Thread Tools | Search this Thread | Display Modes |
#1 | ||
Before I Spend Mega $$$
__________________
1992 W250 G360~ Wife calls it Satans' Lavatory |
#2 |
I agree with Dave. Definately hydraulics. I was having similar problems so I replaced the master cylinder and the slave cylinder. Mucho better now. If the clutch doesn't disengage, then the hydraulics aren't doing their job... simple.
__________________
1990 D250, Cummins, G360 3200 Spring Full Fuel Screw maxed Injector upgrade 1/8" Timing bump ATS Manifold Airflo Intake HTT 56mm 14cm W/G Stan's 4" turbo back |
#3 |
I am having the same thing on a 2002 4x4 3500 with 135,000 miles ,it started with clutch engageing just an inch off the floor now its almost impossible to get into gear I think I will replace it with an upgraded one ( Master Slave ) so when I replace my clutch with a new upgraded one the hydralics will handle it.
I read a post where Advanced Diesel Technology 304-864-3399 have them for 250.00 shipping included when your dodge dealer will get you for about 200.00 for a stock unit. LeRoy |
#4 |
After inspecting your slave cylinder and master cylinder for leaks. Look inside under the dash on the fire wall for leaks from the master cylinder. If no leaks are found try "pumping" the clutch pedal I would say 10-15 times and see if it will "pump up" and disengage the clutch. If this works than I would guess its your clutch master cylinder. You will be able to tell as your pumping if the clutch starts disengaging.
But check for leaks inside on the firewall first, if there is than replace master cylinder.
__________________
92 Black W250 295K, getrag, valair 13" ceramic clutch, dana 80 3.54, HX40, DDP3 injectors, high pressure piston LP, custom IP, M&H M2 fuel pin, PS charge air cooler, 4 in exhaust w/ brake, gauges(and lots of them) Leece Neville power. 89 FUMMINS F350 4x4 crew cab, VE 12V, A518 trans, ford np205 t-case, PS cooler, hybrid HX35, low pressure piston LP http://s218.photobucket.com/albums/c...Truck%20stuff/ |
#5 |
If you could, get one that is prefilled and primedfrom the dealer, if it is your master OR slave cylinders. Makes for a lot less knuckle-bashing and makes it a easy swap.
Just my $.02 worth (which isn't much )Jon |
#6 |
I have been having the same trouble with my truck. usually a shift into a higher gear will allow me to shift into 1 or 2. Some people have told be its the trans starting to go. Too me the clutch release and hydralics would be a good and cheap and easy place to start. Thats what I'm gooing to do as soon as it warms up.
__________________
1993 W250 Clubcab 5spd, 3.07 gears, Green/Tan, Isspro Boost, pyro, fuel pressure and tach. 7'6" Meyers Plow. 3 inch Straight pipe. MagHytec Diff cover. Alocas with 265/75's BFG AT's, HX35 12cmWG, P3 Brake controller, 110gal bed tank, BHAF In stock waiting for a nice day. -Rocker panels, Chrome roof lights, Lund Visor Future Plans -4inch exhaust, 2-4 inch lift -1980 Rabbit diesel 4dr 5spd. -1982 Mercedes 300 -1997 F250 SC 4x4 auto 7.3 powerstroke |
#7 | |
Quote:
The parts were in the store the morning after I ordered them. Some place only carry the slave cylinder but the master is special order.Jon |
| Display Modes | |
