B3.3T Jeep YJ
Old 05-16-2009, 01:39 AM
  #751
BigBluemotors's Avatar
B3.3 Engines
Hey guys,
Haven't posted in awhile. Still working on my 1990 Cherokee - slowly. Thought I'd let you know that if you need an engine, they are lots available on
http://www.dieselenginetrader.com. The 85hp are going for $3999 and the QSB3.3 110hp for $4725.
Chris
AKA: BigBlue
Old 05-19-2009, 08:48 PM
  #752
MotoBoyMatt's Avatar
I just found some BSFC data for the 4B3.3-G1, it's an NA genset engine but I would imagine it would be pretty close to the B3.3's.
BSFC BHP 1500 RPM
0.359 48
0.352 43
0.344 32
0.376 22
0.438 11
BSFC BHP 1800 RPM
0.369 56
0.351 51
0.344 38
0.371 26
0.477 13
Looks encouraging that the min BSFC occurs at power levels consistent with highway road loads.
Old 05-19-2009, 11:32 PM
  #753
95Z28A4's Avatar
Macet,
I was looking at your Flickr pics and noticed your engine doesn't have the lower oil fill spout next to oil filter like mine & TDIwyse's engines have. The turbocharger oil drain ties into the this spout. I'd like to remove this lower oil fill spout. I believe that I can use a turbocharger oil drain like yours to accomplish this. Is the part number for this part C6205518431? And are the necessary gaskets C6205517611 & C6204216820? What are the cost of these parts? Also, what is the part number for QSB3.3T paint? Thanks.
Old 05-20-2009, 07:34 AM
  #754
TDIwyse's Avatar
Thanks! I'd wanted to see some of that type of BSFC vs HP at constant rpm's.
BSFC BHP 1500 RPM
0.359 48
0.352 43
0.344 32
0.376 22
0.438 11
BSFC BHP 1800 RPM
0.369 56
0.351 51
0.344 38
0.371 26
0.477 13
Old 05-20-2009, 07:37 AM
  #755
TDIwyse's Avatar
I had issues with that thing hitting the passenger side frame mount in the jeep. I ended up cutting off a portion of the spout and putting in an expandable rubber plug. It looks pretty redneck but so does my whole jeep
Originally Posted by 95Z28A4
Macet,
Old 05-20-2009, 07:51 AM
  #756
TDIwyse's Avatar
Speaking of redneck . . . I did some redneck wind tunnel testing on those vortex generators several weeks ago. Of course it involved duct tape along with my shop vac. I had the shop vac tube hooked to the exhaust and was using it to blow air across the roof and over the VG's. Used string tapped to VG's to watch the air flow. I modified the positions/angles some based on what I was seeing and added a few more. The two tanks of fuel since this mod have yielded 37.5 and 35.3 mpg. That's 522.4 mls with a total of 14.4 gallons for a 2 tank average of 36.3. This is by far the best single and two tank averages I've ever had. I've been running straight petro diesel since Feb so I'm sure that's part of it as well.
I've got a little video of the windtunnel exercise that I'll try to put on youtube this week. It's not great but you can see the wind pattern generated by the VG's.
Oh, and here's that mitsubishi paper about the VG's that got me interested in them a long time ago.
http://www.mitsubishi-motors.com/cor...004/16E_03.pdf
Old 05-20-2009, 08:27 AM
  #757
95Z28A4's Avatar
Yep, I'm thinking I'll have clearance issues, also. Also, it increases the possibility of water intrusion into crankcase.
Awesome results using a few pieces of plastic. I'm always interested in this type of information.
Old 05-20-2009, 12:22 PM
  #758
Macet's Avatar
Macet,
Shoot me your ESN..
Old 05-20-2009, 01:54 PM
  #759
TDIwyse's Avatar
I wanted to see MotoBoyMatt's data in a more visual perspective. From my calculations I need ~40hp to travel ~60mph on flat road with no wind. Interestingly enough it looks like the higher rpm point would give better mpg's than the lower rpm point. At ~65 I need ~ 50 hp and again the higher rpm would give better mpg's.
BSFC BHP 1500 RPM
0.359 48
0.352 43
0.344 32
0.376 22
0.438 11
BSFC BHP 1800 RPM
0.369 56
0.351 51
0.344 38
0.371 26
0.477 13
Old 05-20-2009, 04:02 PM
  #760
95Z28A4's Avatar
Originally Posted by Macet
Shoot me your ESN..
68301042
Old 05-20-2009, 07:35 PM
  #761
TDIwyse's Avatar
http://www.youtube.com/watch?v=HPG6Z_a_hLo
Enjoy the Tomfoolery.
Old 05-21-2009, 08:14 AM
  #762
Macet's Avatar
68301042
All you need is the tube gaskets are the same. But extra is always good..
Old 05-21-2009, 12:41 PM
  #763
95Z28A4's Avatar
Tube & gaskets.......in case I damage one or both. I called Cummins Midsouth for a price on C6205518431.........$122! Does this sound correct, or did I supply the incorrect part number? Is that the part number for the tube on your engine?
Old 05-21-2009, 09:30 PM
  #764
Dangerous Dave's Avatar
I seem to do best with my '03 2500 at somewhere close to 1800 rpm
Sure, 1600ish is better still but you can't get anywhere in Texas at less than 60 mph!
I still think a Jelly Bean shaped F150 with a little 4 banger would the cats A$$
Old 05-26-2009, 08:48 AM
  #765
TDIwyse's Avatar
Filled up again. 38.4mpg. This is crazy. I was expecting ~5-8% improvement in mpg's by running on staight D2 compared to mostly biodiesel based on the studies I've read. It appears the engine will be exceeding this expectation. Here's a chart of my fuel economy/bio% over the last 3 years. The mpg's are a 3 tank running average to reduce the tank-to-tank randomness of the data.
Quick Reply: B3.3T Jeep YJ
