Go Back   Dodge Diesel - Diesel Truck Resource Forums > 1st and 2nd Generation Ram - Years 1989-2002 > Performance and Accessories 2nd gen only
Register Forgot Password?
Search
submit to reddit
Thread Tools Search this Thread Display Modes
Old 09-10-2007, 09:38 PM   #1
dodgediesel
dodgediesel's Avatar
Question Bottom Tapping Head Stud Threads????
Is this a real benifit? Most people say to bottom tap, install studs and then back the studs out a 1/4 turn before fully torqueing. I bottom tapped one so far and when I back the stud out 1/4 turn, the threads seem more sloppy than the one's I havent bottom tapped yet. Should I be worried about the studs stripping out if I continue with the rest? Also, why doesn't a guy tighten the studs in completely to prevent them from slowly wiggling back out or could that ever happen??? I'm just trying to get all the information now so when my head gets back from being o-ringed, I can be ready to do it right this time..
__________________
2012 Laramie 6.7L 4x4 SB Crew Cab Auto
3" Carli Backcountry 2.0
20" KMC XD Badlands
35" BFG All Terrains
MBRP Filter Back Duals
Custom Badging
Jamie
dodgediesel is offline   Reply With Quote
Old 09-10-2007, 10:32 PM   #2
97' CTD
I bottom tapped all mine working good so far.
Brandon
__________________
Brandon Bowersock
97' P-Pumped 24V
97' CTD is offline   Reply With Quote
Old 09-10-2007, 10:38 PM   #3
dodgediesel
Did you back the studs out 1'4 turn prior to torqueing them?
Old 09-10-2007, 10:45 PM   #4
blackdiesel
Registered
blackdiesel's Avatar
I didtn bottom tap either trucks that i installed studs on. (two different rigs)
backin the studs out 1/4 to 1/2 of an inch allows the nut to properly clamp down on the head. As opposed to the stud bottoming out and decreasing the clamping ability of the studs.
It makes sense in my head, just not sure if i explained it good enough. Somebody get HOHN in here
blackdiesel is offline   Reply With Quote
Old 09-10-2007, 10:47 PM   #5
dodgediesel
Blachdiesel, are you o-ringed?
Old 09-10-2007, 10:57 PM   #6
97' CTD
Yes, I backed them out 1/2 turn. I look at it this way you are this far do it should be no question. Im O-Ringed.
Brandon
Old 09-11-2007, 12:25 AM   #7
PourinDiesel
PourinDiesel's Avatar
If you bottom tap you'll never have to "back the stud out" because you'll have extra room with the new threads.
Not bottom tapping your wasting your time using studs.
__________________
123456
SMARTY POWERED!!
PourinDiesel is offline   Reply With Quote
Old 09-11-2007, 08:35 AM   #8
dodgediesel
Sorry to ask again but I want to get it right. So bottom tap and back them out 1/4 turn or bottom tap and tighten studs? I'm just afraid of having these wiggly head studs after I bottom tap them, it seems to really open up those threads. I have the correct tap size. Am I worrying too much???
Old 09-11-2007, 04:25 PM   #9
blackdiesel
Registered
No, im not ringed, but im also just running a smarty. Back in the day i was pushing 45 psi and 530 hp, so i studded the head.
If it makes them sloppy, i wouldnt bottom tap them. I can see the benifits, but they just dont justify the work. (IMHO)
Old 09-11-2007, 04:31 PM   #10
Tate
Tate's Avatar
If you turn the studs tight against the bottom of the block, you are already putting stress on the threads in the block before you've even began to tighten them. Different expansion rates of materials could make this even worse. Make it much easier to pull the threads out of the block.
__________________
'98 3500 4x2 Quad Cab, 24v, 5 spd, 3.55s, CDS 13mm, SDX 7x.012 Injectors, Single S480, Big Stick Cam, FASS, BD Short Shifter, SBC DD, Fluidampr
Alcoa Magnums, GM Brake Cylinders, HID Headlights, DSS
'98 2500 4x4 Reg Cab, 12v, 6 spd, 3.55s, 0 plate, 4k GSK, 18° Timing, SBC DD, F1 370's, GT37R/GTX42R Twins, Fluidampr
Alcoa H2's, Lorado Tonneau Cover, HID Headlights, Espar D5, EMS Hub Conversion
Tate is offline   Reply With Quote
Old 09-11-2007, 08:32 PM   #11
PourinDiesel
Quote:
If your making the threads sloppy then something is wrong. With the proper tap you should just be making new threads and thats it.
Old 09-12-2007, 04:46 PM   #12
blackdiesel
Registered
I put in one set of schieds studs for a guy, and their not ever threaded all the way to the bottom of the stud. the last 1/4" is just a little ball. You can go to their web site and see them. So bottom tapping would be worthless if you use theirs.
Old 09-12-2007, 05:34 PM   #13
CTD01
CTD01's Avatar
when u bottom tap with a good sharp tap it will cut to much meat out.then u r risking pullin the threads out of the block. when i did mine i just used a little oil and screwd them in and backed off a 1/4.
__________________
2001.5 Cummins 2500 EXT.Cab,DTT Auto,SLT,AEM Bruteforce Intake System,4 inch exhaust,6 Inch tip, QUADZILLA ADRENALINE RACE BOX, Dragon flow injectors, Htb2 62/65/12,Walbro GFS 392 fuel system, Cobalt boost,Cobalt Fuel Pressure, and Cobalt pyro, BFG 285/75/16, Pioneer Avic-N2 Navigation, Rockford Fosgate Punch P2s, JBL CS 200.1, clear corners,HID 10,000k Headlights, tinted windows, xm radio, ipod,Prodigy brake controller.
CTD01 is offline   Reply With Quote
Old 09-12-2007, 08:02 PM   #14
XLR8R
XLR8R's Avatar
To the OP - how hard did you hit the bottom of the hole with the tap? A quarter-turn too far can cause the thread tolerance to balloon.
Did you hit a clean (chip-free) bottom and back out the tap a few times on the way down to break the chips?
Like Justin posted, a properly tapped deeper hole will result in less stud "wiggle".
__________________
Lazar
Sleeps a flock of Rams & a Goat
GUN-HAPPY Crew Chief
XLR8R is offline   Reply With Quote
Old 09-12-2007, 08:21 PM   #15
Jfaulkner
Muted User
Jfaulkner's Avatar
Quote:
You've got to be kidding me! Unless your using the wrong tap (standard tap in metric hole, or wrong thread pitch) the correct tap will only remove material from where there aren't already threads.
Bottom line is if your using ARP studs, bottom tap them. If ARP didn't believe that the studs needed to be that long don't you think they would have saved material and the production time cutting the threads that long? Keep in mind shortcuts can lead to problems later. Ask Navistar how well the decision to only use 4 headbolts per cylinder on the 6.0L instead of the 6 everyone else uses. You could get away without doing it but then again you also could get away with only using 2 lugnuts per wheel. It's your truck.
Jfaulkner is offline   Reply With Quote
submit to reddit
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.6
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
vB.Sponsors
Copyright 2011, DieselTruckResource.Com
Contacts Backup
