Go Back   Dodge Diesel - Diesel Truck Resource Forums > General > General Diesel Discussion > Fuels / BioDiesel / Diesel Prices
Register FAQ DTR Store Members List Mark Forums Read
Thread Tools Display Modes
Old 09-06-2005, 09:14 PM   #1
chevyryan6
chevyryan6's Avatar
Question running used oil
i've read a couple of threads on running used oil, curious as to mixture, filtering, smoke level, power gain/loss, etc. any info i could get would be great.
__________________
2001 3500 4x4 cold air, tst stage 3, crimped wastegate, straight pipe, heavy right foot alternate email address: chevyryan6@yahoo.com
Last edited by chevyryan6 : 09-06-2005 at 09:46 PM. Reason: already alot about biofuel
chevyryan6 is offline   Reply With Quote
Old 09-07-2005, 12:23 AM   #2
tempforce
tempforce's Avatar
using wvo
be sure to let it settle for a couple weeks. then filter the oil on top of the crud, down to 5 microns, prior to use.
i'm using a rv water pump and a house filter.
this time of year, if your up north you may need to start using a heated system in the mornings or a blend with #2.
i've been running 100% wvo all summer in a idi engine. next fill up will be 70-75 % wvo as the nites are getting cooler here in the west.
remember wvo is not bio-diesel and using it is at your own risk.
tempforce is offline   Reply With Quote
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.6.7
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
vB.Sponsors
Copyright 2003, DieselTruckResource.Com
