Go Back   Dodge Diesel - Diesel Truck Resource Forums > 3rd Generation Ram - Years 2003 and up > 3rd Generation Ram - Non Drivetrain - All Years
Register Forgot Password?
Search
submit to reddit
Thread Tools Search this Thread Display Modes
Old 05-15-2003, 12:14 PM   #1
Dan B
Break Dust
Is there a break in period for the brakes? With 2000 miles it seams like there is a lot of redish brake dust on the front wheels for normal everyday driving (not pulling anything)....Just a pain to be cleaning all the time...
Dan B is offline   Reply With Quote
Old 05-15-2003, 01:01 PM   #2
Guest
Re:Break Dust
Yeah, there's a break-in period for brake pads before the red dust stops - I think it's about 40-60 thousand miles, depending on driving styles - when the pads get down to the metal, the dust changes color... <br><br>It IS a pain, ain't it! No, it isn't gonna get any better over the life of the pads, either.
Old 05-16-2003, 09:36 AM   #3
dodgeman01
dodgeman01's Avatar
Re:Break Dust
You guys need to find those covers that go behind the wheel to stop the dust from getting on the wheels.<br>DM01
__________________
Aaron
[color=blue
94 Dodge Cummins Diesel forest green 4x4 reg. cab (2002) 5spd 215 pumped set at 30* 5x16 edm injectors ported,polished, and O-ringed head with custom valves and springs snow water meth kit
put to the ground by SBC DD clutch[/color] twins soon
04 auto commonrail (stock)01 p-pumped 24v 6spd 98 dodge CTD 93 dodge ctd 95 dodge gasser
Its a Horse power thing Ford owners wouldn't understaind
Thanks Peter of South Bend Clutch for the new tranny clutch and help
dodgeman01 is offline   Reply With Quote
Old 05-16-2003, 11:07 AM   #4
Guest
Re:Break Dust
IF you do heavy-duty use, towing, steep grades and such, you need to be cautious about potentially blocking airflow in and around brake disks - otherwise, ya just MIGHT end up with the cleanest wheels in the junkyard or bottom of a canyon...
Old 05-16-2003, 11:15 AM   #5
Green Giant
Re:Break Dust
Downshifting when you are stopping helps reduce the dust. High speed stops (50+ MPH) without downshifting will put a serious coating on the wheels after just a few hard or long applications of the brakes. I learned not to depend on the brakes that much from my 95' and carried the habits to the 03'<br>Jeff
__________________
GREEN GIANT 2003 3500 QC SRW LONG BED HO 5" Straight pipe, Silencer ring fell off the turbo as well as everything else that made the truck quiet :)
Green Giant is offline   Reply With Quote
Old 05-19-2003, 10:11 AM   #6
Dan B
Re:Break Dust
Does any one know where to get the break dust covers?<br><br>Thanks
Old 05-20-2003, 07:05 AM   #7
Dodgezilla
Dodgezilla's Avatar
Re:Break Dust
Genosgarage.com has them. They are called Kleen Wheels. They are fairly inexpensive and they do work. I had some on my 98 dually. they have slots cut into them for brake cooling..
__________________
04 Green/ Silver Dodge Ram 2500 4x4, 305/555 HO CTD, Custom 4" exhaust, HE351 turbo, VA C3.2
Dodgezilla is offline   Reply With Quote
submit to reddit
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.6
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
vB.Sponsors
Copyright 2011, DieselTruckResource.Com
Contacts Backup
