Go Back   Dodge Diesel - Diesel Truck Resource Forums > General > General Diesel Discussion > Fuels / BioDiesel / Diesel Prices
Register FAQ DTR Store Members List Mark Forums Read
Thread Tools Display Modes
Old 08-17-2005, 02:39 PM   #1
roguesteelhead
roguesteelhead's Avatar
Question Bio fuel
Is anyone running Bio diesel in there truck that are still on warrenty? What does DC say about it ? The dealer here sayed they would not warrenty anyting that was fuel related so that could be the whole motor and fuel system. With diesel over 3.00 a gallon here and headed for 5.00 I would like to run Bio but my new truck only has 1700 miles on it so I would not want to kill the warrenty. So I may just put it in storage . Thanks for any help . Pete
__________________
05 3500 SLT Dually,pearl molten red, 4x4, quad cab, HO,NV 5600 6 speed, 3.73 gears anti spin,Eagle alloy wheels, Tinted fr windows,Astro color matching canopy,4 Carr black powder coated steps,F&R Husky Liner mudflaps.Towing a 2006 Arctic Fox Siver Fox Edition 29 V TT.
roguesteelhead is offline   Reply With Quote
Old 08-17-2005, 03:03 PM   #2
mestdagh
Any vehicle manufacturer only warranties 5% bio. Since it seems to be a standard figure between DC, Ford, GM and VW, there's probably a reason behind it. (Yeah, they don't want to stick their necks out.) I'm sure you could use a higher % (I have.) but if they do a fuel test you might be SOL.
Here's some interesting reading from the Cummins site "Cummins' position on the use of Biodiesel fuel in Cummins" -->
http://www.cummins.com/sa/pages/en/c...F080C4A8F00000
One statement sticks out:
"Failures caused by the use of biodiesel fuels or other fuel additives are NOT defects of workmanship and/or material as supplied by Cummins Inc. and CANNOT be compensated under the Cummins' warranty."
__________________
2005 2500 SLT Quadcab shortbed 4x4 6speed 325/610 3.73 NV5600
My off road package: air dam removed, xfer case & fuel tank skid plates, Line-X rockers, Warn 4x fender flares, Toyo A/T 285/75R17 E rated
PIAA reverse / rear lights
mestdagh is offline   Reply With Quote
Old 08-17-2005, 03:14 PM   #3
Lightman
You guys are both missing the picture totally, no offense. If you have ANY fuel related problem, it's YOUR DIME! No manufacturer will cover a repair that occured due to a bad tank of fuel, it doesn't matter if it's b5, b100, dino, or mouse-pee. If you put something in the tank that messes up the engine, you are responsible, period. So the real question then is, do you trust biodiesel enough to run it in your engine, or any other fuel for that matter?
I have run up to b50 in my truck, although b20 pay at the pump is going to be more frequent for me now, since one just opened up in my area.
Lastly, your dealer doesn't need to know what's in your tank and I wouldn't say the 'b' word anywhere near them. We all know how the dealerships will try to blame anything they can to deny a warranty claim.... ie. your a/c isn't working? Sorry, you have an aftermarket exhaust, your warranty is void
__________________
2004 2500 4x4 HO/48RE Laramie/Sport - Line-X, Jordan, Wet Okoles, Dynamatted, Invinca-shield 3M clear bra, Scotty's intake, Mopar flaps & liners, PIAA's, 4" Exhaust, RDS 51 Gal Tool/Tank Combo, Amsoil Oil Bypass System, Boost/EGT/FP Gauges, Edge Hot Juice, Super-B, Kore Suspension/Weld Wheels, 35" Toyo Mud Terrains, full DTT trans w/billet shafts, MITUSA fuel system.
Lightman is offline   Reply With Quote
Old 08-17-2005, 05:35 PM   #4
P.J
P.J's Avatar
Can you run mouse pee? Whats the MGP's like?
For real though, I would think that commercially blended bio's should be safe.
Now, if you have done something stupid while whipping up batches in your brother in law's basement, it's an ethics mater on the one trying to get warranty coverage......
P.J is offline   Reply With Quote
Old 08-17-2005, 07:23 PM   #5
Lightman
PJ I havent tried it Again though, what fuel you run has absolutely zero to do with warranty coverage.
Old 08-18-2005, 11:12 AM   #6
realsquash
realsquash's Avatar
Send a message via Yahoo to realsquash
The Cummins site seems to be really poo-pooing bio. Seems to fly in the face of common "knowledge".
Andy
__________________
2003 4x4 QC/HO/6-speed/4.10
realsquash is offline   Reply With Quote
Old 08-18-2005, 04:46 PM   #7
Lee S
Lee S's Avatar
When you consider that some guys are running used engine oil in their diesel....?
__________________
2005 Dodge 3500 Laramie Quad Cab, DRW, Cummins.
Lee S is offline   Reply With Quote
Old 08-18-2005, 05:38 PM   #8
Lightman
Realsquash Cummins is actually pretty positive in their statements about blends up to b5, and in the end if you read thru the lines you'll realize their stance on anything up to b20 is pretty neutral. They say they haven't tested it extensively(however many years ago they wrote that statement), but in the limited testing they've done they encountered no issues. I'm not sure about common knowledge, but my experience is that I've run b20-b100 in three vehicles now since 2001 and haven't had any issues.
Lee also makes a good point, consider this is an ASTM certified fuel that people are so worried about, compared to running used engine oil which cummins approves up to 5% also..
Old 08-19-2005, 09:16 PM   #9
larryt
larryt's Avatar
If ever we needed a national biodiesel incentive it is NOW!
__________________
2005/2500/2wd/sb/610 CTD/QC/3.73/LS/NV5600
addons such as Buckstops, GDP 391 Walbro & 2micron bigline filter, Ravelco , JimmyJammers , Amsoil EAa189 air filter, Isspro gauges, Smarty Jr, etc
larryt is offline   Reply With Quote
Old 08-19-2005, 09:40 PM   #10
bulabula
bulabula's Avatar
Quote:
I second that motion!
__________________
Chris, USN (Ret.)
'03 2500 SLT QC 4x4 short bed, HO, NV5600, 4.10LS, 4" SS exh; H2/35" Yoko's
'06 VW Jetta TDI, 5-speed
'01 VW Golf TDI; 2 Door, 5-speed
Maryland DTR Chapter #33
Feelings of inferiority and superiority are the same - they both come from fear
bulabula is offline   Reply With Quote
Old 08-20-2005, 06:38 AM   #11
Ramasaur
Would it hurt to run a couple of gallons of filtered WVO with a full tank of fuel? My neighbor goes through at least 10 gals a month....
__________________
06 MegaCab 2500, 48RE, 325X60R18 Nittos Terra Grapplers, AFE Stage II, everything else stock...for now
Ramasaur is offline   Reply With Quote
Old 08-20-2005, 08:39 AM   #12
MikeyB
MikeyB's Avatar
There is grant money available for starting up biodiesel production from the EPA.
MikeyB
__________________
2003 2500 2wd SWB Quad Cab Laramie, 305/555, NV5600, 3.73LS, Line-X, Westach boost/EGT combo gauge, Fogzilla mod, PML diff cover, Airbox mod w/Amsoil Ea, Hurst 6spd Shift knob, Adjustable boost elbow, Toyo OC AT 285/70/17 E, Daystar 1.5" lift, Monroe Reflex, Raptor RP100, Lazarsmith Intake Horn, Headlight wiring upgrade
SMARTY/Van Aaken C3.2
2005 Dodge Magnum RT (Wife's ride)
2008 Dodge Caliber RT (Daughter's ride)
1990 HD FXSTS
MikeyB is online now   Reply With Quote
Old 08-20-2005, 10:43 AM   #13
realsquash
realsquash's Avatar
I'm not trying to kill bio here, but unless the manufacturers support the stuff it's never going to take off. From that page:
In addition, from Cummins' fuel systems suppliers, the following issues are also noted: swelling and hardening/cracking of some elastomer seals within the fuel system/engine, corrosion of fuel system and engine hardware - especially aluminum and zinc, solid particle blockage of fuel nozzles and passages, filter plugging, injector coking, higher injection pressures due to physical flow properties - reduced fuel system life, added stress and heat to injection components - especially rotary fuel pumps - increased pump seizures and early life failures, poor fuel spray atomization - reduced fuel economy. Pure biodiesel fuel is not stable and its acid content increases over time which can damage powder metal components.
So how does that make anyone want to run their $40k truck on bio in any concentration? Is bio really not as great as everyone makes it sound? Is that why it's not coming to market with any speed?
B5 is the same thing as running crappy #2 to Cummins. I suspect the only reason they say 5% is ok is due to the fact that straight #2 can probably have 5% of other stuff in it and run fine. So if that 5% of crap in #2 happens to be bio, it should be fine, too. Same goes for the waste oil that people use. You could probably emulsify 5% water in that #2 and it would run fine, too. That's half a gallon for every 10.
That said, I would stick my head out and run B100 all summer long if I could find the damned stuff! The closest place to me is an hour drive, one way, and they only have B11, and the price is the same as straight #2 (B0?). I've heard of a retail place in Batavia, IL that has B100 but that's hours away. If I lived on a farm I'd get the stuff in quantity and store it at home but I can't do that.
Andy
Old 08-21-2005, 11:51 AM   #14
STATELINE
STATELINE's Avatar
Maybe someone who is a little more computer literate than myself could start a thread where we could sign on some sort of a petition & send it off to the powers that be. doubt it would do any good, but I'd be willing to try
__________________
2001 Ram 2500, auto, 3.54's, quad cab, boost, fuel, & pyro gauges, Qzilla XZT+, Magnaflow 4", FASS DDRP
The Womans Ride...2005 Jeep Liberty Limited CRD, not a Ram, but a sweet ride
pride & joy... 2007 Victory Vegas Jackpot Arlen Ness Edition
Originally Posted by Gotlift01
........and if anybody disagrees on that you earn the right to be slapped in the back of the head.
STATELINE is offline   Reply With Quote
Old 08-21-2005, 07:18 PM   #15
ckennedy
Andy
Realquash - where did you get this qoute from.. just wondering and would like to read the stuff/article... thanks..
__________________
04.7 2500 CTD 325/600 White/Slate quad cab Lone Star Edition, 4 speed automatic 4X4 with manual transfer case, white camper shell, autometer 4 gauge "windshield" pod with di pricol pre/post egt boost trans dual porb. switch gauge.
ckennedy is offline   Reply With Quote
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.6.7
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
vB.Sponsors
Copyright 2003, DieselTruckResource.Com
