Go Back   Dodge Diesel - Diesel Truck Resource Forums > 1st and 2nd Generation Ram - Years 1989-2002 > 1st Gen. Ram - All Topics
Register Forgot Password?
Search
submit to reddit
Thread Tools Search this Thread Display Modes
Old 08-19-2006, 02:18 PM   #1
smoky beast
smoky beast's Avatar
BHAF longevity
what is the change interval for BHAF?
all help is appreciated
__________________
'94 2500, NV 4500,2 wd,3:55 gears,reg cab,charcoal grey,#100 plate, 4K rpm GSK,BHAF,Isspro pyro & boost
'91 D250, Getrag,2 wd,3:55 gears,reg cab,non IC,AutoMeter boost&pyro,3200 rpm spring,PDR fuel pin,starwheel,fuel&smoke screws fully cranked,ASA intake,HTT stage III, 4'' dp to 5'' turnouts
"A man can always use just a little bit more horsepower" - Chris LeDoux
smoky beast is offline   Reply With Quote
Old 08-19-2006, 02:28 PM   #2
blackdiesel
Registered
blackdiesel's Avatar
i think it was HOHN, but he said that they should last 50,000 or 60,000 miles. all depending on your driving conditions of course.
Dont change it just because it "looks" dirty. Mine "looked" dirty within the first 5,000 miles. Dosnt mean its clogged....
blackdiesel is offline   Reply With Quote
Old 08-19-2006, 05:51 PM   #3
12valve@heart
12valve@heart's Avatar
A filterminder is the best way to tell but it will last a lot longer if you use the Outerwears cover to keep the chunks out.
__________________
Jay
'92 D250 Ext. Cab non-LE (manual windows & locks, rubber floor mat, steel headliner), CTD, MU0090 Ralley, Getrag rebuilt by Jay, 3.54, 18.5 cm, D-Celerator exh. brake, BHAF/Outerwears in Old Smokey Mount, head and tail lights on relays, 3” shoes & GM wheel cyls, Tach-Boost-Pyro-Oil Press-Volts-Water Temp-Air Press-Trans Temp-Fuel Press Gauges, Pump bump and KDP dead thnx to WannaDiesel, '93 Jayco 3500FS TT in tow, 300K and counting
'94 Vogue Prima Vista, 8.3L Cummins, Allison MD3060
12valve@heart is offline   Reply With Quote
Old 08-19-2006, 06:09 PM   #4
mr T
ive had mine for 2 years...and i plan on at least another year
__________________
SOLD:
1995 CTD 2500, 4x4, long box, ext. cab, BLUE, 3.5 rear, 47RH, 363 000 km, WAAG bush guard, 285/75/16 tires
3K GSK
homemade #10 plate
BHAF
silencer ring MIA
wastegate blocked
5" stacks
15.5* timing
TC lock-up switch
mr T is offline   Reply With Quote
Old 08-20-2006, 05:36 PM   #5
Marine
Marine's Avatar
I ran both of mine 50,000 miles, and could have gone more.
__________________
Mike
2001.5 2500 4x4 QC, Comp, NADP 91% Single Disk TC and Series 450 Trans., Pulse/Adrenaline, Amsoil Nanofiber 4510 Air filter, Vulcan Performance and GDP Fuel System, Tow & Camp Pkg, JRE 4", Isspro EGT, Boost and Trans Temp, Nordskog Digi. FP Gauge, HTB2 62/13SS, HTT Pulse Manifold, Silicone boots, DDP 95 HP Sticks. BMK-11 Bypass Amsoil throughout. NRA Member and Instructor.
"Make no mistake, our freedom will be defended." GWB
Marine is offline   Reply With Quote
Old 09-03-2006, 11:24 PM   #6
1st gen Hobie
1st gen Hobie's Avatar
Quote:
Any info on a filterminder?
__________________
1993 D350 5-Speed, Dual 5" turnouts, Pyro, Pod's,BHAF, pump tweeked, Fixed KDP.
1992 D350 5-speed Parts truck
1st gen Hobie is offline   Reply With Quote
Old 09-03-2006, 11:52 PM   #7
flashgordon
flashgordon's Avatar
Quote:
any dealer should be able to get you one....99 and newer....thay may have used them before then but 99 and up for shore! Probabley want more for them them there worth!!
__________________
91.0 non intercooled 3/4 ton 5sd ex.straight piped HX35, timing bumped 1/16...Pump mods have started Full power screw1/2 max with out removing the collar. Gear Vendor over drive!
Finally finished 2nt gen intercooler turbo and Coolertubz, By Tim (TWorline)" write-up here:http://www.dieseltruckresource.com/d...d.php?t=186908
flashgordon is offline   Reply With Quote
Old 09-05-2006, 05:14 PM   #8
1st gen Hobie
Quote:
How would I put one on a 1st gen?
Old 09-05-2006, 05:27 PM   #9
wannadiesel
Cut a hole in the intake tube and jam it in there. They are grommet mounted.
__________________
Faith
'93 D350 - DPS 6x16's, HTT Stage IV/14wg, PowerStroke IC, Snow water/meth, Walbro 392, Con-FE, pump tampering by owner.
390 HP/800 TQ on #2 only, 413 HP/852 TQ w/ water/meth - needs more air!
Dead KDP's = 72
wannadiesel@dieseltruckresource.com
wannadiesel is offline   Reply With Quote
submit to reddit
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.6
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
vB.Sponsors
Copyright 2011, DieselTruckResource.Com
Contacts Backup
