Main Page Classifieds Tech Facts Member Photos Articles Links Forums Chat
Go Back   Dodge Diesel - Diesel Truck Resource Forums > 1st and 2nd Generation Ram - Years 1989-2002 > 2nd Gen. Dodge Ram - No Drivetrain
Register FAQ DTR Store Members List Mark Forums Read
Thread Tools Display Modes
Old 11-02-2009, 08:13 PM
Silver R/T's Avatar
Silver R/T Silver R/T is offline
Send a message via AIM to Silver R/T Send a message via Yahoo to Silver R/T
Better mpg with O/D off or on?
I do most of my driving in the city 30-35 speed limit. I was wondering if I should leave O/D off or on as sometimes I do drive 40mph and those rpm's are getting bit high. Would I see better mpg with O/D off or on?
__________________
68 Dodge Charger R/T
95 Ford Mustang Cobra SVT
01 Ram 2500 QC LB, auto, K&N air filter.
Old 11-02-2009, 08:16 PM
hamilton71801 hamilton71801 is offline
Leave it off if your just running 30-35mph. Its not good to lug the engine and its definately lugging at those speeds in OD.
__________________
Mine
2001.5 Dodge Quad Cab 4x4 Auto Cummins
HTS Ultimate Duty Tranny, Straight piped, Puke bottle relocation, Stage 3 Nozzles, BD J Hook, Vulcan Big Line/Relocation Kit, Quadzilla XZT+, Lock-up Switch
Dipricol Optix trans, pyro, fuel pressure on A pillar, Boost gauge in cubby hole
Jordan Ultima 2020
Hers
2003 QC HO 4x4 Auto Short Box...stock and stayin that way!!!!!
Maxbrake
Ours
Coachman SOA 299TT
1978 Glastron Carlson (115 Merc, Hotfoot, completely restored)
'09 Polaris RZR
Old 11-02-2009, 09:58 PM
Silver R/T's Avatar
Quote:
truck is unloaded and I'm going on flat roads most of the time, why would it be bad for it since cummins has so much tq down low. I would think it would be fine for it to use low end torque...
__________________
Old 11-02-2009, 10:52 PM
jay_d's Avatar
jay_d jay_d is offline
itll eventually stop it up and itll be weak as crap...plus i know they waste fuel like that, look at the tail pipe the next time you lug it...black smoke galore. detroits like to be lugged around...cummins like to be operated at around 1800-2500 rpm.
__________________
1998 club cab slt long bed 4x4: red with new paint, bhaf, straight pipe, 35x12.50s on weld typhoons.
Old 11-03-2009, 10:45 AM
infidel infidel is offline
It's no problem lugging down the Cummins, problem is your tranny won't last long locked in OD at low speed.
Leave it off until you're going at least 55.
__________________
Bill
'95 2500 4x4 auto
'95 3500 5 speed flatbed hauler
stock for one day
Old 11-03-2009, 08:01 PM
Silver R/T's Avatar
care to explain how it's bad for trans? I'd like to know what's going on when O/D is working/off and how it affect trans.
__________________
Old 11-03-2009, 10:17 PM
I believe it has to do with line pressure which operates off rpms. The lower the pressure, the worse it is on the tranny...I think. Someone will chime in with the correct answer.
__________________
Mine
Jordan Ultima 2020
Hers
Maxbrake
Ours
Coachman SOA 299TT
'09 Polaris RZR
Old 11-04-2009, 01:55 AM
Dinner's Avatar
Dinner Dinner is offline
That's correct^^ The lower the RPM, the lower the line pressures for the transmission as well as the TC circuit. When you are putting around, lugging the engine in O/D. There isn't as much line pressure going to the TC to keep it locked up compared to if you waited until 55mph. Torque Converters like high fluid pressures.
For the original question, I believe if you wait until 50-55mph you will net better fuel mileage. Main reason being is you aren't lugging the engine (puts more load on the engine which in turn fuels the engine harder).
__________________
2001 Dodge Ram 2500 CTD QC SB 4X4: Goerend Trans with Billet Flex & Billet Input / Airdog 100 / Gauges / ScanGauge II / BHAF / Draw Straw / HTT Exhaust Manifold / 4" Straight to 6" Stack / Smarty & TST PM3 Comp Stack / DDP Stage 3's / HTT 62/71/14.
Old 11-04-2009, 08:24 AM
blackimpala blackimpala is offline
OK, i don't understand I though that the OD didn't come on until 55MPH If that is the case how will it hurt to not touch the button and let the transmission or computer control itself.
Floyd
__________________
96 4X4 Auto, Gauges, Full time power windows, headlight relays, By-pass filter, KDP Done, Lukes Link, GM Wheel cylinders, removed fuel heater.
I need no stinking chips.
For those who fought for it Freedom has a taste the protected will never know.
Old 11-04-2009, 11:02 AM
Mph when OD locks varies between vehicles.
It supposed to be 50 mph but I've seen many lock at 45.
More of a problem than when it locks is when it unlocks.
On my own rig once it's locked it won't unlock until 30 mph or less unless I give it a bunch of throttle.
__________________
Bill
'95 2500 4x4 auto
stock for one day
Old 11-04-2009, 04:41 PM
Hodge Hodge is offline
If you are in OD or T/C lockup at such low speeds, your oil pressure will also be much lower due to the low RPMs. I personally feel that it is better for the engine to operate within its torque curve, with the oil pressure up where it should be.
__________________
1994 Ram 2500 4WD 12v Cummins 47RH auto
Romans 1:16- "For I am not ashamed of the Gospel of Christ...)
Old 11-04-2009, 11:49 PM
dguru dguru is offline
If you increase the pressure regulator pressure to at least 75 pounds you don't have to worry. Stock pressure is the reason for failure. A TFOD diesel transgo kit and increased line pressure is the best thing you can do for your tranny. Or if you are made of money you could get a performance valve body.
I have a gauge on my tranny and it stays at 75psi minimum when in drive. I see 90+ when cold. I may increase the pressure more next time I have the pan off. Stock is 45psi. My CL locks at 45mph.
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.6.7
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
vB.Sponsors
Copyright 2003, DieselTruckResource.Com
