Go Back   Dodge Diesel - Diesel Truck Resource Forums > 1st and 2nd Generation Ram - Years 1989-2002 > 1st Gen. Ram - All Topics
Register Forgot Password?
Search
submit to reddit
Thread Tools Search this Thread Display Modes
Old 11-11-2011, 11:27 AM   #1
M1Lover
M1Lover's Avatar
Baja california, Mexico Trip: First Gen Spares List
Good morning Gents. Headed to Mulege, Baja California Mexico with the Mrs and the 5th wheel for 2 plus weeks in December (Bullmastiff girl died last week. RIP Daisy.). My '93 has about 102k miles on it now. Did the air and fuel filters (NAPA Gold) yesterday. I have a spare serpentine belt, the manual lift pump, I think. Need a new positive battery cable (Good source for the stock one?). What am I missing? What 12V prep would you perform for the trip and what spares would be most likely needed in a remote area? Is the fuel screw option REALLY that easy? My truck is bone stock except the muffler has been removed.... Thanks, H.
Click the image to open in full size.
__________________
"If we're all thinking alike, somebody's not thinking." General George S. Patton
"Fat people make lousy revolutionaries" Me
'93 D250 LE ClubCab, 4X2 Auto, 3.50 rear, bought 6/08 with 76k miles, now at 103k. Muffler removed, fuel pin turned 100 degrees.
M1Lover is offline   Reply With Quote
Old 11-11-2011, 12:50 PM   #2
jimlj
I'd make sure I had a good spair tire for the truck and trailer. While you are at it, make sure you have a lug wrench for both, and a good jack. Maybe I'm just too stupid to worry about too much else.
__________________
'79 Ford F250 4X4 Super Cab. Mostly stock (for now) '89 Cummins, NV4500, Ford high pinion Dana 60 front, Dana 60 rear, 3.54 gears.
jimlj is offline   Reply With Quote
Old 11-11-2011, 01:04 PM   #3
Santaclaus
Sorry to hear about Daisy.
The first sign on list would be fuel filters, as in several. I'm not familiar with where you're going or what your fuel range would be but dirty fuel will ruin your day especially in the boonies. Of course and tools especially some method to prefill the fuel filters with known clean fuel. You can get Napa, to make a positive battery cable for you. A good set of jumper cables. An extra air filter. A spare for the trailer and make sure your spare is aired up. If you haven't done the headlight relay fix our consider doing that before the trip as it makes a big difference in the brightness of the headlights. I'm sure there's a hundred other things that can be added but there is a limit to which want to carry. Have a great trip. Just my two cents, Mike.
__________________
92, Extended cab, auto trans, exhaust, boost, tack, oil pressure gauges. Pensacola, Fl.
Santaclaus is offline   Reply With Quote
Old 11-11-2011, 01:12 PM   #4
M1Lover
M1Lover's Avatar
Thanks for the condolences Mike. you must be a "dog-person". We're gonna miss this one. Best dog I ever had..
I have 3 extra NAPA gold fuel filters and 1 air filter. Spare tires galore. the headlight relay fix is on the list, though I'd do it not for brightness, but to eliminate the possible altogether failure. You just don't drive at night in Mexico -at ALL- unless you have no other choice. I'll have to check with NAPA about building a battery cable. Didn't know they did that... Keep 'em coming. Good advice, all. Thanks, H.
Old 11-11-2011, 01:21 PM   #5
Twitchy
Twitchy's Avatar
An extra blue mopar voltage regulator, mayhaps?
that's my 1/2 cent.
__________________
-Ryan
Lurking about the 1st Gen Forum.
No trucks yet.
(Ads removed signature violation)
Ok. :/
Twitchy is offline   Reply With Quote
Old 11-11-2011, 02:04 PM   #6
bryson711
bryson711's Avatar
Quote:
that's my 1/2 cent.
Its a 93 it does not have a voltage regulator
Sent from my DROID2 using Tapatalk
__________________
93/81 Dodge crewcab longbed, nv5600, 5x14's, 366 spring,timing bumped, tweaked pump, M3 pin, he351, 4" exhaust, coolertubz, powerstroke intercooler, low pressure lift pump, bhaf, alcan springs, kelderman air ride, skyjacker nitro's, 3.07's, autometer pyro, boost, fuel , issopro tach
92 D-250 4'' exhaust, minor pump work 3200 spring, timing bump, A518
97 dodge ext cab long bed cummins 4 '' exhaust, bhaf, 4k kit, timing advanced ,plate work tuned afc, bradford flat bed, nv4500
bryson711 is online now   Reply With Quote
Old 11-11-2011, 03:15 PM   #7
Mieser
If it was me....
Serpentine belt
water pump
idler tension pulley
upper and lower radiator hose
few spare hose clamps
A hose splice to bypass the heater hoses
mechanical lift pump
spare fuel filters...more than one
u-joint for driveshaft
optional stuff I would think about...
wheel bearing grease and the tools to repack bearings
Make sure your steering box mounting location isn't cracked already
tie rods and steering linkage in good shape
ball joints in good shape
more than one spare tire or a good plug or patch kit
Have a good trip, let us know how it goes! I have been wanting to take my truck down on a baja run for years.
__________________
New project....92 W250 regular cab manual, fuel pin rotated, high idle screw back out, throttle linkage moved over, straight pipe, open air cleaner.
Mieser is offline   Reply With Quote
Old 11-11-2011, 05:23 PM   #8
gyman98
gyman98's Avatar
Maybe he meant to bypass the computer and get the truck charging again if it blows the internal reg.
Have a safe trip and bring me back a Gen 2 Ramcharger!
No seriously I will pay well!
__________________
2011.5 Ram 2500 Crew/SB Laramie 4x4 800lbs HO
1982 Dodge W350 Crew cab Cummins with 5spd
94 2500 4x4,93 W350 Dually, 92 W250, 1950 powerwagon 6bt/5spd
My build thread;
http://www.dieseltruckresource.com/d...d-t288785.html
gyman98 is offline   Reply With Quote
Old 11-11-2011, 06:53 PM   #9
M1Lover
M1Lover's Avatar
Are you saying that all the Gen 2 Ramchargers defected to Mexico?!?
I'll keep an eye out!
Thanks for all the good tips gents. I will give a full report. The image in the OP is in AZ north of Quartsite headed for Yarnell Hill and Prescott on the way home to Cottonwood from San Felipe in, uh, lemme think, January of 2009. I'll give a full report when I get back. We're looking at Mulege, about 600 miles south of Tecate. Sure to be an adventure! H.
Old 11-11-2011, 07:00 PM   #10
gyman98
gyman98's Avatar
To my knowledge that was the only place they were sold in North America
Old 11-11-2011, 07:10 PM   #11
rebal
rebal's Avatar
we used to go down the Baja for years only trouble we had was tires you might want to take a couple extra tires for the trailer a fan belt and fuel filter. we never had a issue with fuel it was always good. but between rosario (spelling) and the bay of los angles we had to find fuel it was like 250+ miles between gas stations.I have heard that a new pemmex station was build somewhere closer now. but like I said tires .
__________________
1990 W250 bought new in Nov. 89 performance built 727 and torque converter , high miler 800 k kelderman air ride
2001 2500 HO 6spd 4x4, Engine brake ,fass,SBC 4" turbo back exhaust BHAF fluid damper,ARP head studs, DSS, Fast cools. wife says trucks fast enough:(
How many of your rights are you willing to give up before you feel totally safe ?Wake Up People vote EVERYONE OF THE BUMS OUT OF OFFICE!
rebal is offline   Reply With Quote
Old 11-11-2011, 07:13 PM   #12
93flatbed
93flatbed's Avatar
Extra bulbs for both trailer and truck. As said a good jack, jack stand, and wrench. Dodge also still have the factory cables(well about a year ago they still had them). Go over the truck real good before you leave. In my humble opinion I would not carry a whole parts store with me. If you don't already, I'd want a pyro and fuel pressure gauge to watch the truck with that trailer on the grades. Have a fun and safe trip!
__________________
1993 W250, single cab, hunting for Jeremy.
1981 crew cab powered by 93 w250 drivetrain
Special thanks to Rob @ highway chopper for machine and head work.
93flatbed is online now   Reply With Quote
Old 11-11-2011, 08:08 PM   #13
d22019
d22019's Avatar
Quote:
Originally Posted by Mieser View Post
If it was me....
Serpentine belt
water pump
Looks like the list of stuff that live in various places in my cab. I would also bring a long piece of 3/8 fuel line with you and some nuts and bolts. A spare fss wouldn't be a bad idea either, when they go out it usually shuts the engine down.
__________________
'93 D-250. Getrag, 3.54's, stock sticks, 1 turn on the power screw, Pdr HX35, ported 16cm, 2nd gen 4" dp 3rd gen 4"turbo back,bhaf, CoolerTubz intake horn, grid delete.
'92 D-250. A518 Bone Stock.
"89 D350. Work in Progress.
d22019 is offline   Reply With Quote
Old 11-12-2011, 10:29 AM   #14
Twitchy
Twitchy's Avatar
Thumbs up
As an Eagle Scout, I am of the firm belief of always being prepared.
I am 99.9% certain that your internal regulator will be fine, but in my experience I end up with the 0.1%.
Old 11-12-2011, 01:56 PM   #15
maybe368
maybe368's Avatar
Oye! Casador, No te preocupes porque tu sabes que los Mexicanos se pueden instalar un distribudadora de Toyota en un Cummins y funcionaria. ...Decided on the Baja huh? That's ok, any place in Mexico (mas o menos) is nice...Mark
__________________
90 W250 LE 4x4, Getrag G360 Replaced the IP and Killed KDP and Cap bolts. Estimated 300 K miles (update), odometer quit in 2003...fixed, thanks to the great how to's in the sticky. 8000 LB Warn Winch 91 Gal Axillary fuel Tank, dual battery's, Solar battery charger, disk brake conversion, rebuilt front end and 100% antifreeze
'You do not quit running because you get old, you get old because you quit running', A variation of a quote by Oliver Wendell Holmes
maybe368 is online now   Reply With Quote
submit to reddit
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.6
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
vB.Sponsors
Copyright 2011, DieselTruckResource.Com
Contacts Backup
