#1 |
How can I tell
I just noticed on my new truck that the sticker says manufacture date 3/09. How can I tell if it has the pcm that will or won't except a smarty?
__________________
Terry 2005 5.9 Quad Cab 4x4 Auto--Now one of my work trucks 2007.5 Mega Cab 6.7 4x4 Auto--Now a work truck And now driving a 2009 6.7 Auto Quad Cab Dually. Stock for now. |
#2 |
Try and find somebody close with a Smarty and try it
__________________
2007 JEEP WRANGLER UNLIMITED SAHARA 4X4 RESCUE GREEN LOADED 4in LIFT (WIFE) 2006 Jeep Rubicon Wrangler GREEN4.5 Rubicon Lift RUBITRUX (SON) 2009 Quad-Cab Laramie 6.7 Auto Loaded. Toys, Smarty ME Gauges,5"Exhaust EGR Delete More to come! :) KYDTR #41 |
#3 |
buy a smarty and upload it. That problem is fixed. ME Version 16 but now they have ME version 17 out. don't be skeerd
__________________
07 Mega, 9" lift, Toyo's, 8" stacks, Billet Clamps, Smarty, Ravelco, Ice Box, HID's, RECON, Ranger 6900 CB, Sterling grill SAC Member #1 Megacab Club # 81 3rd Gen Stack Club #18 Soldiers for Jesus Motorcycle Club (Prospect status Jan, 30th) NMDTR #44 PM me for details |
#4 | |
Quote:
So much for the locked ECM issue?
__________________
2007.5 Ram 3500 SLT 6.7L Megacab, 4x4, 6sp. Auto, Electric Blue, Nav & 6 disc changer, Smarty S67 ME14 (SW3), Revertable EGR Plugging and Exhaust Deletes, Edge Insight, S&B intake, Amp Research Steps, Prodigy Brake Controller, Wolf Liner O.T.R. DTR Megacab Club Member #152 |
#5 |
Check with MADS about the locked ECM issue. I think the work around is only for ECM's that have had the lock downloaded after the fact with the latest dealer flash. You will need to verify this and not take it for fact.
__________________
'07 6.7 3500 DRW, 6 speed auto, QC, 4X4, B&W turnover |
#6 |
I dont think the problem is fixed. The new update is just for the new flash. I dont think anything else has changed.
__________________
2007 Mega Cab Dually SLT, 6.7, Auto, White, Recon Smoked Cab, Fender, Third Brake, Tail, Light Bar, Big Rig Runnin lights, 5" TBE, XRT Programer 175, AEM Work Horse Intake. SOLD- 2007 Quad Cab SLT, Straight Pipe w/ 6" Tip, AEM Work Horse Intake, Silencer Ring MIA, Triple Dog Power Pup with Out Look Moniter, A-Piller Mount, 24" BZO Magic wheels, Fiberglass Bed Cover, Laramie Front Bumper, 2" Drop Shackles |
#7 |
it is not fixed yet. The latest software starting with 15 or 16 will warn you that the pcm is locked and cannot be updated. previous versions would just lock the pcm.
jeff. almost forgot, I believe there is a date on the pcm as well. There is a chance that your pcm was built before the 3/09 cut-off. But the safest way would probably be to check with smarty with one of the later software versions. Of course you do still have the option of a plug in module like the edge juice.
__________________
2008 Patriot Blue 3500 Quad-Cab, 4wd, DRW, Auto, H&S Stage 1, Edge JA, EGR System "fixed", LineX 2000 Quad-Cab LB 4wd auto. Dodgezilla Turbo, Unknown aftermarket converter(billet cover), 5" Exhaust 1970 Chevy C-10 1976 IHC Scout II |
#8 |
Where is the pcm located? Is the sticker usually visible or do I have to unbolt anything to see it? Thanks.
| Thread Tools | |
| Display Modes | |
