Go Back   Dodge Diesel - Diesel Truck Resource Forums > 1st and 2nd Generation Ram - Years 1989-2002 > Performance and Accessories 2nd gen only
Register Forgot Password?
Search
submit to reddit
Thread Tools Search this Thread Display Modes
Old 09-06-2007, 07:04 AM   #1
74dart
74dart's Avatar
? Bottom Turbo For Twins
Was searching through e-bay the other day and ran across a couple of turbos and I wondered if they would be a good bottom for a set of twins. One was a HX-60 and the other was a HX-85. The 60 had a 26 cm exhaust housing the 85 I don't rember. I have a s300 based 62/14 right now that I was going to use for the top. Are the holsets a good chioce or do I need to hold out for a s400?
__________________
96 4x4 ext cab LB, #10 Plate Factory Position, 3gsk, s-300 turbo, 4" straight exhaust (homemade glasspack in the works).
Quote:
Originally Posted by PoorMansCat View Post
I had a Detroit diesel calendar one time; I had to return it to the dealer and file a warranty claim on it due to it leaking oil all down my wall!!
04 30' Wildcat Fifth-Wheel
89 Jeep YJ, 2.5" lift, 31x10.50s, powered by a stock TBI 5.2l v8.
/],[____],
l---L –[]lllllll[]-
()_)-()_)--o-)_)
74dart is offline   Reply With Quote
Old 09-06-2007, 03:00 PM   #2
HOHN
HOHN's Avatar
HX-85 would be way too big. You'd maybe use this in triples with the HX60 as the "medium" turbo and the stocker as the small one.
HX-60 is a great choice for twins, especially if it has the WG housing (many do). HX-60 is basically a newer, better HT3B with better flow and spoolup.
JMO
__________________
Justin
Mechanical Development Senior Engineer, Cummins Heavy Duty Engineering
** Opinions expressed are mine alone, and NOT the official position of Cummins, Inc., or any affiliate or subsidiary.**
HOHN is offline   Reply With Quote
Old 09-07-2007, 01:17 AM   #3
Ph4tty
Ph4tty's Avatar
Last time a turbo air flow thread came up the hx60 flowed about the same as the s400 so that shouldn't be much of an issue. While the ht3b is a reverse flow turbo, the t signifying the direction of flow, so the ht60 is reverse flow and hx60 should be the s400 as far as piping goes. Seems like Jr Adkins is one of the only guys who likes the big holsets in twins though.
__________________
David
'02 3500 dually: Smarty/ tst ce/ mach4/ super 62/ helix 2/ 12mm arps / II Pump/ diaphragm sprung hub 3250 SBC dual disk
543/1040 uncorrected 1/12/08
Ph4tty is offline   Reply With Quote
Old 09-07-2007, 07:27 PM   #4
74dart
74dart's Avatar
Quote:
Why is that?
Old 09-07-2007, 09:30 PM   #5
Ph4tty
Ph4tty's Avatar
Dunno, seems to be his specialty.
Old 09-07-2007, 09:34 PM   #6
1-5-3-6-2-4
1-5-3-6-2-4's Avatar
Does Adkins have a website?
__________________
Luke
'06 Ford F450 CC Lariate 37" Toyos
'98 Freightliner COE C12 13spd LWB
'90 VW Jetta 1.9TD coupe wolfsburg
'73 Chevy RS/Z-28 454 M21
1-5-3-6-2-4 is offline   Reply With Quote
Old 09-07-2007, 11:18 PM   #7
HOHN
HOHN's Avatar
That's almost too tempting!!
OK, wisecrack moment passed.
My sense of humor might get me bannned-- apparently poking fun at vendors, whether they advertise or not is a
So, for now
submit to reddit
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.6
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
vB.Sponsors
Copyright 2011, DieselTruckResource.Com
Contacts Backup
