Thread Tools | Search this Thread | Display Modes |
#1 | ||
best 1 time injector cleaner?
__________________
-2005 2500, 5600, 4wd shortbed 205k oilfield truck |
#2 |
HOWES meaner cleaner lubes and cleans availably at truck stops and big truck parts store. My truck was sooted up from small trips and poor maintence of PO blew brownish soot for 2 tanks befor she was cleaner 1 litre treats 950 litres of fuel or in the imp 1 quart treats 950 quarts rated "superior "by Cummins L-10 test Specifications this is the info from bottle in hand 4.8% fuel ecnomy improvement/65% reduction in injector deposits/35% increased lubricity-injectors,pumps and upper cylinders/80%emissions reduction-stops the smoking/Cleans tanks and fuel lines/Corrosion inhibitor-stops corrision in engine fuel systems/Fuel stability-eliminates sediment formation/Eliminates water/ Also for farm and marine diesels. Iget it at the Western Star dealer about $13 a bottle. Howes has been around since 1920 a lot of the otr rig drivers swear by it. just my $0.02 worth. oh and must inportant in the directions " add to fuel 1 litre to 950 lites" [ i get 10 tanks worth 1/10 bottle to 100 litres ]it states OVER USE IS NOT HARMFUL so you can heavy dose a few tanks
__________________
2003 QC,LB,3500 SRW ,HO 4x4 Laramie,Auto 373's Edge EZ. 2002 QC,LB,3500 DRW,SO 2x4 SLT,6 spd..sold. 1993 CC,D250, lots of mods..sold. |
#3 |
Don't fill the fuel filter with power service! I saw a guy do this once on a bobcat. It was still hard to start up even after the all lines were bled (as it was run out of fuel). It ran like crap for a little while and the guy who owned it gave it some more fuel to help push what he thought was air in the lines, then BANG! backfire, black smoke everywhere. It took a second to comprehend what had just happened. Smoke was coming out of the air filter, the oil light came on, SHUT IT OFF IT'S RUNNING BACKWARDS!
Lucas make great products, I,d try thier injector cleaner, mixed per label directions.
__________________
The Red Eye Ram 92 W250 LE, SLED PULLER, tuned Bosch VE, S400 single turbo 71PSI boost, and a 5 inch hood mounted flame thrower '93 W350 CC dually to tug the puller around with |
#4 |
I prefill my fuel filters all the time with Power Service fuel additive. My reasoning is I have additive in the garage more than I would diesel fuel.
__________________
Bill Gilbert 85 D350 crew with 90 6BT intercooled Getrag 3.07's 93 D350 single cab Getrag 3.54's |
#5 |
Bill, If you saw that happen you would be leary too! The bobcat was a N/A motor which might be the reason for the backward running. I know for sure the PS caused it as after the incident we dumped the filter, filled it with #2, bled out the PS and it started right off. The problem never occured again.
Anyway the injector cleaning process is somewhat slow on most types of engines. It usually takes a few tanks of treated fuel to do the job best. BG makes an excellent diesel injector cleaning product as well I hear. |
#6 |
Chevron Tecron injector cleaner is about the best there is from my view
__________________
2006 2500 megacab laramie with bfg's and a black leer cap '06 Mercedes Diesel (we love it) "Lord help me to remember that nothing is gonna happen to me today that you and I together can't handle" |
| Display Modes | |
