Go Back   Dodge Diesel - Diesel Truck Resource Forums > 3rd Generation Ram - Years 2003 and up > 3rd Gen Engine and Drivetrain -> 2003-2007
Register Forgot Password?
Search
submit to reddit
Thread Tools Search this Thread Display Modes
Old 11-22-2008, 04:32 PM   #1
BMH95
BMH95's Avatar
Block heater problems???
I changed the water pump and drive belt this week, and might have killed my block heater. I drained the radiator / motor of coolant completely, then realized after 15 minutes or so that I still had the heater plugged in. So I unplugged it and didn't think much of it. I did the pump and belt later that night and took the truck for a test drive, and all checked out ok. I plugged the truck in when I was done for the night and popped the fuse. I've put in a new heater cord, tried different house circuits, and switched extension cords. It pops the GFI breaker instantly when I plug it in. Did having it plugged in with no coolant short the heater somehow? I don't understand it though, because it wasn't popping the circuit when it was plugged while empty. Is there something else that could be causing this?
__________________
2005 CTD Quad Cab Shorty
"They that can give up essential liberty to obtain a little temporary safety deserve neither liberty nor safety." - Benjamin Franklin
BMH95 is offline   Reply With Quote
Old 11-22-2008, 04:52 PM   #2
Topper
Topper's Avatar
Sounds like you burnt it out. (Over heated) You opened the circuit and it wont short out when the block is empty but when you add coolant it shorts and pops the breaker.
Topper
__________________
06 dually
Bored 40 over
Issopro egt,boost & trans temp
Zilla FP & RP
Single shot of Nitros
Smarty TNT
Hamilton big stick
#110 lb springs
II PS62/S474 twins
FASS
2 mic ff
Arson III
DDP 90's
fluid dampener
ARPs (625)
EEP pressure by pass
Generation 2 1 micron oil bypass filter
Full Goerend built trans w/converter
BD flex plate
Leveled
35s
AFE Blade Runner Intake
S&B cold air intake
Magnaflow 5' SS dual exhaust.
Firestone R R
RBP Grille
Topper is offline   Reply With Quote
Old 11-22-2008, 05:27 PM   #3
Jeff in TD
Jeff in TD's Avatar
Take an ohm meter reading between the two prongs, and between each prong and the ground.
I want to say it should be around 7 ohms...
__________________
06 Inferno Ram dually Laramie 4x4, stick, jake, B&W, BrakeSmart.
Tows 394F Patio Hauler w/ Honda 500 Foreman, and 680 Rincon.
Jeff in TD is offline   Reply With Quote
Old 11-24-2008, 08:01 AM   #4
BMH95
BMH95's Avatar
So what's the replacement process on these? Are they threaded into the block, or is it a clamp on freeze plug style? I just spend a load of cash on coolant last week, and don't want to loose more than I have to. I want to pull the old one and slam the new on in as quickly as possible so I don't have to replace more fluid than is necessary.
Old 11-25-2008, 09:47 AM   #5
BMH95
BMH95's Avatar
Where do I get a replacement that isn't $90?
Old 11-25-2008, 04:30 PM   #6
spitfire9137
It list on Cummins website for about $30. I assume the $90 you have is from dodge. Looks like you need to find a Cummins dealer near you.
__________________
Mine: 03 2500, 305/555 48RE, Quad, LB. Remote start, 4" Stainless Exhaust with Magnaflow muffler and MBRP tip, Kilby Condenser Guard, BD Steering Brace, Autometer fuel, boost, pyro, and trans temp gauges. Front windows tinted to match back. Raptor 150, Smarty Jr, ATS Pulse Flow, HE351.
Dads: 98 12v 5spd Stock...
spitfire9137 is offline   Reply With Quote
Old 11-25-2008, 04:41 PM   #7
BMH95
BMH95's Avatar
I cannot find any parts on their website? What am I doing wrong?
Old 11-25-2008, 04:48 PM   #8
BMH95
BMH95's Avatar
never mind
Old 11-25-2008, 05:38 PM   #9
spitfire9137
I guess you found the QuickServe part of the site? It lets you buy parts from there. I never have so I don't how easy it is.
Old 11-26-2008, 09:28 AM   #10
BMH95
BMH95's Avatar
I found the part. The site is cool, in that it gives you diagrams and schematics on parts you are looking for. The problem I have, is that I can't see prices or a way to actually order a part????
Old 11-26-2008, 09:30 AM   #11
BMH95
BMH95's Avatar
Here's a picture of the block heater that the sight says matches my engine (based on serial number)
Click the image to open in full size.
submit to reddit
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.6
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
vB.Sponsors
Copyright 2011, DieselTruckResource.Com
Contacts Backup
