Thread Tools | Search this Thread | Display Modes |
#1 | ||
Borgeson rag joint
#2 |
I put the borgeson in my truck, but I recall having 2 bolts and 2 pins.it was a direct bolt in unit.
__________________
Mine,92 ext. cab 4wd, fuel pin,3200 gov. spring, htt62/14 turbo, ddp stage 4 injectors. really big air filter, 4"exhaust with 5" stacks, borgeson shaft, 1 ton rear wheel cyl. .pump timing tweeked, o-ringed head,hasely head studs.full dtt trans. with 91% torque converter.2nd gen. lift pump.321/866 last dyno. also a member of the pull cable crew. Her's, 99 std. cab 4wd. 3 Guage pod, egt, boost, fuel preasure.3" over stock rough country front shocks, leveling kit. |
#3 |
I did mine a couple of years and remember having the same problem. I think I may have used the old pins, or did some crafty engineering to make it work.
or heck, the truck is right outside, let me take look. Hang on a sec. Okay, i'm back! Apparently, I used 2 new bolts with washers and nuts that came with borgesen shaft and then the old 12 point pins from dodge.
__________________
Matt Marchman 91.0 Dodge 3/4 4X4 W250 LE standard cab 4500lb axle D60fnt CTD Auto 3 speed non-inter cooled, 3200GOV spring, 3"straight pipe 350,000+ miles Top speed=88.5mph GPS verified! 8/27/07 |
#4 |
Thats pretty much what I decided to do. Where you used the nuts and bolts did you grind off those threaded nubs that the old pins screwed into?
Tim |
#5 |
I can't remember what I did to make it work, but I do remember thinking that it should have bolted up just like the old one did!! hehe.
Knowing my bad habits, I probably force threaded the new bolts thru the old threads and then torqued down the new nuts. I know, I'm not the best guy here to be taking advice from :P |
| Display Modes | |
