#1 |
Changed oil, put in 11 liters, now 1/2" over full
Changed oil, let it drain for 2 days, installed new Fleetguard Stratopore and installed EXACTLY 11 liters of oil. Drove the truck for 25 miles and let it sit 2 hours. The user manual says the 6.7 holds 11.3 liters. On the dipstick its reading a good 1/2 inch over full. Am I insane, my 5.9 did the same thing to me.
__________________
2007.5, 2500HD, QC, Laramie, 4X4, SB, 68RFE, 3.73, Inferno red, Edge Insight w/pyro, MaxBrake, Firestone Ride-Rites and controller, Air-Zenith air compressor, EZ Change Drain plug, S&B drop in air filter, 250 watt oil pan heater, EGR unplugged. 2008 YZ450FX, matching 756's, Marcel Fournier ice tires, 320mm EBC supermoto front disk, billet fuel screw, DiD narrow x-ring chain, Ironman sprockets, Scotts SS oil filter, Dr. D pipe coming, love the SSS suspension... |
#2 |
You are not insane.. I did the same thing..
. Too used to the changes on my 97 with the how much to put in and I had to drain out a good litre.
__________________
97 2500 4X4 LWB CC SLT Laramie 5spd LSD 3.55. Isspro EV's pyro/boost, #10 Plate, PEAK 3K GSK, AFC Spring, DDP III injectors, S300 Turbo, PEAK IC Boots, TAG III, South Bend 13-1.25" Con FE clutch, SCOTTY II-UNI, MBRP XP 4", KDP Tab, 16° Timing, SS DSS / 03TBK, Roda Deaco PAS. Espar D5WSC heater. B-Quiet sound deadening inside. Dyno 09-2009 401 RWHP / 1050 Ft-lbs '08 2500 4x4 MegaCab Laramie, 6.7, 68RFE, 3.73 LSD, S-67ME POD. Alberta Chapter #5 Prez... PM me for details... |
#3 |
I've had this happen to me too. Pour what it holds don't bother with the dipstick.
__________________
07 5.9 CTD MegaCab 6spd 4x4, afe blade runner, 4" silver line exhaust, AFE mega cannon CAI, 5.5" revtek/pro-comp susp lift, 5100 bilsteins, BW pocket flares, eclipse diamond audio, 35.00-12.50x20 nitto m/t, 20" diamo wheels, srt hood, dual Stabilizers, Thuren Trac Bar, -o fab trac bars DTR MegaCab Club Member #260 |
#4 |
If your oil pressure is ok leave it the way it is. if it jumps or dives then be worried.
__________________
~Black 06 2500 HO 48re 4X4 Big Horn Quadcab SLT~ -GDP MK2 - 2 Micron Fuel Filter Kit -Amsoil Oil Bypass Kit -PSC Steering Brace -Thuren Adjustable Track Bar -N-Fab W/W 6 Steps -Jimmy Jammer Products -Ravelco -Grey WeatherTech Mats -Rear Fender Liners -Bush Wacker Pocket Flares ~Coming Soon~ -RevTek 4.5in Lift w/ Bilstein 5100's (Ordered) -Toyo Open Country 35x12.50x18 -XD Addict 18x9 (Waiting for tires) -Ranch Hand Bullnose -PIAA 520 ATV (Waiting for bumper) |
#5 |
This is why you never add oil based on what the book says... You add 90% of it, run and check... Too much oil can be VERY bad for an engine.
Unless he has added an oil psi gauge he has no way of knowing what his real oil psi it. The gauge in the 03+ trucks is fake.
__________________
2005 3500 SRW 4X4 QC LB NV-5600, Jake Brake, Smarty Jr Revo, Airiad MIT, GDP Intake Horn, GDP MK2+ w/ Cat 2um, Baldwin BF1212, Amsoiled, Pricols |
#6 |
That don't make any sence. Either the pan is the wrong one or the dipstick is wrong.
There should be a part number on the dipstick. See what it is and call the dealer and see if it the correct one. Filter should hold a quart? Dave
__________________
2006 Dodge 3500 SLT, Cummins, 48RFE, 3:73's, 70 Gallon Transfer Flow Bed Tank with Trax II Monitor System, Racor Marine Centrifigal Water Seperator/10 Micron Filter in the system. Edge Insight w/pyro, Headache Rack, Turbo Wing, Rhino Bed Linner, Nasta Rails, Recon Lights and Strip Lights, Sirius Sat Radio, Net Weight 7,520 lbs with 34 gallons fuel Tagged at 13,500lbs GVW. Towing 35ft Carriage ,Triple Slide 5fer, GVW 14030. 04 Hemi Durango AWD "Grannys Hemi Kid Getter" |
#7 |
I think the dry capacity would fill the engine from new. The oil cooler doesn't completely drain when you dump it and leaves a little in the system. Thats probably the extra litre.. I have only done one change on it so far, the next one is today.. Won't do that again!!
#8 |
I notice in your signature you use an ez drain plug. I'm not familliar with these but I looked at them on Geno's site. Is it possible these things stick up in the pan a little and do not allow all the oil to drain? And the always ask, is your truck level or tilted to the drain when you change oil? Hope you get it figured out.
__________________
2005, 2500 quad cab shortbed, 2 wheel drive, 5.9 H.O., 48re tranny, mag hytec double deep pan, 11.5 rear end 3.73 antispin, mag hytec diff cover |
#9 |
I just changed my oil today. After 4,000 miles I removed about 3 1/2 gallons. I never wait for the oil change indicator but change oil instead at about 3-4k intervals. I don't feel comfortable with the oil level rising so much in such a short mileage period. This is the first vehicle I've owned that actually "makes" oil.
I'm seriously considering removing about a quart of oil every 1.5k miles or so in order to keep the level from rising too much (the Fumoto drain valve makes this easy). As one guy on this thread said, too much oil is VERY bad for the engine. Still love the truck, though.... ![]()
__________________
2007.5 Dodge Ram 3500/6.7 CTD/SRW/SB/4X4/QC/G56 trans/Big Horn Edition/mineral gray/16k Hijacker manual slider hitch. Bone stock |
#10 |
ever 4k is way over kill. I got to 9k before I change mine. Also you got to be careful, not having enough and having too much oil is just as bad. Both will not allow proper lubrication.
#11 | |
Quote:
Let's see, to get fewer emissions the guvment has mandated emissions controls. Now I use more fuel and change my oil more often... ![]()
__________________
2009 Ram 3500 Mega DRW 4x4 Auto - August 2009 TOM 2007.5 Ram 2500 Mega 4x4 Auto - SOLD 2004.5 Ram 2500 Quad 4x4 Auto - SOLD |
#12 | |
Quote:
__________________
'07 2500 Reg.cab,G-56,5.9, Northstar popup 24/7. Upgrades: Carli,Defiant,Thuren,King. Don't blame me,I voted for McCain. |
#13 |
I read somewhere that dip sticks aren't always set in the engine the same at the factory. The 6.7 calls for 12 quarts w/filter, so 12 out, 12 back and make a mark on your stick for reference.
__________________
2008 3500 CTD Quad Cab LB SRW 6 speed Auto 4X4 3:73 P3 Brake Control White Born 09/07. |
#14 |
The EZ change oil drain plug leaves a VERY small amount of oil in the pan. I spoke with the company before I bought it and its designed to sit level with the bottom of the pan. I drained a liter out and its just under full.
Since I unplugged the EGR, the engine makes a very minimum amount of oil. I think next summer my emissions equipment might fall off... dang these rough Saskatchewan roads... |
#15 | |
Quote:
Use the dipstick. |
| Thread Tools | |
| Display Modes | |
