miles.
If the only way to minimize this problem is by unplugging the EGR and perhaps "losing" a few more parts I'll have to give that serious consideration. Makes you wonder, though, that if D/C expected oil levels to rise in these new vehicles then perhaps they designed 'em to run with 4 gallons of oil. I doubt it, though
EDIT: I forgot to add, I didn't notice any diesel fuel smell in the old oil. I even gave it the "paper towel" test to see if fuel was present and it didn't show any. I know, that isn't a professional test but at least my nose didn't detect anything but oil. If there was a half gallon of fuel in there I think I would have noticed it. I could be wrong, but that's why I visit these forums to hear from the experts.
__________________
2007.5 Dodge Ram 3500/6.7 CTD/SRW/SB/4X4/QC/G56 trans/Big Horn Edition/mineral gray/16k Hijacker manual slider hitch. Bone stock
mr. ed is offline   Reply With Quote
Old 11-07-2009, 07:17 PM   #27
bansh-eman
bansh-eman's Avatar
I don't see how your getting so much extra and not able to smell any fuel. Something isn't right.
I am going to ponder a little over a few beers tonight and see if my imagination can't comeup with something.
__________________
~Black 06 2500 HO 48re 4X4 Big Horn Quadcab SLT~
-GDP MK2 - 2 Micron Fuel Filter Kit
-Amsoil Oil Bypass Kit
-PSC Steering Brace
-Thuren Adjustable Track Bar
-N-Fab W/W 6 Steps
-Jimmy Jammer Products
-Ravelco
-Grey WeatherTech Mats
-Rear Fender Liners
-Bush Wacker Pocket Flares
~Coming Soon~
-RevTek 4.5in Lift w/ Bilstein 5100's (Ordered)
-Toyo Open Country 35x12.50x18
-XD Addict 18x9 (Waiting for tires)
-Ranch Hand Bullnose
-PIAA 520 ATV (Waiting for bumper)
bansh-eman is offline   Reply With Quote
Old 11-08-2009, 01:32 AM   #28
mega-engr
mega-engr's Avatar
Whether you go with capacity or sneak up on it, use the dipstick. It is the gauge designed to ensure the level is correct. There is no known issue with it, or it would have been resolved by now.
I've heard that once the emissions falls off that the oil not only seems to stay put level wise, but also stays cleaner longer.
When you're not feeding your motor it own refuse and squirting extra fluid into the combustions chamber then it makes a lot of sense to me the the oil level and color/qualtiy would seem/act "normal".
Old 11-08-2009, 08:21 AM   #29
AH64ID
AH64ID's Avatar
Per the service manual
To ensure proper lubrication of an engine, the engine
oil must be maintained at an acceptable level. The
acceptable oil level is in the SAFE RANGE (3) on the
engine oil dipstick
Old 11-08-2009, 09:52 AM   #30
Hvytrkmech
DTR's "Puttin fires out and workin on big trucks" member...
Hvytrkmech's Avatar
Making oil is not normal, regardless of the emission equipment on the vehicle. If you are making 2 qts of oil in 4k miles then i hope you have plans on putting an engine in it. The added soot in the oil caused by egr is masking the smell of the fuel. Fuel enters the oil from a leaking injector tube, an over fueling injector, low egt's, excessive idling. If it is not an injector tube then it is bypassing the piston rings from what we call wet stacking. Oil left on the cyl wall mixing with unatomized diesel fuel diluting the oil. This is a progressive cycle, and cause rapid catastrophic failure.
If an engine is run up to and at full operating temp and is not idled excessively then in my opinion, a fuel dilution of >1.5% is too high and would get my immediate attention.
__________________
Tim
2006, 3500 QC/SRW/LB/48RE/4.10/Inferno red, Mag-Hytec trans and diff cover, Isspro gauges, Quad XZTII, GDP 2 micron kit, Air Dog 100, install with pics- http://www.dieseltruckresource.com/d...d.php?t=185809
Hvytrkmech is offline   Reply With Quote
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.6.7
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
vB.Sponsors
Copyright 2003, DieselTruckResource.Com
