Go Back   Dodge Diesel - Diesel Truck Resource Forums > General > General Diesel Discussion > Fuels / BioDiesel / Diesel Prices
Register FAQ DTR Store Members List Mark Forums Read
Thread Tools Display Modes
Old 09-02-2005, 08:47 PM   #1
marv h.
marv h.'s Avatar
can I run wvo ?
What do I need to do to run waste veggy oil? Diesel went up 32 cents a gallon so far here today. I am interested in trying some wvo in the tank. Can you guys tell me anything about this. I can't handle much fuel at $3.40 per gallon. Any help would be great. Thanks!
__________________
1997 2500 4x4, 5 speed ext.cab, green and silver, tinted windows, kdp tabed, BHAF, Isspro pyro, boost, and fuel gauges on A pod, star wheel turned up some, TST # 10 kit, Lukes Link on track bar, silencer ring in tool box, Larry B's starter contacts, and fuel hose.
marv h. is offline   Reply With Quote
Old 09-03-2005, 09:51 PM   #2
kd460
http://biodiesel.infopop.cc/6/ubb.x?a=cfrm&s=447609751
__________________
1997 2500, auto, 4x2, bilsteins, gauges, #10 plate, 3k gsk, 4" exhaust, timing at 15.75* HTS Custom Transmission, 190,000 miles of beating the snot out of it (and counting).
kd460 is offline   Reply With Quote
Old 09-04-2005, 12:51 AM   #3
Stamey
Stamey's Avatar
Yes, but you will have to make several fuel system modifications. First is heaters on the tank, filter and lines. Second, you'll need a duel fuel system, with an auxiliary tank for the WVO. You must start and stop the engine on diesel, but once it is warmed up, you switch to WVO. When you get about a 1/2 mile from your destination you switch back to diesel so you can get it out fo the fuel lines before you stop the engine, so it will be ready for the next startup.
You'd have an easier time making BD yourself, because there are no fuel system modifications required.
The link KD460 posted is a great place to learn about either method.
Chris
__________________
Got TWINS? :D
Artificial Intelligence is no match for Natural Stupidity.
And by the way, I have an abnormal affection for my truck. My support group for this affliction is DTR Chapter #7 (like an alcoholic hangin' with his drinkin' buddies). [laugh]
1999 2500 CTTD, 4x4, QC, SWB, AT, loaded. What's my truck got? An obscene amount of torque, and an ATS tranny, repaired & upgraded with DTT parts. :rolleyes: PM me before you buy ATS.
Tim Barber (TimInVa) is THE MAN! THANKS Tim!
Now Overvalved AND Undervalved (got a 96 :D)
http://www.Stamey.Info/Truck
Are you a Diesel Head?
Stamey is offline   Reply With Quote
Old 09-05-2005, 09:21 PM   #4
marv h.
marv h.'s Avatar
OK thanks guys, I should have known it wasn't as easy as just pouring it in the tank. Sorry for posting in the wrong place!
Old 09-05-2005, 09:47 PM   #5
Stamey
Stamey's Avatar
Something you can try with no mods is mixing WVO with your No. 2. If you mix 50%, you'll save 50% on diesel. I'd get on a WVO forum to see how much you can mix in, though. I just used 50% as an example.
Chris
Old 09-06-2005, 11:10 AM   #6
akghound
akghound's Avatar
Thumbs up Best Info
Check out these sites;
http://www.frybrid.com/test.htm
Look at the first two sticky notes at;
http://biodiesel.infopop.cc/eve/ubb....51&f=159605551
Drop me a line anytime, I have over 23k miles, and a year on WVO. E-address in profile.
Ken Gardner
__________________
One Day At A Time
96 2500 4x4 Cummins Converted to WVO
4" Exhaust, #11 plate, Firestone Airbag Suspention
Gauges; Boost, EGT, Tranny & Diff Temps.
Living off grid-16/1 Listeroid Diesel Generator on WVO
akghound{at}gmail.com
akghound is offline   Reply With Quote
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.6.7
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
vB.Sponsors
Copyright 2003, DieselTruckResource.Com
