Thread Tools | Search this Thread | Display Modes |
#1 | ||
belt squeal.
#2 |
Check all the accessories, make sure that they spin freely or with minimal resistance. Usually belt squeal after startup until it's warmed up can be caused by the alternator, fan, or tensioner. Make sure all these spin freely, no tight spots, no burned spots on the pulleys, etc. If it starts hard, then it might be the batteries are getting old, and the alternator is working hard to charge them after it starts.
Also, with an auto tensioner, "tight" is a relative term. I think the spec testing with an actual belt tension tester is in the 15-20lb range. |
#3 |
try some belt dressing. it comes in an aerosol can. just spray a little on while the engine is running.it may be just a temporary fix. had an alternator going out a few years ago which caused mine to squeal under acceleration. you may wanna look into that or any other accessory
__________________
'91 GMC C2500 XCab/ Longbed, cam, tb spacer, headers, hollow cat, heavy right foot Honor the Texas Flag; I pledge allegiance to thee, Texas, one and indivisible |
#4 | |
Quote:
I wouldn't us belt dressing evan if it was just to sell the truck! JMOIf you can get hold of a heat gun,the one that shows heat not make heat! after the cold start belt squeal has stopped,shut he eng off and start checking pulleys for heat.....you will find the problem
__________________
91.0 non intercooled 3/4 ton 5sd ex.straight piped HX35, timing bumped 1/16...Pump mods have started Full power screw1/2 max with out removing the collar. Gear Vendor over drive! Finally finished 2nt gen intercooler turbo and Coolertubz, By Tim (TWorline)" write-up here:http://www.dieseltruckresource.com/d...d.php?t=186908 |
#5 |
I had the same problem when I bought a belt at autozone. Within a couple of days it startd squeeking and I must have checked everything and couldn't find the problem. I can't remember why but for some reason while working on the AC I put the old belt back on and it hasn't squeeked since. Our trucks don't like cheap belts.
__________________
1989 Dodge Ram 250, 2WD, Reg Cab, auto, Dana 70, All stock for now. |
| Display Modes | |
