Thread Tools | Search this Thread | Display Modes |
#1 | ||
Caliper replacements
__________________
2001 suburban 2002 Dodge Ram 2500 SLT Laramie 4X4 stock engine other than k & n filter dodge mudlfaps billet grill inserts bug deflector window visors *SOLD* 1989 VW Golf N/A Diesel 52 hp of fury *SOLD* |
#2 |
I had one start to stick on my 99. Tire shop found way more wear when getting new tires, replaced the set.
#3 |
Not to hijack but what is the size of the caliper bolt??? hex or torx. I need to do front pads shortly and I want to make sure Ihave the tool.
__________________
'99 3500 Black DODGE RAM Quad Cab Laramie slt 4 x 2 dually 5spd 4.10. lift pump victim, VP-44 at 165k dual license plates. Extang Tonneau cover fuel pressure gage. silencer ring installed in glove box... new 3000w generator in the bed, Prodigy, Exon Valdez in my driveway. and ...yes the plane will fly older than dirt a cup is neither half full nor half empty, it is twice as big as it needs to be. |
#4 |
Almost positive it is 3/8 hex.
#5 |
Just did my front brakes this morning
and you are 100 percent correct... 3/8 hex.. there are two of them on the 96 calipers, one on top and one on the bottom.. Rick
__________________
05 3500, smarty, intake, exhaust, full replacements, full hitches, muds, steps, 110 gallon auxillary, R&K toolbox 95 5 spd 4x4 HUGE thanks to Gomer (Ad removed signature violation) |
#6 |
Thanks . Got it covered
#7 |
pretty sure hex on the calipers like they said. the craddle is inverted torx. which is weird cause the rear craddles are normal bolts
| Display Modes | |
