#16 |
Founder / Webmaster
There a bunch of reasons why you would want to run the truck with the EB on all the time. Mainly for DPF purposes...
#17 |
Nice write up. I've wanted this for a long time.
__________________
2007.5, 2500HD, QC, Laramie, 4X4, SB, 68RFE, 3.73, Inferno red, Edge Insight w/pyro, MaxBrake, Firestone Ride-Rites and controller, Air-Zenith air compressor, EZ Change Drain plug, S&B drop in air filter, 250 watt oil pan heater, EGR unplugged. 2008 YZ450FX, matching 756's, Marcel Fournier ice tires, 320mm EBC supermoto front disk, billet fuel screw, DiD narrow x-ring chain, Ironman sprockets, Scotts SS oil filter, Dr. D pipe coming, love the SSS suspension... |
#18 |
I understand that, just wondering if the EB on the 6.7 pushes soot into the oil as much as the 5.9? From what I have read most of it probably happens when the EB is on with a cold engine and the rings haven't fully sealed the cylinders off... UOA would tell the story.
__________________
2005 3500 SRW 4X4 QC LB NV-5600, Jake Brake, Smarty Jr Revo, Airiad MIT, GDP Intake Horn, GDP MK2+ w/ Cat 2um, Baldwin BF1212, Amsoiled, Pricols |
#19 | |
Quote:
__________________
'08 3500 4X4 Inferno Mega 6.7, Auto, Debadged, DeBlueTec'd, 5" TBE, XRT (Thanks to All Terrain Diesel), Glowshift Gauges, AFE Stage 2, Kenwood DVD/Nav, XD Rockstars, Frontier Bumper Replacements, HBS 2.5" Leveled, Auto On Exhaust Brake Mod Founding Member of DTR Megacab Club Join Here IAFF Local 2922 Donate to DTR, HERE |
#20 | |
Quote:
__________________
2001.5 2500 6 sp. van aaken BHAF 246,000 and counting sold 2005 st quad cab 6 speed ,superchips , striker 1 module,BHAF 97,000 10-19-07,176,000 11-25-09 Driving a powerstroke is like ED, you know it should but fails when you try. DTR RIGHT WING EXTREMIST |
#21 |
I've had some BAD experiences with jiffy/quickie lube places and our old company trucks. Stripped transfer case bolts, stripped transmission fluid level bolts, etc. I think I'll take Cummins' advice and change it every 6 months or 7500 miles and not worry about it (at least until the deletes and smarty come along...).
#22 |
OK guys, not trying to be rude, but lets keep this thread on topic so guys that want to do it won't have to search through 10 pages of off topic discussion to get the info they need
#23 |
This mod would be illadvised to make if you live anywhere near snow. EB on slippery conditions will get you a new truck real fast.
__________________
Nick __________________ INFERNO 2008 3500 4x4 Stick Mega Dually Club Member #235 |
#24 |
That is true. However, if you're concerned then just turn it off instead of having to turn it on... Or don't bother with this modification.
__________________
2007.5 Ram 3500 SLT 6.7L Megacab, 4x4, 6sp. Auto, Electric Blue, Nav & 6 disc changer, Smarty S67 ME14 (SW3), Revertable EGR Plugging and Exhaust Deletes, Edge Insight, S&B intake, Amp Research Steps, Prodigy Brake Controller, Wolf Liner O.T.R. DTR Megacab Club Member #152 |
#25 |
thax it works great is awsome
__________________
08 2500 6.7 leveling hellbent leveling kit custom intake egr unpluged |
#26 |
Couldn't one use a SPST relay and a prewired relay socket?
Then just wire the resistor to the 87 term wire run? Relay with 87 term plugged into socket, 15ohm resistor soldiered into wire run from that 87 socket, other end of same wire run to and spliced/soldiered into brown/orange exhaust brake switch wire?
__________________
09 3500 SRW 6.7 6spd SB quad 24K off sticker..... Richard Head could not shift std trans..... CTDs since 94 a million + miles and rolling... |
#27 |
Does this mod allow you to turn it off just by punching the button, or is it always on once this is installed?
__________________
2003 Dodge Ram 2500 4X4, PDR Cobra Stage 2 Twins, Dual 7" Black Stacks with rain caps, Banks Big Hoss Bundle, Goerend Full Built Trans, Smarty REVO set to Kill, MP-8, Full DIY Modded CP3, FASS 150/150 and custom big line kit. |
#28 |
#29 |
I used a 0332209161 Bosch/Tyco relay into a HD relay pigtail socket.
Relay socket color coded and prewired: Yellow 87 Red 87A Blue 30 White 86 Black 85 I removed the yellow wire and pin end. I removed the red wire soldiered a 2711102 resistor to female plug then to wire and 2X shrunk wrapped then replaced into plug I removed blue, white, and black wires and soldiered connections, shrunk wrapped and replaced into plug. Then I 3X shrunk wrapped for about 4 inches the RED BLUE BLACK AND WHITE wires from the plug into a factory like, extra strong harness. I then disassmbled the cig lighter switch plug wires and soldiered the white to black yellow and the black to the pink yellow wire, shrunk wrapped both soldiered connections and reasembled the switch, plugging it back into the cig lighter. Lastly I dissambled the Exhaust brake wiring plug wires soldiering the red to the brown/orange wire and the blue to the violet/brown wire, shrunk wrapped both connections reassembled the switch plug and plugged it back in. When all done I picked a nice flat space to attach the relay to, through the top holder hole. One self tapping screw and all done. One of the 2 phillips head screws works great also. If the relay blows simple unplug & replace.. the connections will NEVER COME LOOSE or become corroded. Just like everything on my truck I build accessories to the same or heavier duty standards... a couple of bucks and a few mins now saves hundreds and hours later... ![]() |
#30 |
You could also run a toggle switch inline on the power feed from the lighter socket to disable the auto-on feature. When it's crappy weather, that could save you the time of pulling the dash face off and unplugging wires/relay. Then when it's nice again, you could flip the switch and have the EB turn itself auto on again.
Nice write-up, BTW. Thanks!
__________________
Electric Blue 2007 4wd 3500 Mega Laramie 6.7L auto, 6" Superlift with ProComp 37x12.50x20 on KMC XD's, N-Fab bars, Clifford & Jammers, Smarty S67, 32000 miles STOLEN 6-15-09 - 2002 4wd 2500 Sport Quad Cab shorty, 47RE slushomatic, 3.55 & LSD, Leather, 42000 miles, Airhog drop-in filter and an Edge Juice/Attitude box, 5" exhaust, Predator lift pump & big line kit, Pioneer AVIC-N4 with XM, Bluetooth & iPod modules. VIN: 3B7KF23612M235721 Engine # 56902534 |
| Thread Tools | |
| Display Modes | |
