Go Back   Dodge Diesel - Diesel Truck Resource Forums > 1st and 2nd Generation Ram - Years 1989-2002 > Performance and Accessories 2nd gen only
Register Forgot Password?
Search
submit to reddit
Thread Tools Search this Thread Display Modes
Old 06-04-2012, 07:41 PM   #1
cowboykilla235
cowboykilla235's Avatar
best J-Hook to buy
im planning on installing a J-Hook & Boost fooler on my truck in the next few months. there are several different versions out on the market.
B&D X- Hook
TST J hook
and a few others.... what are you guys running, and do i have to worry about adjusting my J hook?
if someone could post links i would App it!
also is everyone runing Quadzilla's boost fooler, or what other options do i have?
__________________
2002 dodge S.O. 2500 ext cab, long bed, automatic tranny, 45 Hp injectors, J-Hook (32PSI), boost intake elbow, B&D 4" exhaust from the turbo back, auto meter gauges (boost, tranny, and EGT, fuel pressure), Suncoast Tranny, Quadzilla XZT +, semi style chrome cab lights top of cab and under the front bumper, custom headache rack with 130 watt long range Daylighters, 55 watt backup lights wired into my reverse lights, 55 watt lights facing into my bed from headache rack.
cowboykilla235 is offline   Reply With Quote
Old 06-19-2012, 08:40 PM   #2
novahauler
novahauler's Avatar
I run the TST, have hit 33psi of boost. Easy to install and really like it. All of the programmers have a boost fooler built in. I have an Edge Juice with attitude.
__________________
2001 2500 4x4, Edge Juice With Attitude, 197K Miles, 4" SS Exhaust, 18.6 MPG Set on 3,5, Home made AN Big line kit from Fuel Filter to VP44, BHAF, 2.5" leveling kit, Falken Wild Peak A/T 285/75/16, Sport Light Conversion Hella 9004/9007 Off Road lights, 4 on low, 4 on high (8 filaments).
novahauler is online now   Reply With Quote
Old 06-20-2012, 04:33 AM   #3
cowboykilla235
do you have to worry about adjusting your boost pressure or anything?
Old 06-20-2012, 07:05 AM   #4
novahauler
novahauler's Avatar
It is all regulated by the spring pressure.
Old 06-20-2012, 12:15 PM   #5
Sea:\>Drive
Sea:\>Drive's Avatar
+1 on the TST - used to be a lot cheaper than the BD one too but I think they are close in price now.
__________________
'01.5 2500 CTD QC SB SLT 2WD, Auto (Goerend), 3.54LS, TruxPort, J-hook, AEM Workhorse, Boost/Pyro/FP/Trans Temp, 4" Pinnacle Power Exhaust, Vulcan Big Line Kit w/Raptor, Edge Comp, DD1s, DEI Remote Starter, KoolVue Tow Mirrors, 20% Tint, LED tail ,brake, and turn signals and HIDs.
Keith
MD DTR Chapter #33
TOM June 2008
Sea:\>Drive is offline   Reply With Quote
Old 06-21-2012, 04:00 PM   #6
cowboykilla235
with the TST did you ever have to worry about over boost, or going over 35 PSI
Old 06-25-2012, 10:23 PM   #7
novahauler
novahauler's Avatar
No. Only had mine to 33 on level 6-5 on Juice with Attitude.
Old 06-26-2012, 02:24 AM   #8
cowboykilla235
i think im going to buy the TST one, it just looks more stout!
i was worried about it because you cant adjust it, unlike the other J-hook...
im only hoping/trying to get 28-30 PSI of boost!
Old 07-02-2012, 06:25 AM   #9
high bid
high bid's Avatar
You could just get a turnbuckle from lowes or HD and prob save some $.
__________________
high bid - 1999 2500 4x4 SWB auto w/3:55, SLT, leather, 3"Carli+Deaver leafpack, 225k, VP44#3@ 186k, Adrenaline (goodbye superchip & skyjunker), Mach 1.6, Transgo kit,amsoil intake, holley blue+baldwin spin-on ff & oil bypass,5"exhaust, silencer ring lost, HX35,Commander, Quicksilver Fuel Press+idiot light, Luke'sLink,315-MTR's=junk, H2wheels/315BFGs, replacement bumper, bilstein5100,53block,,70+gal aux, GM wheel cyc, RSC brace, "fish or cut bait".
high bid is offline   Reply With Quote
Old 07-02-2012, 07:21 AM   #10
cowboykilla235
ya im just afraid of getting to much boost and overspooling my turbo
Old 07-02-2012, 10:52 AM   #11
high bid
high bid's Avatar
If you have the HX-35...I wouldn't worry about it. W/my setup it has never been an issue. You could even install the turn buckle solid on one end and spring on the other.
Old 07-02-2012, 03:22 PM   #12
cowboykilla235
Hy35
Old 07-03-2012, 06:12 AM   #13
high bid
high bid's Avatar
I'd still proceed w/doing it. Think about finding a used HX....it would bolt right on.
Old 07-13-2012, 01:30 PM   #14
Sea:\>Drive
With the TST I can very rarely hit 35lbs w/Edge and DD1 injectors - and I never worry about. I had the turnbuckle and easily reach 40psi all the time so I went to the j-hook instead as it was my daily driver and I didn't want to grenade the turbo. You'll be fine with the j-hook.
submit to reddit
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.6
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
vB.Sponsors
Copyright 2011, DieselTruckResource.Com
Contacts Backup
