Thread Tools | Search this Thread | Display Modes |
#1 | ||
On Board Air
__________________
1997 CTD extended cab 4X4 5 speed. Towing package, SLT, BHAF, 4" straight exhaust Bought 4/28/07 |
#2 |
I used to put the tank and compressor under the right rear wheel well but now have it put into a truck bed tool box. I use quick-connect air fittings to connect everything together so I can remove the air tank most rickey-tick to fill up a tire or run my air jack without dragging 30 feet of hose around. I now use a simple 95-125psi air pressure switch from SquareD (Pumptrol) that works pretty well.
__________________
<---My previous oil burner // "Bombs delivered on time or your money back!" ------------2011 3500 SRW Laramie CC 4x4 LB Auto, 4.10. Sold: '01 2500 SLT Laramie QC LB 4x4 Auto 3.54 gears, 248,881 miles. Goerend w/billet input shaft, ARP head studs, 4" exhaust, Edge Juice with Attitude, Walbro 392 with Swagelok bypass, Yokohama Geolandar A/TS 265/70R17s on 2006 H2 LE Alcoa wheels, '03 Big Brakes F&R, PSC Steering Stabilizer. |
#3 |
i bought a little 12v pump made for these air ride trucks and found an old air tank the tank is under the passenger bed side and i put the pump under the bak seat to keep it out of the weather works great for tires or my air horns whatever. Easy instal dont forget to use a relay when you wire it
__________________
2005 600HO 4x4 DRW Auto 6" skyjacker 3"body lift. custom rear diff guard. Welded on ROADARMOR bumper. 6"stacks built not bought straight piped. mp-8, AFE int, bypass oil filter. Full built DTT. , 10" SUB CUSTOM BOX. 65 gal stainless steel fuel tanks under bed(built not bought) + the stocker. 3 air horns, 4 gal air tank with hose outlet. AND MORE and yes i tow all the time NRA LIFE MEMBER GOD BLESS AMERICA |
#4 |
I wound up getting a dive tank free from craigslist and bought a small compressor that looks like this: http://cgi.ebay.com/HIGH-VOLUME-AIR-...lenotsupported
I would like to mount the tank and compressor under the bed somehow. I figure I could make a bracket for the compressor and use some sheet metal to make a shroud around it to protect it from rocks and water splashes. I don't want to put it under the back seat because I use that area all the time for storage and cargo. Anyone have pictures of how they mounted their system? |
#5 |
I mounted my Viair compressor inside my in-bed tool box and ran the air line to the front to my Grover air horns.
My tank also has a quick disconnect for my 25ft. air hose. My system works very well and my air horns really gets the point across !!! My air horns works so well that my wife demanded that I put a set on her Chrysler Sebring who now loves to scare drivers that get to close to her.
__________________
2001.5 Dodge Ram 2500 4x4 - QC, 24V, AT, SB, Aux. Fuel Tank, Phantom Gauges, Bright Box, Sport Headlights - BFG 315's/Amer. Eagle 102's, BW Pocket flares, Skyjacker D25's, MBRP/Magnaflow - R.H. Bumpers w/PIAA 520i's, Warn Winch, Bilstein 5100's, AFE Stage 2 - Vulcan Big-Line/FASS/Raycor, Grover Air Horns, Mag-Hytec Covers, DT Links - Smarty, ATS Stage IV, HTB2 62/65/13, DDP-110's, PB Air Bags, Pusher Intake "Gas is something you pass through your A.... NOT your Truck... Got Diesel !!!" |
#6 |
Where did you get a solenoid for the air horns? A friend offered me some horns that he didn't like because he was susing a manual valve and he said the horns sounded funny because he coudln't open the valve fast enough.
If you know a source for a solenoid valve please post it. |
#7 | |
Quote:
I used a toggle switch inside my truck connected on the ground side of the 12valve to arm the horns or to toggle back to the stock horn (in case of a problem with any police City ordinances or when going to a car wash ect..). I just checked eBay and the exact type I purchased is listed as per below for $45. I paid around $20 earch for mine and have worked perfect since 2006: "ASCO SOLENOID AIR VALVE 3/8" AIR RIDE SUSPENSION 12V" http://cgi.ebay.com/ebaymotors/ASCO-...Q5fAccessories I found that Grover Air Horns are by far the best. I recently purchased a brand new "EMERGENCY" fire truck air horn made by Grover and plan to bolt it up soon with my other Asco 3/8" 12v solenoid valve. This one definetly would require a "Toogle Switch" between it and my stock horns because of its sound and city ordinances !!!! Or, you could go to your neighboorhod Custom auto. shop where they sell/install air bags and purchase one or something very similar. Hope this helps ! |
| Display Modes | |
