Thread Tools | Search this Thread | Display Modes |
#1 | ||
#2 |
Best for what??? I like the 100hp for all-around and extreme for real fun. 100 is all a stock auto will take. You might also need turbo and exh. upgrades to keep egt down. Make sure everything is turned off on the truck then plug it in and the display will walk you thru the steps. Craig
__________________
03 QC dually, 4wd - all on the rear, HO 6sp, 4.10 LS, Phat Shaft 62/65/14 w/4", TST/PMCR, GDP 391 Walbro, 2 micron, Oilgaurd Bypass. In-line Pacbrake, Firestone bags, Rancho 9000s and onboard air/in-cab controls. Relocated batteries. Two BHAFs. Shortened frame and custom hauler bed. 98 Sunnybrook 30RLFS 5er. Old Too Soon - Smart Too Late! |
#3 |
You should be fine on the Performance setting. Extreme may be more than your stock 03 turbo can handle. I much prefer the non-stacker tunes over the stackers and I don't even use the Puck. Have the truck and all accessories off, plug the Predator in to the OBDII plug under the steering wheel, and follow the directions. It takes about 12-15 minutes to download a new tune so make sure you have the windows down so you don't sweat to death.....
__________________
04 Green/ Silver Dodge Ram 2500 4x4, 305/555 HO CTD, Custom 4" exhaust, HE351 turbo, VA C3.2 |
#4 |
what about gauges? mine come on when i turn the key foward. do i need to unplug the power wire or is it fine? i know a/c lights and stuff but what else? im about to use a downloader for the first time too
__________________
2008 gmc crewcab 2wd 5.3 flowmaster. it's nice but it's no cummins... for now! sold and missed-2004 quadcab lwb 4x4 305/555 6 speed, 3" spacers, 1.5 rear, bilstein 5100's, 325 toyo a/t, 17x8 058's, predator/quad, full 4" exhaust-5" tip, afe tube w/airaid, autometer pyro and boost, quad rp and fp gauge, husky liners, home built steps. 496hp @ hot street 11/17/07 1978 jeep cj-5, spring over 33x13.5r15 super swamper, 15x10 2.5bs chrome mods, 4.88's rhino lined floor, pro comp seats. |
#5 |
The guages should not cause any problems. Mine don't. You have to turn the key to the "On" position to download and you will hear the LP running at times while downloading. You don't want to cause any voltage spikes or drops while you are downloading so you should not even open the door during this...
#6 |
I turn off the radio, OH puter and don't touch the windows or doors. I roll down the window before I start and do it from outside the truck. That way I do whatever I want while it DLs. Craig
#7 |
Oh i meant how do you or can you change the tunes on the preadtor itself and which one of thoes is the best. Sorry about that
#8 |
you can go on their site,diablosport.com and download the custom tunes,they have some 200hp extreme tunes.theres ones for stacking with the puck too.whos to say what the best tune is,depends on what u want,i want milage and throttle responce,i found just that with the extreme rkl stacker.
__________________
gone but not forgotten,2001.5. 3/4 ton,4x4 sb,5 spd,,.silencer ring,mia.bhaf.130 hp xxx injectors yahooooo.edge comp.5"stacks.now smartified. new to me 04 6spd longbox,305,555.diablo predator and quad x2race box and comander.bhaf,scangauge2.stix on the wayyyy |
| Display Modes | |
