#1 |
Blew apart both of my Bilstien 5100's.
After about a year and 75,000 kms my shocks had a complete come apart. Literally! What gives. Absolutely nothing out of the ordinary. Doing the same job for about 200 days and my shocks decide to do this.
Very strange.....
__________________
John Fort St John B.C. Canada 1998 12v, 4X4, QC, DTT 91% auto, 3.54 gears, TST #10, 370's, 3k GSK, PDR HX 40, 191's, 4 inch exhaust, Isspro boost/pyro/tranny gauges, 15.5 timing, Afe MC, Mag HT tranny pan. 04.5 4x4 3500 SRW LB 6-speed. Smarty Jr. & Hot Juice with Attitude. Carli starter kit, Kore control arms. |
#2 |
The 1st pic is the drivers side obviously and the 2nd pic is the passengers. Forget Baja testing..... Send your stuff up to the oilpatch in northern bc!
#3 |
That sucks. Thats also a pile of snow!
__________________
'98 3500 4x2 Quad Cab, 24v, 5 spd, 3.55s, No Plate, 4k GSK, 23° Timing, DDP Comp Injectors, Silver Bullet, Big Stick Cam, FASS, BD Short Shifter, SBC DD, Fluidampr Alcoa Magnums, GM Brake Cylinders, HID Headlights, DSS '98 2500 4x4 Reg Cab, 12v, 5 spd, 3.55s, 0 plate, 3k GSK, 15° Timing, SBC DD, F1 370's, 64/71/0.80 Turbo, Fluidampr Alcoa H2's, Lorado Tonneau Cover, HID Headlights, Espar D5, EMS Hub Conversion |
#4 |
i have see that before , happens in the cold ,
__________________
1975 VE 4X4 NV4500, awaiting twin's amd p-pump 1995 AUTO 4X4 waiting for trany all work no play for a few months ROB WINKWORTH IS THE REAL NAME |
#5 |
Was about -3 yesterday. Went through -45 last winter. I dunno!
#6 |
oh well i have seen it when they get water in them and they do that when they freeze ,,,,
#7 |
Send that weather south, I want snow. Sorry to hear about your shocks, Have you contacted them, I would call that catastrophic failure.
__________________
98.5 2500 QC SB Laramie 24v 5spd 4x4 stock 2002 Audi A4 Sport Quattro 5sp |
#8 |
I will be calling the guy who I bought them from tomorrow. Might have to send back my carli anti-sway bar links. The heim joint in them is in rough shape as well.
#9 |
Try the 2.65's
__________________
1994 12 valve 4X4 Fully loaded Carli Suspension with 3" Kings Suncoast full billet trans converter & Flex plate HX 40 370 injectors Snow Performance Meth h20 injection 315-75-16 Pro-Comp Extremes Wilco tire carrier Keeps up with the traffic!Thanks to Old Man Bob 4X4 & Pablo |
#10 |
I am not opposed to trying newer better parts..... Will look into these 2.65.
#11 | |
Quote:
plus i run my 5100 reverse of what you have yours installed ,iwas kinda worried about water and grime build up .I was assured they could be run the opposite of what you are running yours
__________________
1992 4x4 Reg cab LE 5 speed Skyjacker 4 Inch lift Bilsteins shocks 5125 Shiny new VE moderately molested Dana 80 Mod ultra wheel rims Type 164 ASA Modified pipe BHAF 19037 Outerwears prefilter Advanced adapter nv4500 & Bell housing South bend Flywheel and clutch 13125-OK |
#12 |
Swamp, hopefully you have a warm garage to repair the truck in. That looks alot like winter
to me. Isn't winter driving in the oil field so much fun. Good luck with the repair.
__________________
02 sport QC, SB, 3/4 4X4 DDP stg 3 sticks, back to single little tiny turbo GT3782R -Kore Recon and a few DSS parts stuff on the front. -Half worn out DTT Race tranny and the cruise control still works. -2500 watts stereo, four amps and twelve speakers cranked to the limit |
#13 |
I haven't been sold on Bilstiens yet. I have had good luck with lesser cost shocks..
__________________
97 2500 4X4 LWB CC SLT Laramie 5spd LSD 3.55. Isspro EV's pyro/boost, #10 Plate, PEAK 3K GSK, AFC Spring, DDP III injectors, S300 Turbo, PEAK IC Boots, TAG III, South Bend 13-1.25" Con FE clutch, SCOTTY II-UNI, MBRP XP 4", KDP Tab, 16° Timing, SS DSS / 03TBK, Roda Deaco PAS. Espar D5WSC heater. B-Quiet sound deadening inside. Dyno 09-2009 401 RWHP / 1050 Ft-lbs '08 2500 4x4 MegaCab Laramie, 6.7, 68RFE, 3.73 LSD, S-67ME POD. Alberta Chapter #5 Prez... PM me for details... |
#14 |
I like the ride from my Bilsteins 5100's, but now thanks to Swamp I worry.
#15 |
i would not worry to much about the quality of the 5100's. I think they were to short to begin with and finally had enough..... Going to order longer shocks tomorrow.
| Thread Tools | |
| Display Modes | |
