Go Back   Dodge Diesel - Diesel Truck Resource Forums > General > General Diesel Discussion > Fuels / BioDiesel / Diesel Prices
Register FAQ DTR Store Members List Mark Forums Read
Thread Tools Display Modes
Old 09-06-2005, 08:53 PM   #1
bernard
B99
I have been running my 97 on B99 for about a week. I decided to change the fuel filter on Monday and found something worrisome.
The filter O-rings (3) had expanded about 25% as if they had absorbed the biodiesel. Could this translate to fuel pump problems? I assume there are O-rings in the pump??
Now waiting for the rubber fuel line behind the pump to self-destruct..........
__________________
Six is the magic number of cylinders for an inline engine.
bernard is offline   Reply With Quote
Old 09-13-2005, 09:51 AM   #2
northslope
Suposedly our P-7100 pumps DO NOT have any natural rubber parts in them which means no there won't be any problem, with the exception of any rubber lines used i.e. return lines and that little elbow on the lift pump which would need to be replaced with fuel line that can handle methanol (fuel injection rated hose is capable of 100% methanol or ethanol) the Gates brand Fuel injection hose os the stuff to use, Gates marine rated hose can handle up to 10% methanol not sure what % of methanol is left in biodiesel but if it takes 1 gallon of methanol to make 5 gallons of bio that's 20% right there.
northslope is offline   Reply With Quote
Old 09-13-2005, 04:06 PM   #3
kd460
I would question your fuel. If it is washed fuel then it should be free of methanol. I would not run unwashed fuel in my truck. Try to find another source of your bio, one th is washed.
__________________
1997 2500, auto, 4x2, bilsteins, gauges, #10 plate, 3k gsk, 4" exhaust, timing at 15.75* HTS Custom Transmission, 190,000 miles of beating the snot out of it (and counting).
kd460 is offline   Reply With Quote
Old 09-13-2005, 09:48 PM   #4
northslope
Only theory at this point. I haven't actually ran or produced any bio YET, but yes it WILL be washed so I see your point of it being devoid of methanol if washed
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.6.7
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
vB.Sponsors
Copyright 2003, DieselTruckResource.Com
