Go Back   Dodge Diesel - Diesel Truck Resource Forums > General > Competition / Pulls / OffRoad > Off Road / 4x4
Register FAQ DTR Store Members List Mark Forums Read
Thread Tools Display Modes
Old 04-17-2009, 07:59 PM   #1
bigorange
bigorange's Avatar
a/c pump to air compressor
hey guys not sure if this is the right place to post this but here it is I've seen jeep guys turn there a/c pumps into an air compressor and I was woundering if any one has done it to a 2005 ram, do to that I pulled all the a/c stuff out of my truck but still the the a/c pump on it and would like to have onboard air . any on have any tip on this would be great . shane
__________________
05 3500 ram, 8" coil over lift, colt cams stage 4, hamilton push rods and srpings , big air pumps, big sticks, zz fab side intake, 12v rods, fire rings, and so on, 855HP FUEL ONLY
bigorange is offline   Reply With Quote
Old 04-17-2009, 08:06 PM   #2
HotRodTodd
HotRodTodd's Avatar
Years ago we used to make the old piston style compressors like the York twin cylinders into air compressors, by adding a tank, pressure switch, lines, and drilling the crankcase on the compressor so that oil could be added and checked.
I don't think the newer rotary styles would be a good candidate to convert as there isn't a sump for oil, so its life would be very short.
__________________
"Be A Real American, Buy American Made Products, Whenever Possible. The Future Of This Country,And Your Job, May Depend On This."
HotRodTodd is offline   Reply With Quote
Old 04-17-2009, 08:19 PM   #3
bigorange
bigorange's Avatar
ok just woundering but how do they stay lubed when they are a a/c pump or is it lubed from the a/c oil
Old 04-17-2009, 11:17 PM   #4
HotRodTodd
HotRodTodd's Avatar
Quote:
The oil is in suspension with the freon when the a/c is in its normal configuration.
Old 04-18-2009, 06:00 AM   #5
gwhammy
www.onboardair.com has all the pieces to mount a york air compressor on the 24 valve trucks. I've had one for years, really handy. The big compressor will move alot of air,fast idle will keep up with a half inch impact most of the time.
__________________
02 2500 qc,auto,red sport 3.54 gears,edge juice,35-40 ,2.5 edm's,full billet trans,4in ex
01 qc,4wd,he351 over a 3b,adrenaline pulse,200 horse injectors,5in ex to 5 in. stacks.ats 5 disk convertor,on board air,st. hd gsk for now!
gwhammy is offline   Reply With Quote
Old 04-18-2009, 02:02 PM   #6
Busboy
It says that the compressor mounts above the alternator, does it relocate the alternator? If so does it need a special belt? It also mentions that a Vee belt comes with it so they must add another bottom pulley to drive the compressor. Does the tank mount under the hood? Did you buy the whole kit or make your own?
__________________
2001 2500 quad 4X4 5 spd Stock except gauges
Busboy is offline   Reply With Quote
Old 04-19-2009, 12:18 PM   #7
bigorange
bigorange's Avatar
I know about that air set up just want to do it on the cheap and was looking to see if I could use my a\c pump since I won't be running a a/c system but thanks for the good info .
Old 04-19-2009, 12:49 PM   #8
gwhammy
New bracket mounts above the alternator, the pulley on the alternator changes and has a v belt in front of the flat belt. I built my own setup,bought the bracket and pulley, bought a compressor rebuilt off of ebay for 135 with the right pulleys. I have had tanks in the bed under the bed and the last one is a 4X8 tubing rear bumper made into a air tank. I usually put a toggle switch inside so I can shut it off when not needed. They do work good just check the oil in them when I do weekend service on my truck.
Old 07-01-2009, 07:19 AM   #9
1-2-3
1-2-3's Avatar
I got a nifty little air pump from Sams about a month ago. Works on 12 volts. There's tons of then out there. With all them available, I would thing it would be too much of a hassle to do anything else, unless you wanna do train horns. Back in shop class, all the guys with trucks mad big air bumpers they could fill up and have enuff to fill a tire or two and get home.
__________________
Gen.3-'04 CTD, 94K, still figuring out what it's got
RIP: Gen. 2-99 2500 CTD-Recently Sold
RIP: Gen. 1-'95 2500 V-10-Stolen
Goofball Member #10
Ice Road Lisa Fan #1
1-2-3 is offline   Reply With Quote
Old 07-01-2009, 11:53 AM   #10
~Angry Tractor~
Yeh that York is pretty pricey. There are alot of alternatives. I'd do a search on airhorns on this site. Thats where your gonna find cheap ways to get onboard air. Mid sized commercial 6bt's usually have air compressors and I have seen them for sale on FLEABAY for a few hundred. Don't know if they would fit on a Dodge though. I have one on a spare 12 valve I bought and looking at it, it looks like it would be a tight fit. I just got an air horn and have been collecting the fixins to hook it up. I'm probably going to go with 12 volt compressor.
__________________
1996 2500 CTD, 4x4, BHAF, Silencer ring, somewhere in a field south of my garage. Tranny- 47RE. 145,000
~Angry Tractor~ is offline   Reply With Quote
Old 01-09-2010, 04:08 PM   #11
cLAYH
You can use your stock AC pump, lots of the Jeep guys do. You just have to keep the compressor oiled with either an in line oiler or manually.
__________________
2003 3500, dually, SO, 6spd, full load, SBC, Edge Hot Juice,AFE intake, BD exhaust.
Dad's truck now:
2001.5 3500 auto, 4x4, extended cab, loaded Sport, BHAF w/shroud, Juice w/Attitude, RV275 nozzles, DTT Torque Converter and Valve body, WG turnbuckled(32psi), Holly Blue pushing into stock pump(14psi @ WOT), DSS steering system, CIPA towing mirrors
cLAYH is offline   Reply With Quote
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.6.7
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
vB.Sponsors
Copyright 2003, DieselTruckResource.Com
