Go Back   Dodge Diesel - Diesel Truck Resource Forums > 1st and 2nd Generation Ram - Years 1989-2002 > 1st Gen. Ram - All Topics
Register Forgot Password?
Search
submit to reddit
Thread Tools Search this Thread Display Modes
Old 02-06-2003, 08:47 PM   #1
Farmall
Can I Run Without It
My TPS is shot. I have drove the truck with no overdrive for the year and a half I have had it. Can I just take it off the pump and run without it. I don't see what it will hurt, but wanted to ask and make sure. Thanks, Bill
__________________
1995 Dodge 2500
5 spd.
SBC FE
3:54 Gears and a LSD
4x4
Straight Piped
aFe Intake
Toolbox in the Back
Bearcat Elite CB
Twin Firestik's
Line-X'd
B&W Turnover Ball
American Racing Wheels
Gauges on the A-pillar
Custom Badges
Homemade BriteBox
Lucas Oil in the Motor
Royal Purple in Everything Underneath
And a few HP and Smoke mod's here and there.
The Surgeon General Never Said Anything About Smoking A Ford
Farmall is offline   Reply With Quote
Old 02-07-2003, 06:12 AM   #2
jughead
jughead's Avatar
Re:Can I Run Without It
with or without if it is bad you still wont have overdrive. you can put a toggle switch on the od wire to ground at the trans. will need to remember to turn it off when you stop. with switch on the trans will skip 3rd gear on hard acceleration.
__________________
slightly bombed 90 ctd 4/4. od trans, 0 to 60 7.7 sec., 1/8 mi. 9.65, 70 mi per hr., 1/4 mi. 15.89, 89 mi.per hr. weight 6569. added to stable. 1/2 ton 82 dodge with 97ctd. 370 injectors 0 fuel plate, 3k gov. springs, 518 with manual valvebody and hughes converter
jughead is offline   Reply With Quote
Old 02-07-2003, 10:52 AM   #3
furious70
furious70's Avatar
no lockup to worry about on his application? U shouldn't hurt anything, but I'd sure want my OD
__________________
1991.5 3/4 4WD 5SPD ctd
1970 sport fury 383/727
1969 coronet
furious70 is offline   Reply With Quote
Old 02-08-2003, 12:43 AM   #4
Sootblower
You can not take it out completely, but you can fix it at a permanent position. I removed the stub (underneath) and cut a stainless piece of sheet metal to fit on the bottom with two holes for the bolts to go through. I cut a small tab and bent it up to fix the potentiometer voltage for 1.3 volts with will cause the 3 to 4 shift at 35 mph regardless of throttle. You need a voltmeter. I have been running this way for 11 of the 12 years on my 91 W250. Has cut shifting and wear by factor of 75%. 235,000 km and no problems. I can mash the pedal and it stays in 4th. The torque converter is so mushy and loose it has lots of torque multiplication such that I rarely have to push dash OD OFF button. Use dash button on hills if you are towing, since there is lots of heat generated under high slippage.
__________________
97 W250 4x4 AUTO (82,000 km), totally stock but KDP tabbed, TC lock disable switch. 91.5 W250 4x4 AUTO, 16cm housing, 185 injectors from PDR, TPS bypassed, Borgeson coupler, (450,000 Km ) - no major work and original tranny. 2000 2500 Quad, Auto, 4X4, Isspro guages, Diablo Puck, TC lockup disable sw.
Sootblower is offline   Reply With Quote
submit to reddit
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.6
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
vB.Sponsors
Copyright 2011, DieselTruckResource.Com
Contacts Backup
