Go Back   Dodge Diesel - Diesel Truck Resource Forums > 1st and 2nd Generation Ram - Years 1989-2002 > 1st Gen. Ram - All Topics
Register Forgot Password?
Search
submit to reddit
Thread Tools Search this Thread Display Modes
Old 03-22-2006, 10:58 AM   #1
Blowndodge
Arm Rests
Has anyone (everyone) worn out there arm rest that your left elbow rides on? Mine is severly dented and the clips that snap it down are torn out of it! Is there a contact that can get them?
thanks
brad
__________________
93 2WD Ext Cab. 16cm housing, turned up pump. Timed at 1.4mm K&N filter. Rev limit set at 2900rpm's. 20lbs. boost. full gauges.
Blowndodge is offline   Reply With Quote
Old 03-22-2006, 11:32 AM   #2
wheelo90
wheelo90's Avatar
Mine has definately wore out bad enough to the point that I put Duck tape on it and it really matches the grey interior. Every so often, I have to replace the tape because it starts to look crappy. Mine had 174,000 Miles on it when I put the tape on it.
__________________
92 w250, 4x4, Auto, DRW, Flatbed, some pump tweeks.
91.5 w250, 4x4, 5sp, power screw almost to run away mode, fuel pin ground, BHAF,40 PSI boost, gauges,
wheelo90 is offline   Reply With Quote
Old 03-22-2006, 11:41 AM   #3
edwinsmith
edwinsmith's Avatar
Yeah, mine are worn and dented but not falling apart yet. I got 160,000 miles on mine. The paper backed fuzzy panels are also warped and peeling away from the plastic on the door panels. I don't know what to do about that yet. Since it's cosmetic it will be a while before anything is done with it but it does bug me.
Edwin
__________________
1989 D-350 Dually CTD, WH1C turbo Non-IC, boost controller set to 34#, 3200 RPM govenor spring YAY!, Autometer Z-series Tach, Boost and Pyro, 5spd Getrag 360, A/C, Power Steering, Brakes, Windows & Locks.
Replaced all seals and o-rings in the VE when I did the govenor spring.
Paint sucks but I'm currently stripping/sanding/priming for new paint. See my photo gallery.
edwinsmith is offline   Reply With Quote
Old 03-22-2006, 01:28 PM   #4
tboling
tboling's Avatar
Mine to has gone flat,I'm not sure if Jcwhitteny offers arm rest's for our old rigs or not. I have'nt tryed Dodge yet. Let me if u fine some one who sells them. Thanks Tboling
__________________
91CUMMINS LE D350 MODS HX35 14CM HOUSING BIG INJECTORS 366 SPRING CUT FUEL PIN AFC GRIND 60 PSI VALVE SPRINGS LOTS OF FUEL PISTON LIFT PUMP, STILL HAVE'NT P PUMPED D80 REAR END 354S 5SPEED
95 CUMMINS SLT 2500 auto BD flex plate,Suncoast triple disk converter,Suncoast valve body,ATS billet input shaft stage 3 rebuild kit, Maghigh tec double deep pan, Engine mods for me to know an you to find out.
tboling is offline   Reply With Quote
Old 03-22-2006, 02:23 PM   #5
ouchman
ouchman's Avatar
Mine was trashed on the drivers side, but the vinyl was okay. I pulled it off and removed the plastic and padding. I cut a piece of 1/4" plywood the same shape as the plastic and added stiff padding. Then I stapled the vinyl to the bottom side of the plywood. Screwed it on to the panel. Not like new, but it works.
__________________
1992 D250 LE A/T
my Tightwad Fixes- TPS fix (dial-in OD shift) WHY SPEND $38 ON A "KIT"? - 2wd Leveled
Mods - Front leveled (Daystar spacers #KG09101BK) - stock springs - shocks (#FTS-9119)
ouchman is offline   Reply With Quote
Old 03-22-2006, 02:46 PM   #6
90dodge
arm rest
mine was shot after about 250,000 miles. i just had mine redone at an upolustry shop! $20 big ones, and looks brand new, like the right side one. and feels alot better on the elbow.
Bob
__________________
SUPPORT OUR TROOPS
NEW TRUCK
98 12V 2500 4X4 5SPD EXT. CAB
ALL STOCK 131K 4.10'S
2 1/2 inch level kit, air bags in rear
dead NV4500
NEW CAR 2001 JETTA TDI 5 SPEED, 152K
SOLD
90 250 LE 4X4 2 TONE BROWN
4" LIFT, RANCHO SHOCKS, 35" TOYOS, 16X10 ULTRAS TYPE 164
KELDERMAN AIR RIDE IN THE REAR.
PUMP MODS....
3 1/2" STRAIT PIPE/ BHAF
NEW 7MM HEAD, 60 LBS. VALVE SPRINGS, PORTED & POLISHED EXHAUST SIDE
FULLY PORTED EXHAUST MANIFOLD
90dodge is offline   Reply With Quote
Old 03-22-2006, 02:56 PM   #7
tyssniffen
tyssniffen's Avatar
I got a new one
My PO handed me a perfect new one, still in the bag when I bought the truck. it was my first fix. So I know they're out there, but I don't know where.
just be sure to work on taking *all* the interior of the door off, and don't try and go at the little pieces. The little carpet like bits are held on by crappy plastic 'rivets' that break when you start looking under stuff.
maybe everybody else already knew that. I'm going to be gluing my carpet bits down, since they're flapping now.
Tys
__________________
1991 Dodge 4x4 Diesel Ram 250 turbo, intercooler, automatic
Now running on Vegetable Oil with a 2 tank system! Love it!
tyssniffen is offline   Reply With Quote
Old 03-22-2006, 03:17 PM   #8
rebal
rebal's Avatar
Check with dodge thats where i got mine
__________________
1990 W250 bought new in Nov. 89 performance built 727 and torque converter , high miler 800 k kelderman air ride
2001 2500 HO 6spd 4x4, Engine brake ,fass,SBC 4" turbo back exhaust BHAF fluid damper,ARP head studs, DSS, Fast cools. wife says trucks fast enough:(
How many of your rights are you willing to give up before you feel totally safe ?Wake Up People vote EVERYONE OF THE BUMS OUT OF OFFICE!
rebal is offline   Reply With Quote
Old 03-22-2006, 05:35 PM   #9
Nuttymopar
Nuttymopar's Avatar
Not sure if these people have them or not.
http://www.browns-of-tworivers.com/
__________________
Scott
2005 2500, Arson III CP3, Pro-Guard 7 Air Filter, Swiss Cheese airbox with Ram Snorkel, Chromed Torque Tube, Silencer Ring MIA, Tone Ring modified, Pryo, Boost, LED Trans temp gauges, TC Lockup Switch, Rokktech Sensor, Rokktech Muffler, BF Goodrich M/T KM2 on stock chrome rims.
Nuttymopar is offline   Reply With Quote
Old 03-23-2006, 01:19 AM   #10
AlK
AlK's Avatar
When the armrest padding on the driver's side was all worn out I repaired it by shaping a piece of foam from old flip flops and inserted under the plastic. The armrest is like new.
__________________
06 2500 SLT,4x4,auto,Q/C,SB,black&silver
SOLD - 92 W250-LE,4x4,5spd,3.54,Borgeson steering shaft, Factory Tach,Isspro Pyro & Boost,PDR HX/35 16cm2 Turbo,PW injectors,230 hp Pump,Lear Cap,KDP is dead!
AlK is offline   Reply With Quote
submit to reddit
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.6
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
vB.Sponsors
Copyright 2011, DieselTruckResource.Com
Contacts Backup
