Thread Tools | Search this Thread | Display Modes |
#1 | ||
Bad VP44 or something else?
#2 |
Do you have good pressure from the lift pump.
Guessing you don't have a Fuel Pressure guage, since you didn't mention it. Is there fuel in the fuel filter cannister? Has the filter been changed recently? Lack of fuel at the injectors could be either pump. Lift pump is cheaper, much cheaper. Just noticed this is your first post, Welcome to the board, prepare yourself to learn alot here. phox
__________________
2002.5 Dodge Ram 2500 4X4 SOLD 2009 Jeep Wrangler Unlimited X 4x4. Detonator Yellow in color Bone stock for now, at least for a couple months 2008 Harley Davidson FLHR Road King. Black Pearl in color 12 inch apes, stainless cables, Vance & Hines pipes, garage door opener, combo speedo/tach |
#3 |
Thanks, Phox
Well I don't have a FP gauge, but when I remove the bleed bolt on the fuel filter canister it will shoot fuel out about 2-3 inches high.. I replaced the fuel filter about 2 tanks of fuel ago... I also notice when I cut the key on the lift pump runs for a very long time instead of its usual 5 second run then it stops because preasure has built, but now it runs a long time like 15-20 seconds... Could I have gotten an air bubble in the line and I'm not bleeding the system correctly? I would really like this to be something simple like a simple lack of enough electrical output or an air bubble in the system or my lack of knowledge in bleeding air from the system... |
#4 |
Well, your lift pump seems to be just fine if you get a geyser out of the bleed hole.
If I had to guess, which it appears I am doing, I'd say your VP44 has given up the ghost. If you can get it somewhere to have the codes read, this would verify it. Unless, like mine, it died without any codes being thrown. phox |
#5 |
steele
it is an easy test to do on the lift pump just slide the clamp on the rubber portion of the line between the filter and inj pump back so you can seperate the rubber part from the metal part of the line .pull them apart and put the loose end from the filter into a container .go to the ing key and bump the starter if the pump does not start when you turn the ing to on.the pump should put out about i think 1 half liter.i dont remember the exact amount it is in a link here under the search files.
__________________
USN 70-74 Patriot Guard Hunter Ed Inst Y2k CTD SLT, 4X4 silver,quad cab,pro-tech bed,w/tool boxes,tnted glass, dynamat extreme ,3.54 LS ,4 spd auto w/magtec deep pan , leather, wdgrain, chrome nerfs, trl/cmpr pkg, 265/75/16e bfg alltrn on alloys, front recvr, autometer , glowshift gauges 4 .exh magna flow, resonator gone ,silencer ring gone, K+N filter, grounded/jumped apps,fass,edge ez,dpp injectors, rancho kyb shocks ,super hitch,prodigy ,airbags ,xm radio,194 k,xdm under the seat |
#6 |
Well it seems like my injector pump, I have a shop in town that is willing to sell me eather a HO pump or the regular 235HP pump and they will accept my pump as a core on eather, what would be the best pump to buy for my application....
Latter I'm planing on a set of F1 stage 2 EDM injectors a boost fooler and eather upgrade my turbo to a hybrid or a full out HX40... no fueling boxes just straight mechanical hard part performance accessories..... That being said would the 245Hp or the 235Hp pump be better? |
#7 |
What ever you decide get a fuel pressure gage first, around $50. You may be surprised like I was, to find out your LP is weak ($150) and it caused your $1200
IP to go out. Are you starting to see the point? It took me several months of fooling myself, thinking I didn't need the gages either. These trucks need gauges, or get the checkbook out. Or worse you'll get stranded.
__________________
"99", 265K on Original VP44 Before it Died. 300K miles And Running Strong! 2nd Full Goerend Bros Tranny & 3 Disc TC Smarty, 2nd FASS HVLP95, ATS 3 piece exhaust manifold, 4" Exhaust, Fuel-Boost-EGT's, Sears Platinums, Marine 275's, K&N, 285's on stock rims, GMC 1 ton rear brake cylinder, Remote starter, KDP checked. |
#8 |
I'm thinking a full gauge set that includes a fuel preasure gauge and also replacing everything from the fuel filter back with 1/2 inch hose and a high flow pump with a regulator that will supply a constant 13-14PSI of fuel flow(Idle-WOT)...
#9 |
steele,
Might save yourself some greenbacks and grief by checking the LP first. I know that advice has been given earlier but I couldn't help comment on the way your CTD "laid down". Exact same sypyoms for me last Feb at -36 c. Could not get that beast to fire even though I had fuel at the canister (or so I thought) I had backed off a banjo, bumped the starter and had fuel. (not) It wasn't until I tried replacing the LP (cheaper) did I realise what 15 psi looks like. Man, I soaked the entire engine bay, my driveway and the dog when I bumped the new pump .Needless to say gauges are a must. Try your LP first. The 2-3 inch "geyser" might not cut it. Good luck.
__________________
98.5 2500 4x4 Auto Short SLT QC. Edge EZ, 4" SS MBRP Exhaust, K&N air, FASS, isspro pre turbo pyro, boost and mech FP, 1 ton cylinder mod, Yokohama 285/75, Fan what fan? & a DSS to straighten me out. Running B-100 when I can. My lucky number WAS "53" |
#10 | |
Quote:
That's why an EZ box on an HO engine won't produce as much horsepower gains as on an SO engine. I'd stick with the 235HP SO pump...
__________________
01.5 2500 QC 4x4 LB, HO 6 spd, 3.54 anti, relocated breather, gauges, RV275 inj, EZ, Cummins Ebrake, AFE, TAG, Jardine 4", CON OFE, 2 whl low, 4 leaf helpers, Rancho 9000's, Helwig rear sway, Lucerix Mirrors, DSS, 19.5 Ricksons, Reese Titan V hitch w/28 in extension. '03 Eagle Cap 950 truck camper, slide out dinette, 4200 lbs ready-to-go Tow; 7000 gvw tandem cargo trailer or 3500 gvw single cargo trailer Semper Fi - Viet Vet |
#11 |
i say it is the vp44 cause the injection pump will still run with out any fuel preasure being supplied from the tranferr pump or lift pump like we all know them, it strains the pumps and this is what you get a broken injection pumpdefinitly check your fuel preasure cause most likely it will be low or none, good luck
__________________
09.5 mega cab 3500 4x4 laramie inferno red 6 spd auto tube step bars lots more to come (Ad removed site violations) |
#12 |
Well guys it was the VP44 injection pump...
I just got done replacing it today with a HO pump and the truck screams compared to before the pump went out, it could be due to the fact of the old pump was always on its last leg or the HO pump on a regular 235hp motor works miracles... Just for future information when the pump went out it didn't throw any codes or anything it just died... Thanks to everyone that had something to share about the topic... |
#13 |
A weak lift pump can cause your problem. I know because it happened to a fellow CTD owner stationed with me on Guam. His truck died. We pulled it to the his garage and we got some parts. A lift pump and a VP44. He has a good connection with a local bus mechanic. There are a lot of buses on this rock that use the Cummins 5.9.
Anyway we tried like heck to get it to start, no luck. Got a small geyser out of the filter canister, about 2 inches high. It looked like a lot. It really isn't . We replaced the lift pump and did the same trick only he left the bleed screw in a bit. Holy Jeez, A lot of fuel made it past the bleed screw and shot the under side of the hood. We bumped the starter a few times to purge the filter canister and as much of the lines as we could. We had to crack injector lines and crank forever until it finally coughed and sputtered to life. It seems you found out the bump the starter trick. When you just bump the starter it triggers the ECM which turns on the lift pump for 25 seconds.
__________________
J.R. U.S. Coast Guard , Electronics Technician 1st class Extra class Amateur radio operator - K5DTR 2001½ SLT 2500 2WD, auto, short bed Hi-flow banjo bolts FASS DDRP Scotty Air II Isspro EGT (pre-turbo),fuel pressure, boost, and transmission temperature (sensor in hot line) guages |
| Display Modes | |
