Go Back   Dodge Diesel - Diesel Truck Resource Forums > 1st and 2nd Generation Ram - Years 1989-2002 > 24 Valve Engine and Drivetrain
Register FAQ DTR Store Members List Mark Forums Read
Thread Tools Display Modes
Old 11-20-2009, 03:58 PM   #1
blackcloud
blackcloud's Avatar
Batteries?
Truck starts just fine in warm weather but as soon as it hit 30 it starts getting harder to start, once it hits 20 and I dont plug it in it cranks but wont fire right away, on about the third try the batteries start getting weak. It usually fires just intime before they die. Would new batteries help this problem? I plug it in where I can but when im at my girls house thats not an option ( theives would steal my cord) so I gotta do something. Any help is much appreciated.
Thanks, Matt
__________________
New truck: 2001 quad cab long box 6spd 4x4, ez,Hypertec max energy, bhaf, straight pipe. 2" leveling kit 315/75/16 Good Year Dura Tracs on stock wheels
Old truck:1994 Dodge Ram 2500 4x4 Cummins 5.9L, regular cab long box, 5" exhaust, pyro and boost gauges, South Bend clutch 13 in. OFE,silencer ring, what silencer ring? BHAF, #0 plate, Scheids 035 DV's, Head studs, timing @ 13.5*
blackcloud is offline   Reply With Quote
Old 11-20-2009, 04:49 PM   #2
farmall99
I just had same thing. I than put in a set of optima's, problem solved!
farmall99 is offline   Reply With Quote
Old 11-20-2009, 05:14 PM   #3
kreynolds
kreynolds's Avatar
New batteries should solve your problem.
__________________
2001.5 2500 4WD QC, sb, 5-sp, 3.55
kreynolds is offline   Reply With Quote
Old 11-20-2009, 11:03 PM   #4
johnh
johnh's Avatar
Send a message via Yahoo to johnh
Quote:
Thanks, Matt
check the grid heaters, if they aren't working hard starts are common when the temps drop
__________________
01 3500 ho 2WD;4 inch exhaust bully dog stage 3 inj edge comp(removed hybrid hx 35/40 8/25/04) dyno 419.2 hp 891.8.torque w/stage 2`s on a dyno jet 6/25/03 ,htb2 turbo installed 8/25/04, not a dually any more,conversion done in 04... added home designed propane march 07 (to improve mileage) new vp 44 from industrial injection 3/july/07 181000 miles, removed stage 3 injectors ,reinstalled stage 2 to try to control EGT's better
johnh is offline   Reply With Quote
Old 11-21-2009, 10:05 AM   #5
blackcloud
blackcloud's Avatar
Thanks guys thats what I wanted to hear, What kind of optimas should I get? red top or yellow top? Thanks johnh I will look into the grid heater when I get back from hunting this weekend, that sounds like a very possible cause too. Thanks again guys. Have a happy Thanksgiving
Old 11-21-2009, 10:59 AM   #6
bigjohn862
bigjohn862's Avatar
I just bought a new set of batteries from autozone gold for 89.00 a piece.Three year warranty with free replacement and up to eight year prorated.They work great. Mine were getting weak they were factory batteries.
__________________
2002 2500 4x4 Q/Cab auto,355's, S&B cold air box,Vp 44 H.O,RV injectors,triple gauges,fuel pressure,egt,tranny temp,5 inch straight exhaust. Performance tuned by Jim Jessup.Built transmission with TCI triple disk torque converter by performance transmission's Louisville,Ky.
bigjohn862 is offline   Reply With Quote
Old 11-21-2009, 02:45 PM   #7
sheriffav8r
sheriffav8r's Avatar
Ditto on the Duralast Gold. Can't beat the 3 year replacement and 8 year prorate....
__________________
<---My previous oil burner "Bombs delivered on time or your money back!"
'01 2500 SLT Laramie QC LB 4x4 Auto 3.54 gears 230K miles. Goerend w/billet input shaft/ low stall TC/ 2,3,4lockup+switch, 4" exhaust, Edge Juice with Attitude, Superchips 3705 Tuner, Walbro 392 with Swagelok bypass, Yokohama Geolandar 315/70R17s on 2006 H2 LE Alcoa wheels, '03 front brake conversion, PSC Steering Stabilizer.
'09 Northstar 850 SC XB popup slide-in camper
Semper Fidelis!
sheriffav8r is online now   Reply With Quote
Old 11-21-2009, 09:15 PM   #8
dozer12216
Perfer Wally world Maxx myself. Same Warranty anywhere, better price.
__________________
Big Blue Beast. 2000 SLT dually heavy towing auto 2WD, stage 1 injectors, 235K and still growing.
Goldenrod. 1984 Rampage with 2.5 1/2 liter EFI engine. D8H CAT dozer and old Hein Werner excavator. Retired to play with toys.
dozer12216 is offline   Reply With Quote
Old 11-21-2009, 09:34 PM   #9
J.Suplanski
Thumbs up Battries
Costco has the best price on Optimas!
__________________
1994 12 valve 4X4 Fully loaded Carli Suspension with 3" Kings Suncoast full billet trans converter & Flex plate HX 40 370 injectors Snow Performance Meth h20 injection 315-75-16 Pro-Comp Extremes Wilco tire carrier Keeps up with the traffic!Thanks to Old Man Bob 4X4 & Pablo
J.Suplanski is offline   Reply With Quote
Old 11-21-2009, 09:37 PM   #10
Patriot1
Patriot1's Avatar
i love the gels in my truck. i have 4 of them. i have moved back to ny and i'm about an hour away from canada and its been cold here and she fires up like a gasser!
__________________
1987 P-30 Chevy Box Truck
Retro fit cummins/allison
with 38,000 original on the motor and trans
Denny-T Fuel Pin Gov Spring
Autometer Gauges
HX-40 turbo 4 inch exhaust
5 inch driveshaft
http://s411.photobucket.com/albums/p...umminsallison/
Patriot1 is offline   Reply With Quote
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.6.7
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
vB.Sponsors
Copyright 2003, DieselTruckResource.Com
